Wm 255 Lincoln mig welder. Gas leaks at where wire enters wire feed. Is there an Oring?
SOURCE: electrical problem with mig welder
Call Lincoln Electric (the manufacturer) at
216-481-8100 and ask them to email you one.
please rate my answer,
Carl
SOURCE: lincoln mig welder
Check the earth clamp, make sure all the cables or in good condition and secured, if the unit is three phase, get an electrition the ensure all the phased are functioning. test the fuses with a meter, get back to me if all is OK
SOURCE: need wiring schematic for miller 140 wire feed welder
No problem,email, write or phone for this information, Miller personel are very obliging as are most Welding manufacturers.
SOURCE: WILL THE LINCOLN SP125 MIG WELDER WELD ALUMINUM AND STAINLESS?
The mig welder should be capable of welding aluminum not stainless but the makers should be able to give you more detail. mig is used for steel and aluminum normaly but I do not know this transformer
SOURCE: hey, i was using my Lincoln mig welder 3200 hd the
kink in the wire. Or the rollers are to tight.
