Question about Philips DVP642 DVD Player
I have a Phillips DVP642 and it will play some DVD's perfectly fine and others get stuck on "Loading" and never play. Seems totally random.
There may be a problem with the lens. I would first use a DVD disc cleaner. This cleaner looks just like a disc with some extra little brushes on its surface. Some DVD cleaner kits even come with supplies to clean and modify scratches on your discs. You may have dust on the lens. Also look at each DVD you load into your player, if it has fingerprints, dust, or a scratch it will not load. Click on the link below to view cleaner kit:
http://www.google.com/products/catalog?hl=en&source=hp&q=dvd+cleaner&oq=&um=1&ie=UTF-8&cid=16815621778595702533&ei=XoFsS4qIAYPasgOo59CyDQ&sa=X&oi=product_catalog_result&ct=result&resnum=4&ved=0CC0Q8wIwAw#ps-sellers
Posted on Feb 05, 2010
CAN'T OPEN DRAWER
Hello
There is a motor along with belt to control the disc tray for every DVD player. If this belt or motor [loading motor] has trouble, the tray won't come out or get into. Check these for perfectness.
Dec 12, 2011 | Philips DVP642 DVD Player
Wont play says loading then goes back 2 saying no dvd
Try to play music and if working keep playing, until dvd can be played.
Nov 22, 2010 | Philips DVP642 DVD Player
Stuck dvd and no power
I fixed this problem in my DVP642 by replacing a capacitor on the main power board where the power chord hooks in. Take the top cover off (after unplugging player). You'll be able to locate the bad capacitor on the circuit board located on the very right. Look for location marked c316 on the circuit board. A bad capacitor will be bulged up on top. The capacitor you're looking for will be a black barrel shape with an aluminum top, this aluminum top will be bulged up or leaking on the circuit board. Replace this capacitor by desoldering the two leads into the board and replacing with an identical part you can pick up at Radio Shack for a couple dollars. My repair for this identical problem was a success. The blinking light is the tip off for this particular problem on these Phillips models.
Oct 08, 2009 | Philips DVP642 DVD Player
DVD player plays VCD/SVCD but not DVD
there is a problem with the disc motor, replace it
Apr 08, 2009 | Philips DVP642 DVD Player
Will play sound but no picture
1.check your video cable between DVD and TV.
2.in back of dvd one yellow socket only for video out others for some other purpose.
3.open tray conditon .-go to system menu on Remote -go to general set up page-video set up -and switch of .progressive -in OFF-mode.
then try it for video play back
4 if not ok replace the video decoder ic.
Nov 12, 2008 | Philips DVP642 DVD Player
Tray is not opening
To open the tray this is not a perfect fix, but it will allow to use it. After the unit is powered on: 1)Hit the "Open/Close" button 2)Wait a while (you will get the timing down with practice) 3)Tap gently, yet briskly with fingertips at area in the attached pic, that the red arrow points to I think the problem is that the tray becomes unbalanced somehow. Because when a DVD is in, the drive opens fine, only when there is no disc do you have to tap on the unit.
Aug 13, 2007 | Philips DVP642 DVD Player
Toshiba disc error
Check formatted disc see if it's +R,-R and see if Toshiba will play homemade disk or just disc recorded in different format.
Jun 25, 2007 | Philips DVP642 DVD Player
Won`t play disney movies
Apparently this is a known issue. Some dvp642 players have compatibility issues with some of the Disney DVD's. A firmware update might help. There is a discussion of this at: http://www.videohelp.com/forum/archive/t317193.html
Feb 19, 2007 | Philips DVP642 DVD Player
Random no audio
I have had this happen with this particular brand frequently. I have it plugged in to a power "strip" or surge protector. I find that if I turn the strip off then on again, it resets and fixes the problem.
Feb 18, 2007 | Cyberhome CH-DVD 300 DVD Player
Philips DVP642 DVD Player Logo
50 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
