Question about Abit Fatal1ty FP-IN9 SLI Motherboard
I need a picture to follow.. help
Where on the web can i find a detailed picture diagram of a fatal1ty fp-in9 sli motherboard.. in lames terms on how to install and connect?
    Problem Solver:
  • 18 Answers
This link will download the manual from the Abit website. It should have the parts fairly well labeled. Good luck.
Posted on Feb 21, 2008
Why doesn't it do POST?
Put a hard drive with an operating system on it.
Jan 01, 2016 | Abit Fatal1ty FP-IN9 SLI Motherboard
Fatal1ty FP-IN9 SLi mobo - works great with dual core 65nm and orig mobo bios but upgrade to quad core 45nm and bios 16 and cpu fan makes lot more noise and I then get a chaecksum error and have repeatedly...
Not everything works with everything else. There will always be compatibility issues especially with motherboards and cpus. U have different circuitry, pin configurations, power requirements, ad infinitum.
Apr 08, 2017 | Abit Fatal1ty AN9 32X Motherboard
I have a Fatal1ty FP-IN9 SLI motherboard installed in the case with a 750 watt power supply. I turn on the power, and it runs the Plextor CD writer with an XP installation CD and does not boot the hard...
If there is a disk in the cd device the bios is set up to boot up from there first. So if you have a xp OS disk in there that is what will happen . Remove the disk and it should boot from the hard drive if it is properly loaded.
Sep 09, 2017 | Abit Fatality aa8xe (MBFAA8XE) Motherboard
After testing the memory,gfx card a different hd my PC still turns off at some point once it hits the desktop,took the battery out but nothing seems to stop it shutting down.
The CPU and cooler are they installed properly? Is the Power connector pluged in correctly, both the 20pin + 4 pin and 4pin for CPU? The Black cooler over whats called the north bridge is it extremely hot? Need to keep it cool!
damnor01
Nov 27, 2010 | Abit Fatal1ty FP-IN9 SLI Motherboard
Usually gets as far as the desktop before shutting down
This problem could be associated with over heating. Clean it of any dust, pay sepcial attention to the CPU cooler. It might also be a problem with software. If you turn on your PC without a hard drive installed, is it stable on a screen that says NTLDR is missing or Insert System disk. If it is stable on this screen for a long time longer than say 20 min. Then I would say that it is a software problem. If not then hardware problem!
It would be so nice to help you in person!
damnor01
Installed a new processor and now it wont work
Is that an upgraded processor? If it is, then somehow, it could be its configuration problem with the older processor on software side. Your previous installation of OS remember its past processor and reporting error.
You can try fresh installation. Just for the input.
Apr 04, 2009 | Abit Fatal1ty FP-IN9 SLI Motherboard
Need Motherboard Manual pdf
I have a link to the owners manual for your Fatal1ty AN8 SLI motherboard.
Here's the link,
This is what you need to get that motherboard setup.
Hope this helps,
Eric
Jan 19, 2009 | Abit Fatality aa8xe (MBFAA8XE) Motherboard
Hi lo alarm siren when playing online games
Hi stretcharm_2,
It seems that the hi-lo siren from the mobo indicates that the cpu is over hated.
1st of all, you need to go into the BIOS/CMOS setup to check if the temperature was boosting higher that the prefix alarm. If it's low, but gone up very fast after a few minutes, you need to update to the latest BIOS firmware, as it's part of the Fatal1ty problem.
you can download the bios here, be sure to read all the instruction before you proceed to update the BIOS firmware.
http://www.abit.com.tw/page/en/download/download_bios_detail.php?pFILE_TYPE=Bios&pMAIN_TYPE=motherboard&pTITLE_ON_SCREEN=Fatal1ty+FP-IN9+SLI&pSOCKET_TYPE=LGA775
PLEASE BE EXTRA CAREFUL WHEN UPGRADING THE BIOS AS IT MIGHT KILLED YOUR MOBO.
you can always come back here and post a comment if you r no sure.
2nd of all, you need to check is the heatsink was fixed properly.
It's not your fault that's the fan wasn't fixed properly because the stock LGA-775 socket T heatsink's design wasn't a perfect one, and it has 4 very fragile fix-in clips. You need to check if all four clips were fixed firmly in the braket for maximum heat dicipation. It might be broken and you need to replace with another one.
You might need to replace the thermal paste to a better 1.
Please check your manual on how to diassemble the heatsink.
Good Luck,
Don't forget to rate my solution, thanks!!
Jan 17, 2009 | Abit IC7-G Motherboard
Blank screen at boot up
Sounds like you need a new motherboard how old is his computer but, before you start looking for a new board try resetting the main board jumpers maybe that will get it to work and if there are no jumpers remove the battery from the motherboard this does the same thing.
Jun 02, 2008 | Abit Fatal1ty FP-IN9 SLI Motherboard
Abit Fatal1ty FP-IN9 SLI Motherboard Logo
169 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
