Question about Freezers
There is ice build up on the bottom inside of the freezer.
  • 52 Answers
Check your tempt setting, make sure it is NOT at the lowest setting and set at recomended. I'd defrost then restart the fridge.
Posted on Feb 06, 2010
Daewoo frsu20iai freezer builds ice at bottom and starts to defrost some items?
Try clearing all vents - inside (make sure vents not covered - in fridge and freezer) and outside (gently vacuum - the coil areas in the back and bottom of fridge)
Aug 25, 2014 | Daewoo FRSU20IA Freezer
Icing up
I've just had a similar problem. I fixed it by removing the large panel on the back of the inside of the freezer. I found a large build up of ice at the bottom of the freezer which seems to have developed because the drain hole at the bottom of the freezer was blocked. I defrosted the ice, cleared the drain and now the freezer is working fine.
Jul 23, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Freezer model EV171NYMS04 we have ice build up on
There is a drain the back of the freezer that is frozen. Your trickle of water comes from the ice that melts off of the refrigeration coils during the defrost cycle. You need to turn off the freezer, then remove the rear cover from the back wall to expose the coils. With a hair dryer, melt all of the ice. You will find a drain under the coils. Melts all of the ice in this drain so water can get out of the freezer. When this drain is clear, you can put everything back together, and your freezer should work normally.
Mar 12, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
Ice crystals forming on inside front freezer panel
Very possible the door seal is not properly sealed. Warm inflowing air onto a cold coil will cause ice build up at the lid.
Oct 08, 2009 | Kenmore 22.7 cu. ft. / 643 liter Chest...
My Whirlpool upright freezer keeps building up ice inside the bottom back wall. The fan starts rattling and freezer will not stay cold enough to make ice. If I take everything all out and leave it off...
Either your defrost timer, defrost heater or defrost thermostat has failed. All parts are located behind the lower back panel inside the freezer. Most likely are the defrost heater and defrost thermostat.
Jun 09, 2009 | Whirlpool 20 cu. ft. / 566 liter Upright...
Ice at the bottom of freezer ice at the bottom of freezer, defrost water not draining
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
May 30, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Running but does not get cold enough
feel the sides or the coils on back if it has any see if they are hot or cold
Feb 20, 2008 | Maytag 15 cu. ft. / 425 liter Upright...
Is the frost build-up in my freezer normal? Why do I have ice in forming the the bottom of my frost free freezer?
The drain has most likely frozen over. It is at the bottom behind the back panel inside the freezer. You will need to remove all of the ice and run hot water down the drain until it is clear.
Nov 16, 2007 | Freezers
Freezers Logo
56 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
