Question about Whirlpool GD2SHGX Refrigerator
No water is coming out of the water line to make ice. It made ice previously. I defrosted thefreezer and still no change. I assume it is a float issue? Whirlpool mark 1 series.
  • 572 Answers
Check your water filter
Posted on Feb 05, 2010
Hi I have an LG- LFX23961SW The water hose that goes from water valve to ice maker keeps freezing up so no water goes to ice maker. We first thought the problem was the water valve, but discovered the...
Water is delivered to the ice maker mold bymeans of a "tube-within-a-tube" design. A conduit system consisting of three separate pieces(liner fitting, conduit, back panel fitting) isfoamed into place in the cabinet.This conduit provides a pathway from thefreezer liner to the back panel. The majority ofthis system is routed above the refrigerator linerto prevent the water tubing from freezing. Thetubing that delivers the water is routed throughthe conduit, and is secured by snapping into place at the freezer liner fitting.
And also check freezer temp and defrost system is working.I hope repairman would replace the insulation of tube by taking door as you said. Thanks.
Jan 29, 2011 | LG Refrigerators
Ice build-up in bottom of freezer section.
your defrost drain on the freezer side is stopped up causing the drain to freeze over then eventually running out on the floor during the defrost cycle. Locate the drain at the back of the freezer and thaw it out using hot water. Using a screw driver or other object gently push down into the defrost hole and dislodge whatever is stuck there.
An air hose with good air pressure may also work well. When the drain line is clear you should be able to pour water through it freely.
Jun 30, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
THE WATER SUPPLY LINE FOR THE ICEMAKER KEEPS COMING LOOSE
this is usually caused bythe tube that goesinto thefreezer compartment being plugged with ice.itplugs with ice because the water valve is not closing off completely(like a drippy faucet)these drips make it to the tube and freeze eventually plugging the tube.the solution is to thaw the tube and replace the water valve
Jan 19, 2010 | Frigidaire Refrigerators
GE Eterna series Ess23xgsbb That the ice maker makes and but the despinser keepe freezing over. We have taken it out and defrosted it and with in 48 hours it frozen over again
I assume you're talking about the ice dispenser and the ice bin being frozen over.
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube and causing the water to spill into the ice bin. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
Aug 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water drips slowly out of dispenser, ice distribution is fine.
Hi, yes the water line could be starting to ice up; maybe defrosting the fridge will cure the problem. Mine has a coiled tube behind the lower drawer in the fridge, this is where the water line is chilled. Hope this helps if you've not sorted the problem already. Kind regards jb
Jul 02, 2009 | Whirlpool GS5SHAXN Side by Side...
Whirlpool refrigerator will not make ice
This is almost always due to a faulty shutoff valve. The valve is at the back, where the water line connects to the refrigerator. Turn off the water supply, remove the water line with a wrench. You should be able to take out the valve with a few screws and by removing one or two wiring clips and the plastic line on the other side leading to the fridge. A new one costs about $60 - $80 at a appliance parts store. Bring the old one with you, and the refrig. model number, and make sure the new one looks the same as the old.
The problem stems from the valve continuing to leak a bit of water to the icemaker after it fills the tray and shuts off. This trickle of water freezes and blocks the line, so matter how many times you defrost it, it will just happen again.
Jan 14, 2009 | Whirlpool Refrigerators
Leaking Kenmore fridge
ok sounds like a froze or blocked defrost drain.take a pice of weed eater line about 6 feet .tie a good knot at one end.then feed the unnotted end down the drain hole and pullout at other end.when you pull the nott witt clean drain.if it wont go thru it may be frozen.you can shut it down over night or use blow dryer.watch out for water and electricty
Dec 31, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Hoshizaki ice machine repair?
seems that its low on water or float switch is bad. try to clean float
Sep 02, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Particles in Ice Cubes
i whould tac the xcbgkvoxchcgdhfjg
hfggfsrfkghghghjgcz
Jan 29, 2008 | Frigidaire FRS23R4A Side by Side...
Whirlpool GD2SHGX Refrigerator Logo
157 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
