Question about Jl Audio Stealthbox Single 10" VW Passat 98-05 Speckled Gray
Car wont start.battery is showing full - Jl Audio Stealthbox Single 10" VW Passat 98-05 Speckled Gray
  • 24 Answers
Jump the starter if it starts move back one and find the relay listen for it to click. if it does its good move back to the fuse if good check bat terminals if still not it could be ignition
Posted on Feb 06, 2010
2004 ford taurus ses turns over barley one short time,makes no noise when ya turn it over.Battery is full charge,lights are bright and dont dim when ya turn key
I don't think any of the previous answers came from a qualified technician. heres the deal: starting the car has nothing to do with the headlights, it cant be a bad fuse because like you said it turns over once, the alternator has nothing to do with the starting of the car, and fuel pump wont keep the car from turning over.
follow these steps in order
FIRST, take your battery to an auto parts store and have it checked, even if it shows a full charge it can still be bad.
if the battery test good, clean both battery terminals well. starting the car requires a lot more energy from your battery then the headlights, so even with bright lights there could still be an issue with the terminals.
if the car still wont start, check the battery cable itself for corrosion, if corrosions present replace the cable.
next check the ground wire from the battery to the frame of the car. make sure it has a clean connection on the frame.
if these are good and still wont turn over, then replace the starter.
Jan 15, 2017 | 2004 Ford Taurus
WHEN I START MY CAR THE CAR WILL NOT START
check that your battery is charged up. if it wont start off jumper cables you may have a bad cell in your battery. tap the starter selenoid too to see if it is bound up
Feb 09, 2010 | 1991 Mazda RX-7
No elec power wont start battery full charge
check the 100 amp main fuse right near the battery
Dec 08, 2009 | 1993 Toyota Pickup
Car wont start, acts like battery is dead. battery shows full charge. full lights, buzzers, etc. put it on charger-didnt start...cleaned cable connections-didnt start...tried to jump with truck-didnt...
Check the battery +12v power connection to the starter is in good order,
Check the ground connection between the battery negative and the engine/starter motor is robust and intact.
If no problem with above, replace the starter motor.
Oct 10, 2009 | 1993 Ford Tempo
Wont start
Is starter engaging but is turning the engine slowly then not turning engine? (that's what I'm reading) If so, check both connections at the block and starter. If reading proper voltage 12v or better, check voltage across battery when in "start" if it drops below 9.5v the starter has failed. (you can turn the engine by hand...correct?)
Apr 25, 2009 | Jeep Grand Cherokee Cars & Trucks
Wont start
check the battery cables and make sure they are on tight...you may have a loose connection
Jan 29, 2009 | 1995 Ford Thunderbird
Car won't start
i would replace the starter and while u do that check the flywheel for damage sounds like it may have a bad connection or bad starter
Sep 22, 2008 | 1994 Oldsmobile Cutlass Supreme
Jl Audio Stealthbox Single 10" VW Passat  98-05 Speckled Gray Logo
Top Jl Audio Car Audio & Video Experts
Mark Skinner
hoyzee1
Jamie Henning
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
