Question about Citrix GoToMyPC
The initializing bar keeps running - Citrix GoToMyPC
  • 163 Answers
Try re-installing the software.
Hope this helps!
Posted on Feb 05, 2010
Initializing
NVRAM Initialization:
1. Turn the printer off.
2. Press and hold down CANCEL (X) and Start Copy (button just below the X button) buttons at the same time while powering on printer. *Keep these buttons press while you power on the printer*
3. Continue to hold down buttons until the printer display reads PERMANENT STORAGE INIT.
4. Release the buttons when "PERMANENT STORAGE INIT" is displayed. Printer will return to Ready automatically.
Dec 12, 2012 | HP Hewlett-Packard - LaserJet Pro M1217nfw...
Tip
How do I troubleshoot a Symbol Barcode Scanner?
<p>Barcode Scanners Symbol read and translates the barcodes on merchandise. The scanner translates the bar code symbols on the label says the price of the item and merchandising information. Traders use the symbol bar code scanner to identify their merchandise. A programming error in reader bar code symbol will cause confusion and may lead to loss of money. Troubleshooting barcode scanner symbol allows you to identify bugs and find solutions to errors. <br /> <p><br /> <p>1. Remove the installed fonts from the reader bar code symbol. The sources of such capacity to disrupt the functioning of your bar code scanner. Press the "Menu" button on the scanner bed and press the "Select" option when the source is highlighted. Press the Delete button to remove the sources of the sample. <br /> <p><br /> <p>2. Close the bar code scanner Symbol with a source of energy. The scanner has a power cord can plug into an outlet. If the scanner runs on batteries, the battery is fully charged before using the scanner. <br /> <p><br /> <p>3. Move the scanner closer to the bar. The symbol bar code scanner cannot calibrate the bar if you wrong position. Place the scanner directly over the bar and wait for the scanner to read and transmit the code. <br /> <p><br /> <p>4. Wait until the bar code scanner symbol to complete the boot. The symbol bar code scanner is initialized when the USB cable is connected to the computer. Initialization requires a short period of time to complete the process. Let the bar code scanner symbol to be idle for 4-5 seconds before you first scan an object. <br />
on Jun 26, 2011 | Computers & Internet
My 210 visio sound bar keeps losing volume then come back on then goes back off
You will need to take the following steps to ensure that the Vizio wireless subwoofer is working properly:1) You will want to make sure that the subwoofer is in the line of sight of the Vizio sound bar.
2) Ensure the Vizio wireless subwoofer is not beyond 60 ft. away from the sound bar.3) Unplug both the Vizio sound bar and the Vizio wireless subwoofer for 30 seconds and then plug back in.4) Try re-pairing the devices. Pairing works best when you have the devices facing each other about a foot apart during initial pairing, once they are paired you can move them to your desired location.
Sep 12, 2011 | Televison & Video
I purchased a new carb fro my husky 137. When I started it it ran very fast. It is hard to start but when I get it going it runs very fast and will not idle. I was wondering what the initial carb...
1/12 initial settings, sounds like you are sucking air, check the hose from cylinder to carb which runs fuel pump in carb off vac pulses. some saws have one and some just **** through the intake small hole. good luck
Aug 25, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
My chainsaw throws the chain off every couple of cuts wont stay on
Release the chain brake, then remove the bar and chain. Lay the chain out on a flat surface and look for damaged links, or sideways bending of the chain. Replace the chain if you find any such damage. Clean the engine surface where the bar fits to, then start the engine--oil should ooze out of the small port there. If ok, then clean the small oil passages that run from the large holes out to the chain groove on each edge of the bar. Re-assemble the bar and new chain (if required)--tighten the chain adjuster until the chain just comes up to the lower bar, but not so tight that you can't turn the chain by hand. Tighten the bar mounting hardware and recheck the chain tension again. The chain teeth must be properly sharpened at a consistent angle to assure rapid cutting which keeps the chain heat down. With a new chain, recheck the tension every so often as the chain will initially stretch when used. Test the chain oiling by running the bar tip near some cardboard at speed for a moment or so--it should throw off a thin line of oil. There should be an oil-volume adjustment screw on the engine to achieve this. Check the sawdust coming from the cut--it should be small chips and curls if the teeth are sharp, but it will be a fine dust if they become dull. Hope this helps!
Jan 22, 2011 | Poulan Pro Chain Saw 46cc 20"
I have a te-2200 but cannot get past the initialization. Machine initialization procedure. I keep getting a e004 error. Its in the d11D10D9D8D3D2D1 section that i keep getting stuck in.
Ok. I need to know these things:
1. which country is it being used in? 2. Do you want a PIN number to log staff on, or just simple log on? 3. Do you have a row of buttons next to the key called CLERK or CASHIER? 4. Will you be using a bar code scanner?
If anyone needs a Casio TE-2200, TE-2400 manual, try here: http://the-checkout-tech.com/manuals/cashregisters/Casio4.php
Jul 21, 2010 | Casio Parts Cash Register PC Desktop
Just bought the sony bdp s350, bought the cable
What type of TV? Plasma / LED / LCD.. ?
Typically you should run through your HDMI ... most of the 5 RGB etc.. in the back can only be used on one of the inputs only for high def... HDMI is easier but more expensive cables..
May 12, 2010 | Sony BDP-S300 Blu-Ray Disc Player
KEEPS SAYING INITIATIONG. WHAT DO I DO??
When the player keeps saying "initializing" perform as next:
Step 1: Disconnect your Player
Step 2: Reset your Player
Press and hold the POWER button for 10 seconds
Step 3: Hold down the PLAY key on your Player and connect it to the PC via a USB cable.
Step 4: Release the PLAY key when a progress bar and text, "initializing" appears on the Players display. If you cannot see the "initializing" text, please disconnect your Player and try again.
Manual for RCA M4208:
http://www.voxxsupport.com/images/manuals/M4208/media/M4208_DOC_OM.pdf
All support for this device:
http://support.rcaaudiovideo.com/product.aspx?product=406
Need more support from this side, just post a comment.
Oct 07, 2009 | RCA M4208 MP3 Player
Old homelite XL chainsaw pumping bar oil into engine while runnin
Check that the oiler hole and the hole in the bar that it pumps into aren't clogged. The sawdust running under the chain and be deposited in the oiler hole in the bar until it plugs it solid. That will keep the oil from havintg a place to go and build up pressure.
Feb 21, 2009 | Garden
Won't initialize
You've stripped something out, its a mechanical problem. Probably on the bar that drives the print head.
Aug 03, 2008 | HP PSC 2210 All-In-One InkJet Printer
Citrix GoToMyPC Logo
614 people viewed this question
Top Citrix Computers & Internet Experts
xxxxxx xxx
alibaba69
Are you a Citrix Computer and Internet Expert? Answer questions, earn points and help others
