Question about Dishwashers
Dishes are still dirty after washing - Dishwashers
  • 572 Answers
Check chopper assembly
Posted on Feb 06, 2010
What is the best way to wash dishes when camping?
I found this greatsite that will help you when it comes to camping and washing your dirty disesand laundry ect http://www.your-camping-guidebook.com/camping-dishwashing.html
Jul 09, 2012 | Camping, Backpacking & Hiking
Dishes are still dirty at the end of the cycle
hello,
If your dishes are coming out of the dishwasher covered by a removable dirty film, your water may not be hot enough, or you could be using an inferior brand of automatic dishwashing detergent. If you have tested your hot water and find it is between 140 degrees and 160 degrees Fahrenheit, consider how long it takes for the hot water to reach the dirty dishes in the dishwasher. If the hot water has to travel a long distance to reach the dishwasher, chances are the water filling the dishwasher starts out cold. To alleviate this problem, run the hot water nearest to your dishwasher until the water coming out is hot. This will guarantee the water filling the dishwasher is as hot as it should be to properly clean dirty dishes.
To remove this type of film from dirty dishes, after running the dishes through a basic rinse cycle, set a bowl filled with a cup or two of white vinegar on the lowest rack of the dishwasher. Remove any metal pans or utensils, and with the vinegar on the bottom rack, wash the dishes as usual. Dirty dishes that were once covered in film should come out squeaky clean
hope this help?
thanks.
Oct 23, 2010 | Kenmore Dishwashers
Our dish seem dirty after a wash we have cleaned the filters
turn it on to run it with out dishes but instead of soap use house hold viniger to clean the watter jets thats what keeps the washrer from cleaning well
Oct 26, 2009 | Belling 24 in. IDW603 Built-in Dishwasher
Have a 2+year old LG LDF6810ST dishwasher that shows no error codes but is not cleaning like it used to. Have city water, do not leave excess food on dishes when loading, am only using powder after...
Try these things in order:
-Try to use a name brand powder, rather then a generic. Even a small box. I had similar problems with my LG dishwasher when I tried to save money by buying a generic powder. My dishes did not get clean and white marks were left behind on my stainless steel DW liner and the dishes. When you ad the powder, do not over fill the dispenser. Add less than the full dispenser cup and close it. Place some powder in that shallow square indent on the dispenser lid to help the pre-wash cycle. Also, run the water in the sink until hot water runs immediately before you start the DW.
-If, after using Electrosol or Cascade for 2 - 3 loads and your dishes do not come out clean, then I would run a load of dishes without adding the soap. Start the dishwasher and wait for it to fill and begin to wash. Open the door and add one cup of vinegar (white vinegar is fine.) Feel free to ad another cup after the first wash water drains and the second wash water enters and the DW begins the wash cycle again. Run a load of dirty dishes with the soap and check for good cleaning.
-If the problems continue, it is time to remove the filter assembly by removing the 9 silver phillips screws from the filter assembly. You will also need to remove the lower sprayer arm by pulling straight up and then out. With a flashlight, inspect the sump area that was hidden by the filter assembly, looking for any debris that has jammed into anywhere down there. Watch out for broken glass as you feel around. Reassemble and test with a load of dirty dishes.
The poor drying may be caused by not keeping the rinse aid re-filled. Check that first.
Also, these water and energy conserving dishwashers actually use the "dirt" from the dirty dishes to help clean the dishes during the first two wash cycles. Simply clear the big chunks off the dishes and put the dishes in the DW.
Please report back what you find or if you have more questions. OK?
Aug 12, 2009 | LG LDF6810ST Stainless Steel Built-in...
Mold growing on dishes
Recommend that you run another cycle with no DW soap aded, waiting until the dishwasher has filled with hot water and begins to do the first wash cycle. Then add 1/2 cup of bleach to the water and close the door. Allow the cycle to finish. Run it normally with a standard load of dirty dishes. Note: These high efficiency dishwashers count on the "dirt" of the dirty dishes to help wash/clean the dishes. Recommend you not rinse/wash the dishes before you put them in the dishwasher.
Watch for any occurrence of the black dots and repeat the bleach treatment.
Jul 22, 2009 | LG 24 in. LDF 7811 Stainless Steel...
Dirty dishes
if water comes into machine then valve is ok.
open machine when in cycle and look to see if spray arms are rotating
if not, then take out and clean.
spray arms only rotate with water jetting out of angled nozzles at end and if these are blocked then no rotation and poor wash
Sep 07, 2008 | Dishwashers
My dishes comes out still dirty
I put a bottle of CLR in the dishwasher and I did a wash without any dishes. Repeat if needed.
Aug 18, 2008 | Maytag 24 in. MDB5651A Built-in Dishwasher
Hotpoint BF1620
What you will find is that the plastic nut fixed on the back panel that the top drawer pushes into has lost the rubber inner layer. Replace and your problem is solved
Kamal
Apr 15, 2008 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Dishes do not come clean grit on them
either dirty wash arms of insufficient water
Feb 24, 2008 | Frigidaire 24 in. PLD2850 Built-in...
Dirty dishwasher
there is a new product out called the dishwasher filtration system. it actually filters the water going into your dishes. the dishes look dirty because your water has a lot of calcium and magnesium in it making them appear cloudy or dirty. the dishwasher filter reduces those minerals and my dishes look perfect now. no more dirty and grimy looking dishes. i also dont waste time washing them by hand before and after the dishwasher. hahaha you can get it at www.dishwasherfilter.com. use code DFMTEN and you will get 10% off. it fits right under your sink and is very affordable. you will be glad you bought this product. thanks
Sep 24, 2007 | GE 24 in. GLD5500L Built-in Dishwasher
Dishwashers Logo
149 people viewed this question
Top Dishwashers Experts
