2 cd inserted into lacie 52x24x52x burner tray, tray was closed, then discs came out when button pushed, now it goes through the motions, but nothing comes up, seems like whatever lifts(?) the disc for reading is out of alignment, doesn't lift the disc, but lights flash & things sound the same as before.
  • 83 Answers
MAYBE THE LASER INSIDE YOUR BURNER DIED.....IF YOUR ROM CAN READ IT IS OK WITH ONE LASER BUT MAYBE ON WITH THE BURNER LASER.
Posted on Feb 21, 2008
I inserted a DVD wrong side into NEC TV NLT-!9HDDDV3. How do I remove it?
There are two ways to open the CD/DVD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD/DVD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD/DVD disc.
If you still having problem opening with the Eject button, then the CD/DVD drive is faulty and needs replacing.
Mar 29, 2013 | Computers & Internet
My dvd tray is not ejecting,i cannot insert a cd
CD Drive Tray problems
There are two ways to open the CD drive door if the button just below the drive tray does not work.
If this does not work then you can manually open the CD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD disc.
If you still having problem opening with the Eject button, then the CD drive is faulty and needs replacing.
Feb 05, 2013 | Computers & Internet
CD DOOR WON'T OPEN
Just below the CD/DVD tray there is a tiny hole. Insert a straighten paper clip in this hole and gently push the paper clip until the CD/DVD tray pops out. You can now pull the tray out until it is in the fully opened position to remove the disc.
Try pushing the eject button to see if the tray closes, then push the eject button to see if the tray opens.
If this foes not work then the CD/DVD drive is faulty and it needs to be replaced.
Mar 06, 2012 | Dell Computers & Internet
Disc tray on RDR-HX720 doesn't open and display
1 of 2 things
can you hear the motor running inside the player ????
there is usualy a snall pin hole under the tray insert a paper clip into this hile and push it in if tray starts to auto open it might be just a dry set of rails
if rails asumed dry open unit and coat the rails with anti seize and try again with the switch on front cover
Aug 03, 2009 | Sony (RDR-HX710) DVD±RW Dual Layer...
Blinking green light on 1 tray
You could have a faulty drive.
To open the tray, you need a paper clip, straighten it and place it in the small hole below the disc tray, push it in and the tray wull pop out slightly, remove paper clip and pull the tray fully out with your fingers.
Then try to close and open the tray with the push button, if it does not work you need to replace this drive with a new one.
Sep 24, 2008 | Acard Technology (CD1TO7T) CD-RW Burner
Cd tray won't open
their is an tiny hole in the cd tray.. f their is... u insert a pin that cn fit to it you estimate the pin head is... while pushing the eject button
Jun 05, 2008 | Compaq (CDD480172) CD-RW Burner
Won't recognize disc-cd or dvd
The pick up or in other terms laser is faulty if its not under garrentee start by opening the tray and clip of the tray`s cover open the writer and clean the lense with a ear bud and then test it if no response it gets more technical or its time to replace, i hope these tip help you
:)craig
Jan 09, 2008 | LaCie 300722 DVD±RW Burner
My MD16XDVD9 doesnt work. Its power is on with the small greeen light flickering and the bigger green light steadily on. but the the DVD tray doesnot open automatically. Even if it is force-opened and a...
have you got it set on an IDE cable on it's own and if so have the jumper at the back set to master the other thing to do is power of pc and remove ide cable from all devices and leave power cable to burner then torn on pc if you have removed power and ide cable from hard drive then when pc boots in press button on cd,dvd drive to open tray then place cd lense disk or any cd in drive tray press close button and let device kick in if it picks up disk then try with a dvd disk with power on pc if all goes well try with a ifferent Ide cable to motherboard and reconnect harddrive and power up if all goes well the pc should recagonise it if not then get it replaced
Aug 06, 2007 | Mad Dog Multimedia (MD16XDVD9) DVD±RW...
Computers & Internet Logo
David Payne
David Payne
