Water pump problem
Can anyone replace the water pump on a paykel washer or should this be done by a contractor?
  • 572 Answers
You can do it. tilt the washer backwards about 45 degrees enough where you can work on it. its on the left hand side unscrew it 2 screws and remove the harnes and the hose. water always sits on pumps so dont ge wet.
Posted on Feb 05, 2010
Replaced water pump and control panel, have power, but just beeps.
Fisher and Paykel GWL11 Top Loading Washer
ths.gardenweb.com > Home Forums > Laundry Room
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... 4) (Rinse Phase) Drain the water, then lock the lid for spin. ..... I plug the power cord in and I have nothing on the control panel. ..... As the controller was only replaced early in January, I've flicked F&P NZ an email to see if it's still under ...
How to repair a Fisher Paykel Washing Machine
www.instructables.com/.../How-to-repair-a-Fisher-Paykel-W...
InstructablesI removed the pump and control panel, found no blockage in the pump, so far ... Ihave just tried to fill my F/P machine but the water is just dripping in. ... I have aFisher Paykel washer have replaced the control module and now it .... washing machine MW612, stopped working and displayed beeping sound every second.
Jan 16, 2016 | Fisher and Paykel GWL11 Top Load Washer
I have a Fisher and Paykel MW511 but the water will not pump out can anyone help?
Thanks for choosing FixYa and welcome to the site. You need to check all of your drain hoses and make sure none of them are clogged. There are many items or articles of clothing that can block the hoses. You also need to check the water pump located inside the washer also. This is what pumps the water out of the tub. It may not be working or it may be clogged also. You can get inside the washer on the back panel or by taking off the control piece, depends which wahser this is. That is where you need to check. Hope this helps.
Jul 10, 2011 | Fisher and Paykel Washing Machines
My Model GW712 won't spin or drain Top loader fisher & paykel
hi there the first thing ill tell you is that the washer needs to drain water before it can spin there are only a few factors that prohibit this operation a faulty lid switch secound a blown or blocked water pump being a fisher paykel they are famous for jammed water pumps as they decided when they built the sysyem to turn the water pump upside down this causes a lot of stress on the water pump see if you can lay the hose on the ground and get all the water out i belive the machine will then start to spin dry. in this case it is the water pump and have it replaced its a simple operation if you can order the part fromf/p you simply turn the washer on its side depress the white latch next to the pump turn the pump clockwise till ity release from machine disconnect power supply plug and fit new unit as per reverse
best of luck
sonic boom electronics australia
Nov 06, 2010 | Fisher and Paykel Fisher & Paykel Washer
Replace drain pump
Hi just read your posting.Now if you look underneath the machine have you got the pump with a fan on it?It should be colored red or black.If you have this pump type the locking tab is on the right hand side of the pump looking from the front of the machine.If you have the other type it has two screws holding it to the base of the bowl.Hope this helps and please reply and tell me which pump type you have and if you require further help.
Jun 09, 2010 | Fisher and Paykel IWL12 Top Load Washer
Fisher&Paykel Laundry: Fisher&Paykel Washer: smartdrive 058 leaking by the pump...
Hi if you can see the water leaking from the base of the pump pump needs replacement better to do now than later when pump fails and takes out main board :)
May 18, 2010 | Fisher and Paykel Fisher & Paykel Washer
Washer will not drain water out properly
you may need to take the pump apart as it may be clogged.
Apr 09, 2009 | Fisher and Paykel Fisher & Paykel Washer
Fisher & Paykel washer - manufacturer in October 2005
Please follow link Might require free sign up.
According to my experience it sounds the your pump is blocked or outlet of water obstructed.
Normally when pump cant be activated you get this problem.
May 18, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher paykel empties as it fills (similiar to recent entry)
Check your drain hose behind the machine. This should be approx 3 feet from ground level; then into the wall standpipe. The fix behind should not be air-tight. Your pump pumps the water 'over' this height. This may be silly.....but just check.
& rate if helped pl....................or 'thanks for trying' & your prob will be back here on the net for further solutions by anyone else.
Jan 11, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Washer
If your washer does not stop filling, you have a problem with your inlet water valve at the rear top of the machine. You simply have to replace this.
Nov 30, 2007 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
46 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
