Question about Taylor # 5598 Glass Body Fat Scale with Invisible Electrodes
How do i calculate total body fat with the taylor 5598 bodyfat scale
r321567499
  • 74 Answers
SOURCE: How do I get the detailed instruction manuel for the Taylor Bodyf
This link allows you to trouble shoot and download manuas directly with/from the company... I hope this helps. http://www.taylorusa.com/advantage/root/contact.html
Posted on Jan 07, 2009
SOURCE: No instructions or warranty papers in box
"Fitnessbalan" posted the answer to your problem -- instructions for the unit in a pdf format: http://personalcare.owneriq.net/mdownloads/500eae21-4ecd-4504-9c69-a27dc677644a.pdf
Posted on May 27, 2009
Testimonial: "Just what I needed, thanks so much."
  • 39 Answers
SOURCE: how do i program the taylor body fat scale
From the Taylor web site
http://www.taylorusa.com/faq-scales
The easiest way to program the scales is to pull the manual up for the scale and follow the directions. The procedure does vary according to the scale.
In general the procedure is to tap the power or set button until it brings up the height and then hit the arrow keys until you get to the correct height. Hit the power or set after each entry usually height, age, gender, athlete mode. It will then beep and you will need to hit the arrow up until you see 1 (this is the memory number) tap the set or power and it will beep again. The scale is now programmed.
The general recall procedure is to hold the power or set button down for 2 seconds (or tap the up arrow) until the memory number goes up. Then just tap the power or set and it will beep. Then step on the scale to get the information. The weight will be first, then running zeroes, then thefat%, and finally water%.
Posted on Jan 21, 2010
Testimonial: "The website does not have a manual. Using 'search' or site map produces nothing. Another problem: scale reads only in cm and kg. Won't cycle to ft/lb."
SOURCE: say it in English,not British
1. Turn the unit on.
2. At the same time, press and hold the "G" button and the power button.
3. While continuing to hold down the "G" button, release the power button.
4. Release the "G" button.
5. If you have done this correctly, the unit will power on. This procedure will switch back and forth between lbs. and kg.
Posted on Apr 25, 2010
jyackle5
  • 8197 Answers
SOURCE: Lost instructions
here is the owner manual from taylor http://personalcare.owneriq.net/mdownloads/500eae21-4ecd-4504-9c69-a27dc677644a.pdf
Posted on May 14, 2010
Testimonial: "Thank you, received the manual promptly, appreciate it."
Need parts list for taylor dunn sc-100-24
Contact Taylor-Dunn Taylor-Dunn Manufacturing Company
2114 West Ball Rd.
Anaheim, CA 92804
(714) 956-4040
Toll Free: (800) 688-8680
Fax: (714) 956-3130
Email: contact@taylor-dunn.com
Taylor-Dunn Vehicle Emission Information
Technical Support
2114 West Ball Rd.
Anaheim, CA 92804
(714) 956-4040 ext: 365
Email: support@taylor-dunn.com
Dec 16, 2014 | Taylor Health & Beauty
What does Err4 mean on weightwatchers bathroom scale mean
Error 4 is a Bodyfat error where the bodyfat percentage is beyond range. Try dampening feet and try again for better contact
Oct 01, 2014 | Health & Beauty
How do you calibrate, it's a body fat scale, can't find model #?
It's important to find the model number to be able to find the correct manual. Below is a link to FAQ's about Taylor body fat scales.
If you do a google search for "taylor body fat scale" you will see a list of a few models. Examine each to see if one of them is the same as yours.
Taylor USA FAQs Scales
Searches related to Taylor body fat scale model number location
taylor body fat scale model 5741 manual
taylor body fat scale model 5761bf
taylor body fat scale model 5731f reviews
taylor body fat scale accuracy
taylor body fat scale 5731 review
taylor body fat scale athlete mode
taylor body fat scale readings
taylor body fat scale5758f manual
Aug 01, 2014 | Taylor Health & Beauty
Where do I get a manual ?
you can purchase a manual of Taylor 5599 440 Pound Tempered Glass Body Fat-Body Water Scale on ebay or in amazon...http://www0.dealtime.com/taylor-glass-body-fat-scale-manual/products
Apr 27, 2011 | Taylor 5599 440 Pound Tempered Glass Body...
What does TBW mean?
You don't specify where it is that you are reading "TBW", but In this context it is likely to mean either mean Total Body Weight or Total Body Water.
I don't understand why you have no manual or instructions. If my comment above does not help you, I suggest you visit the manufacturer's web site.
Jul 12, 2009 | Health & Beauty
Err 4
Sounds like it wasn't initialized, even though it says Er 4 instead of Er 0... According to my manual, to (re)initialize it and reset it to zero, tap the platform lightly. It should show zeroes running across the display for a second or two, then show all zeroes and turn off. It should be re-initialized...
Error Codes for the 5757 (according to my manual):
Er 0 Initialization error (remedy described above)
Er 1 Instability error (step off the scale, then back on)
Er 2 Overload warning (registering weight beyond the 440 pound max)
Er 3 Contact error (body impedance beyond technical limit - try dampening feet and try again for better contact)
Er 4 Bodyfat error (bodyfat percentage is beyond range - try dampening feet and try again for better contact)
Er 5 Bodywater error (bodywater percentage is beyond range - try dampening feet and try again for better contact)
Jul 02, 2009 | Taylor 5757 Digital Glass Body Fat Scale
Dec 01, 2008 | Taylor 5593 Body Fat/Body Water Scale
Taylor # 5598 Glass Body Fat Scale with Invisible Electrodes Logo
218 people viewed this question
Top Taylor Health & Beauty Experts
Ankit Chandel
Ankit Chandel
Are you a Taylor Health and Beauty Expert? Answer questions, earn points and help others
