Question about Dryers
Dryer very loud until heat coil turns on then quiet
    Scholar:
  • 91 Answers
Sounds like the roller wheels are bad, and when the heat is on the metal expands an the noise goes away...... u can replace the wheels an belt an tensioner is cheaper if you purchase the kit rather than separate
Posted on Feb 06, 2010
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
I have a maytag quiet series 200 gas dryer that will not stay heated
replace the gas valve coils on the top of the gas valve they get weak from the heat of the dryer and can't keep the valve open
Jan 11, 2013 | Dryers
Kenmore elite quiet pak 9 Runs but would only heat for about 10 SECONDS then heat would go away but continue running until cycle is done.
The heat coming on for 10 seconds is probably just the pilots trying to light the burner. It sounds a lot like the gas coils (solenoids) are bad.
Mar 09, 2011 | Dryers
I have a Kenmore elite quiet pak 2 and the heat won't come on. It's natural gas
Check your igniter *to see if it glows bright & hot, set on heated dry cycle & start, if not replace it, if it does, you should hear a loud CLICK, before igniter times out, if not, replace the valve coils (donut shaped, slides over a post on top of valve) *observe thru access panel at bottom right front of dryer.
Feb 13, 2011 | Dryers
Our dryer turns on, is getting gas, but does not produce heat. the dryer is 10 years old and is the GE - quiet by design - dbxr453ga2ww.
our dryer turns on, is getting gas, but does not produce heat. the dryer is 10 years old and is the GE - quiet by design - dbxr453ga2ww.
Mar 20, 2010 | GE Dryers
My maytag Dependable Care Quiet Plus 2 /gas dryier
Magyar quiet puls 2, does not heat, have to run 3 times to dry out. Is it usual?
Jul 28, 2009 | Maytag Dryers
FAN ON COMPRESSOR SHUTS OFF
The loud buzzing noise if you have heat pump. May be comming from your reversing valve. To quiet this down. Turn off power to outside unit and squirt some oil into the reversing valve coil area. The coil slides onto a shaft this shaft has corroded a liitle and does not let the valve center itself. Alittle oil on the shaft help and quiets this down. DO REMOVE THE COIL WITH THE INSIDE AIR HANDLER POWER ON IF YOU HAVE POWER TO THE THE COIL AND REMOVE IT IT WILL BURN IT UP. yOU CAN JUST UNPLUG THE COIL IF YOU LIKE. RUSS
Jul 18, 2009 | Heating & Cooling
Electric dryer heat coil off mid cycle
You have 3 thermostats. By the description of the problem it sounds like it needs a new high limit thermostat. All 3 thermostats and the heating coil can be checked with an ohm meter. Also check the ground on the heating coil. It could be grounding it's self out.
Jan 16, 2009 | Kenmore 62602 Electric Dryer
Gas dryer makes loud hum
Sounds like you may have a motor issue, they can get lint trapped inside, and it causes the motor to overheat, and eventually go out. You can remove the top, then the front, and see if thats the problem. Usually, once the motor starts making noise, its time to replace. Right now, the packings in the motor are cold, and once they heat up, they stop making noise, so it could last quite a while.
Nov 16, 2008 | KitchenAid KGYS850LT Gas Dryer
MAYTAG Heat Element Shield?
not really put the plate back on it helps force the air across and keeps lint out
Jan 30, 2008 | Maytag PYE2300AY Electric Dryer
Dryers Logo
Top Dryers Experts
