Question about Foxconn 6100M2MA-RS2H Motherboard
How to get my mobo to post cpu and gpu temperature.
I have a winfast 6100M2MA-KRS2 with an AMD 64x2 4200+, it doesnt post a cpu or a gpu temperature, now it has the options in the bios to overclock but changing voltage doesnt register and I cant really push it too far without knowing the temperature that my cpu is reaching.......any suggestions would help.
Thanks in advance for any feedback
  • diefightin Feb 21, 2008
    the mobo is six months old and hasnt had a temp since I bought it, with the old bios or the new updated one.....
    the motherboard is 6 months old and hasnt posted a temp with either of the bios that it has had......also when I change the ram's voltage in the bios it doesnt show any changes on any bench marks that I have run.......kinda sounds like Im "sol".........
I had the same problem w Atl 4000+ solution - update to bios 17
Posted on Mar 16, 2008
  • 34 Answers
You may be looking at a damaged MOBO, which could be the BIOS, or the temp sensors.
Posted on Feb 21, 2008
Problem with Computer
Did you reset your BIOS ? Try reset your bios. remove the BIOS battery(RTC battery) and press the power button after disconnecting from wall socket. Short the jumper somewhere near to the BIOS chip. A user manual is helpful. If you can't find the jumper, simply short the two terminals inside theBIOS battery holder. That is two golden or steel coloured thin sheet like. Put back the battery after an hour and start the system. Tap the DEL button to enter into BIOS settings and change date and time first then boot device order(boot device priority) save and exit. See what is happening. If it solves the issue you have studied another troubleshooting tip. Hope this helps!!!
Dec 08, 2012 | Gigabyte GA880GMUD2H AM3 AMD 880G HDMI...
Is AMD Athlon X2 7850 supported by a foxconn 6100M2MA-RSH2 mother borad?
This is a list of compatable CPU's for your motherboard.
http://www.foxconnsupport.com/cpusupportlist.aspx?type=mb&socket=Socket%20AM2&model=6100M2MA-RS2H&cputype=AMD
Also you can search your board to CPU here;
I don't have your exact model so if you do, and it shows in the list, you're good. My best guess would be taht it would work.
May 12, 2011 | Computers & Internet
6100m2ma-krs2. I'd like to check and see if there are updates for my motherboard. Which model should I use. I'm trying to install an SSD.
http://www.foxconnchannel.com.cn/support/downloads.aspx?ProductModel=6100M2MA-KRS2&TypeID=zh-cn0000003
Should this link ever fail it appears that the 6100m2ma rsh2 may be the same. The link for the krs2 is only on the Foxconn China website.
Though this posting is very old I am posting so that others may find this info which was very difficult to find.
Jul 07, 2010 | Foxconn 6100M2MA-RS2H Motherboard
Do i have to remove the onboard drivers when installing a PCI graphic card?
no need to remove your on board drivers. mobo automatically recognize the external graphics card.
Mar 30, 2010 | Foxconn WinFast K7S741MG Motherboard for...
Where to free download matherboard winfast n15235 driver
Here is a link:
http://www.foxconnchannel.com/support/downloads.aspx
The problem is that the N15235 is not the model of this motherboard. It turned out to be the Foxconn 6100M2MA-RSH2.
Kind regards and please post if you need further assistance
Feb 26, 2010 | AMD Athlon 64 X2 3800+ Dual Core Processor...
Installation of the drivers does not work, how do i fix this?
May be u r using incompatible cd u should download new mobo drivers from web
Feb 16, 2010 | Foxconn WinFast K7S741MG Motherboard for...
DEAD K7S741mg mobo?
1 possibility to check is if there are any bulging/leaking capacitors.
if that's the case, fixable by someone with soldering expertise and spare caps...
Aug 29, 2009 | Foxconn WinFast K7S741MG Motherboard for...
Compatible CPU
check the winfast website for a cpu support list for your model of motherboard, that will tell you if it supports it and ALSO if you need to update the bios to support later cpu's, i'd imagine your using the old socket A standard, see if your motherboard is listed here> http://www.leadtek.com/eng/mainboard/default.asp?lineid=3&seriesid=23&chipseriesid=15 (this is what is now listed in google as winfast and does show winfast boards), please advise if you get stuck anymore.
Sep 22, 2008 | Foxconn WinFast K7S741MG Motherboard for...
MoBo Winfast 6100M2MA-RS2H
This board is made by FoxConn.
Looking up towards the CPU from the bottom the front panel connector is the third connector up from the bottom right and/or should be labeled as show.
This motherboard is made primarily by FoxConn
This is the link to the English Manual download page.
Regards,
Worldvet
Jun 17, 2008 | Computers & Internet
Foxconn 6100M2MA-RS2H Motherboard Logo
212 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
