Question about Sony SDM M81 18.1" LCD Monitor
My sister started playing an Ispy game and i had to use the esc key to get out of it and adn now my previously geen blue and yellow back ground is green blue yellow red and pink and all colors on internet are wrong and words are distorted only one thing is normal which is the game screen of World of warcraft any idea?
  • 163 Answers
It sounds like you have burned the screen with bright colours for a long time, this should go back to normal after a couple of days.
Hope this helps!
Posted on Feb 05, 2010
Rainbow Six Vegas cheat codes
Various Cheats
While playing, input the following keys to activate the code/effect (editors' note - none of them are useful). All codes are input during gameplay, while the game is paused (START) and while the LEFT BUMPER is being held.
  • Big Heads - RED, BLUE, GREEN, YELLOW, LEFT CLICK, YELLOW, GREEN, BLUE, RED, RIGHT CLICK
  • Colorful Bullets - LEFT CLICK, LEFT CLICK, GREEN, RIGHT CLICK, RIGHT CLICK, RED, LEFT CLICK, LEFT CLICK, BLUE, RIGHT CLICK, RIGHT CLICK, YELLOW
  • One Shot Kills - LEFT CLICK, RIGHT CLICK, LEFT CLICK, RIGHT CLICK, GREEN, RED, LEFT CLICK, RIGHT CLICK, LEFT CLICK, RIGHT CLICK, BLUE, YELLOW
Nov 15, 2013 | Computers & Internet
Alpine cda 9807 in yukon xl
hi david, check out the connection of the yellow and red wires on the back plug. yellow must be connected to a direct battery positive line(continuous positive), the red must be connected to a live wire from the ignition switch OR from a point that is +12v live once the car is started(switched positive). also make sure that that the ground connection is a direct good connection to the body of the vehicle!! make sure that the remote wire(blue) is insulated if you not using an automatic aerial or external amplfier. good luck.cheers.
Sep 08, 2013 | Alpine CDA-9807 CD Player
Where can i find a printable page to print all the controls and functions on lock on moder air combat please help
Scroll Lock Key nearest air target Alt + Scroll Lock Key center-of-view air target Shift + Insert Key next air target Shift + Home Key previous air target Shift + Scroll Lock Key nearest ground target Ctrl + Num Lock Key center-of-view surface target Shift + End Key next surface target Shift + Delete Key previous surface target
MISSION EDITOR Ctrl + N Key create a new mission Ctrl + O Key open an existing mission Ctrl + S Key save the active mission to disk Ctrl + Shift + S Key save the mission under another name Esc Key delete the current selection on the map Delete Key delete the current selection on the map Ctrl + Shift + C Key assign the active mission to a class and protect it with a password Ctrl + Shift + D Key declassify the active mission Ctrl + H Key hide or show specific objects on the map Ctrl + 1 Key return the map to the default magnification level around the crimean peninsula Ctrl + + Key magnify the map by a factor of 2 Ctrl + - Key scale the map down by a factor of 2 Ctrl + O Key take the view down to a very close level Ctrl + V Key magnify the map to a regional view centered on the selected object Ctrl + B Key view and edit the mission briefing Ctrl + D Key view a debriefing when a saved mission is loaded Ctrl + F Key start the current mission Ctrl + N Key begin a network multiplayer session Ctrl + M Key chat with other players during a multiplayer session Ctrl + R Key start the mission and record a video sequence Ctrl + P Key play back the last recorded video sequence Ctrl + V Key start the video sequence and enable its editing Ctrl + Shift + F Key specify failures that may happen to your aircraft Ctrl + Shift + W Key specify meteorological conditions Ctrl + Shift + E Key open encyclopedia Ctrl + Shift + O Key open options screen F1 Key help F2 Key keyboard command list
Feb 27, 2011 | Video Game Consoles & Games
Hi my son is playing smackdownvraw 2011 on his xbox 360, when he saves his progress its fine, but when he restarts the game it says the file is corrupted, and has to start a new file and lose all previous...
try turn ing off autosave adn have him save it manually. there are many bugs known with the saving issues of this game. About all you can truly do is wait for an update. Also if you son is using a custom enterance there are reports of saves not working if saving after picking custom music
Jan 19, 2011 | Microsoft Xbox 360 Console
I WOULD LIKE TO KNOW COLOR CODE ON WIRING IGNITION SWITCH PLEASE. THANK YOU.
They all are not necessarily the same. What model and brand.
You must have the brand and model number to know this information. Some craftsman and their sister machines are connect as follows: B (battery) Red wire from fuse. G (ground -12V) L-black to reverse switch A2 Black to seat switch A1 blue to fuel shut off solenoid and hour meter M (magneto) grounds out ignition coil and connects to clutch/brake pedal S (start) white connects through clutch/brake pedal and attachment clutch then to solenoid.
The switch functions are: off M+G+A1
Run override B+A!
Rin B+A1 adn L+A2
Start B+S+A1
Aug 06, 2010 | Garden
Bypass code for dual xdvdn9131? is there a bypass code for this new unit?
dont need a code just get a toggle switch and hook that to the yellow/blue wire and with the other side ground to the small lil screw where you will see a small lil short wire and then all u have to do is fallow the screen with the e brake but just flip the switch 3 times with the whole one sec then off for 3 sec then on
Feb 18, 2010 | Jensen VM9510 Car DVD Player
My son has a used ds game of Pokemon Diamond (bought off eBay)that did not come with the instruction manual. He'd like to delete the saved game that's on there so he can save his own. Does anyone know how...
Far as I know coming from former GameBoys even to the DS. The game itself is not saved upon the actual Game itself, but the System or in the case the Gameboy. If he had played the game before most likely it is a previous saved gamed he palyed or someone else. All pokemon games have a common point, that you can only play one game at a time, if you try to start a new game, the previous saved game is deleted after saving on a new game. Granted that I have not played the newer verisons of the Pokemon, but if they are anything like the older verions. Emerald, Ruby, Red, Yellow, Green, Blue, Etc. They will delete the game once a new game is started and saved.
DrakeTech
Dec 28, 2009 | Nintendo Pokemon Diamond for DS
Ps3 will play blu ray but not game
lols check ur wires bro. the basic yellow, white and red wires. make sure the yellow i belive is connect properly. if that doesnt work then go to system settings and check for a solution there
Apr 15, 2009 | Sony Playstation 3 (PS3) Console
Sterio wireing problem 1996 dodge avenger
To my knowledge most 1996 Dodge Avengers do not have a ground wire, instead, it uses a braided strap screwed into the rear of the radio unit. However in some units, the ground uses Black/Yellow.
Additionally:
Constant 12V+ Red
Switched 12V+ Blue
Ground Black/Yellow
Illumination n/a
Dimmer Green/Yellow
Left Front (+) White/Blue
Left Front (-) Black/Blue
Right Front (+) White/Red
Right Front (-) Black/Red
Left Rear (+) Yellow/Blue
Left Rear (-) Gray/Blue
Right Rear (+) Yellow/Red
Right Rear (-) Gray/Red
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 16, 2008 | 1996 Dodge Avenger
Red blue gren dotty
Hi
your monitor is 100% ok check your Vcd/DVD Connection
Mar 06, 2007 | Samsung SyncMaster 740N 17" LCD Monitor
Sony SDM M81 18.1" LCD Monitor Logo
80 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
