Question about Sanyo SR-4912M
How to reverse door on sanyo sr-4912m refrigerator
5 Suggested Answers
Agent Dort
  • 216 Answers
SOURCE: Sanyo SR-4912M 4.9 cu ft refrig temp problems
Greetings macx,
The average refrigerator temperature is between 35 & 38 degrees. The maximum temperature a refrigerator can be before bacteria begins to grow is 39 degrees. It would be my recommendation to exchange this unit if you can at your local retailer. If this was purchased at Best Buy, you have a 30 day return/exchange policy on this item with no restocking fee.
Thank you,
Agent Dort
Go Ahead. Use Us.
Posted on Apr 17, 2008
SOURCE: Where to buy Sanyo SR-366 parts? I need a freezer door.
I will probably have one, I'll look to see if it can easily be removed.
Posted on Mar 25, 2009
SOURCE: Sanyo 4.9cu.ft. compact refrigerator heats rather than cools
I'd already picked up a replacement (B&D 2.7cf) before I found the website and asked the question,,,, hoped for a quick fix answer and I'd be able to return the B&D.... oh well. With 'designed' obsolescence and 'disposable' appliances, Robert L's answer confirmed my 'fears'.
Now I'm trying to find someone locally (Conroe, TX) who would like to 'recycle' the Sanyo (everything but the compressor/motor is in great shape - door, glass shelves, etc. maybe even the coolant which I don't want to 'dump' in a landfill.
Posted on Jul 23, 2009
SOURCE: Sanyo counterhigh refrigerator model SR-4911.
remove shelves and insert keg.
Posted on Feb 03, 2010
Door left open on Sanyo SR-4912 and frost on back wall, what do we do?
Best, remove food switch off, leave door open and put plenty of towels down to soak up moisture, when clear restart closing door, give couple of hours to get up to speed restock
Jul 21, 2014 | Sanyo SR-4912M 4.9 cu. ft. Counter-High...
Too cold
Over time, internal parts wear out. If you made all of the manual adjustments to the thermostat control and it fails to raise the temperature accordingly, then it needs replacement. Contact the manufacturer for replacement parts and instructions.
Mar 05, 2014 | Sanyo SR-4912M
Where can I find the model number on the sr-4912?
that is the model number,, I believe its the M series , here are parts listed for it http://www.partstore.com/Model/Sanyo/Sanyo/SR4912M.aspx
Jul 15, 2011 | Sanyo SR-4912M
What is the part number for the evaporator plate? because i accedently punctured the plate while cleaning it?
cant help you with the part # but i would try to repair it rather than replace it . there is a epoxy kit for refrigerators . about 10 to 12.00 dollars, and if the hole is not too large most repairs do work . you will have to vacuum the system and replace the gas . . the repair will be by far easer than replaacing the plate. hope this idea will help you . mm
Oct 10, 2010 | Sanyo SR-4912M
Frost on compressor lines
make sure condenser coil is clean(dust,dirt free) then you may be low on freon(refrigerant) and need that checked,after you clean coils touch top of compressor head to see if its overly warm,thats a good indicator that refrigerant is low
Aug 26, 2009 | Sanyo SR-4912M
Jul 23, 2009 | Sanyo Refrigerators
Motor runs, some ice at top level, but temp is at 50-60 degrees.
Defrost the freezer. Door being ajar allows moisture to build on the freezer coil and stops air circulation. In frost free units this condition should clear itself after about 8-12 hours max. Locating and advancing the timer by rotating the clutch head screw clockwise slowly until you hear one click. This will start the automatic defrost manually.
May 19, 2008 | Sanyo SR-4912M
Greetings macx,
Thank you,
Agent Dort
Go Ahead. Use Us.
Apr 17, 2008 | Sanyo SR-4912M
Sanyo SR-4912M Logo
122 people viewed this question
Top Sanyo Refrigerators Experts
John Tripp
John Tripp
christian nielsen
Are you a Sanyo Refrigerator Expert? Answer questions, earn points and help others
