Question about Lexmark Optra T610 Laser Printer
Error 9454 - Lexmark Optra T610 Laser Printer
  • 320 Answers
Im thinking that you mean a 954 nvram error if thats so hold down the right arror, the go button , and the return button power on the machine untill performing self test comes up and release them .90 percent of the time this will get you back to printing. remember this will get you going but it is only a bandaid. this error is created by either an eprom located on the engine board or the nvram chip being corrupted. this board needs to be replaced
Posted on Sep 04, 2010
Take out print screen shot in laptop
You can press the printscreen keys on your keyboard or use the snipping tool found in windows 7 or 8. Hope this helps.
Mar 09, 2015 | Lenovo 3000 Y400 Y400 9454 Y410 7757 Y410a...
How ican know battary conector valtage
Right-click the taskbar, and click properties.
Click notification area and select battery power and save.
Or go to Control Panel and there should be Power Options.
On the Advanced Tab check the "Always Show icon on Taskbar"
And save
Feb 15, 2015 | Lenovo 3000 Y400 Y400 9454 Y410 7757 Y410a...
Codigo de error
List of Error Codes for Precor Fitness Equipment
Error Code List for Precor Fitness Equipment
Feb 05, 2014 | Precor Exercise & Fitness
Need a error list for a Canon IR 600 imagerunner
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
E490 wrong DF type
E500 finisher communication error
E503 finisher internal communication error
E505 finisher backup memory error
E514 stack delivery/trailing edge assist motor error
E519 gear change motor error
E520 off-set motor error
E530 rear alignment error
E531 stapling error
E532 stapler shift error
E535 swing error
E537 front alignment error
E540 stack tray ascent error/upper tray ascent error
E542 lower tray ascent error
E577 paddle error
E584 shutter error
E590 punching error
E591 puncher dust sensor error
E592 punch horizontal registration sensor error
E593 punch shift error
E5F0 saddle paper positioning error
E5F1 saddle paper folding error
E5F2 saddle guide error
E5F3 saddle alignment error
E5F4 saddle rear stapling error
E5F5 saddle front stapling error
E5F6 saddle butting error
E5F8 saddle connector error
E5F9 saddle switch error
E602 hard disk error
E604 image memory error/shortage
E609 hard disk error
E610 herd disk coding key fault
E674 fax board communication error
E710 IPC initialization error
E711 IPC communication error
E716 communication error for pedestal/ communication error for 3-way unitA1
E717 communication error for NE controller
E719 coin vendor error
E730 PDL software error
E732 scanner communication error
E733 printer communication error
E740 Ether board error
E743 DDI communication error
E744 language file/boot ROM error
E745 TokenRing board error
E746 accessories board wrong model error
E748 controller board and SDRAM size mismatch
E805 fan error
Aug 07, 2013 | Canon imageRUNNER 600 Printer
I lost my serial key for Command & Conquer
MUDY L4GW MGWQ 2DQ8 CC1B,22SL T244 YJ4T 4UT2 7CC3,LM4Q MSPD 4MSD WP4T DBC8,SWYQ 8QJT PQLU WW8D 804D,EMLS T2LS PTT2 2W4E 9454,SQWJ EPJP GM4D JDJW 5383,TQGW YLGT MJDM JSYY 57F9
hi there,it should work...
Mar 16, 2010 | Command Video Game Consoles & Games
Canon ir 3530
E490 wrong DF type
E531 stapling error
E535 swing error
E577 paddle error
E584 shutter error
E590 punching error
E805 fan error
Feb 21, 2010 | Canon ImageRUNNER 3570 Copier/Printer
I need a diagram of a 1995 ford escort engine
96 escort 1.9L
Engine Components
Item Part Number Description 1 6766 Oil Filler Cap 2 6A548 (8 Req'd) Valve Cover Bolt 3 6582 Valve Cover 4 — Exhaust Manifold Shield-to-Exhaust Manifold Nut (4 Req'd) 5 9A462 Exhaust Manifold Shield 6 — Exhaust Manifold Shield Stud (4 Req'd) 7 9430 Exhaust Manifold 8 9454 Exhaust Manifold Nut 9 9448 Exhaust Manifold Gasket 10 — Exhaust Manifold Stud (Fine Thread), Short (4 Req'd) 11 — Exhaust Manifold Stud, Long (1 Req'd) 12 — Exhaust Manifold Stud (Medium Thread), Short (1 Req'd) 13 6518 Valve Spring Retainer Key 14 6514 Valve Spring Retainer 15 6513 Valve Spring and Damper, Intake 16 6C515 Valve Tappet Guide Plate Retainer 17 6571 Valve Stem Seal 18 6513 Valve Spring, Exhaust 19 12405 Spark Plug 20 6269 Camshaft Thrust Plate 21 — Camshaft Thrust Plate Bolt (2 Req'd) 22 — Cup Plug 23 6B273 Camshaft Oil Flow Control Rod 24 6K292 Camshaft Front Seal 25 6256 Camshaft Sprocket 26 6278 Camshaft Sprocket Washer 27 6K252 Camshaft Sprocket Retaining Bolt 28 6L269 Camshaft Sprocket Key (5 x 18) 29 6250 Camshaft 30 6051 Head Gasket 31 6A008 Cylinder Head to Block Dowel 32 6010 Cylinder Block 33 6507 Intake Valve 34 6505 Exhaust Valve 35 6049 Cylinder Head 36 — Intake Manifold Stud (7 Req'd) 37 17A084 Engine Lifting Eye 38 — Engine Lifting Eye Bolt (2 Req'd) 39 9439 Intake Manifold Gasket 40 — Bolt 41 9723 Accelerator Cable Bracket 42 9424 Intake Manifold 43 — Intake Manifold Nut (7 Req'd) 44 9D476 EGR Valve Gasket 45 — Exhaust Gas Recirculation (EGR) Valve Bolt (2 Req'd) 46 9D475 EGR Valve 47 — Fuel Injection Supply Manifold Bolt
(2 Req'd) 48 9F593 Fuel Injector 49 9D930 Fuel Charging Wiring 50 6786 Oil Level Indicator Tube Bracket 51 — Oil Level Indicator Tube Bracket Bolt 52 6754 Oil Level Indicator Tube 53 6750 Oil Level Dipstick 54 9D280 Fuel Injection Supply Manifold 55 — Vacuum Fitting 56 9E498 Main Emission Vacuum Control Connector 57 — Vacuum Tap 58 — Vacuum Hose 59 9B989 Throttle Position Sensor 60 — Screw and Washer 61 9F782 Throttle Position Sensor Gasket 62 — Throttle Body Bolt (4 Req'd) 63 — Idle Air Control (IAC) Valve Bolt
(2 Req'd) 64 9F715 Idle Air Control Valve 65 9F670 Idle Air Control Gasket 66 9E926 Throttle Body 67 9E936 Throttle Body Gasket 68 — Vacuum Fitting 69 — Camshaft Position Sensor Screw 70 6B288 Camshaft Position Sensor 71 8255 Water Hose Connection Gasket 72 — Water Hose Connection Bolt (3 Req'd) 73 8592 Water Hose Connection 74 8575 Water Thermostat 75 6065 Cylinder Head Bolts 76 6500 Valve Tappet 77 6K512 Valve Tappet Guide Plate 78 6564 Rocker Arm 79 6A528 Rocker Arm Seat 80 6A527 Rocker Arm Bolt (8 Req'd) 81 — Ignition Coil Mounting Bracket Bolt
(3 Req'd) 82 18827 Noise Filter Condenser 83 — Ignition Coil Mounting Bolt (4 Req'd) 84 12259 Spark Plug Wire Set 85 12029 Ignition Coil 86 12043 Ignition Coil Mounting Bracket A — Tighten to 5-12 Nm (4-9 Lb-Ft) B — Tighten to 5-7 Nm (3-5 Lb-Ft) C — Tighten to 21-26 Nm (16-19 Lb-Ft) D — Tighten to 2-10 Nm (1.5-7 Lb-Ft) E — Tighten to 8-13 Nm (6-9 Lb-Ft) F — Tighten to 40-55 Nm (30-41 Lb-Ft) G — Tighten to 16-20 Nm (12-15 Lb-Ft) H — Tighten to 20-30 Nm (15-22 Lb-Ft) I — Tighten to 8-10 Nm (6-8 Lb-Ft) J — Tighten to 8-11 Nm (6-9 Lb-Ft) K — Tighten to 23-30 Nm (17-22 Lb-Ft) L — Tighten to 20-40 Nm (15-30 Lb-Ft) M — Tighten to 4.5-7 Nm (3-5 Lb-Ft) N — Tighten to 18-26 Nm (13-19 Lb-Ft)
Feb 24, 2009 | 1995 Ford Escort
ROM Error for Canon Image Runner 2010F
When the ROM Error message is displayed on the control panel, this will indicate an issue with the Flash DIMM on the Image Processor PCB.
re-flash the system software for that specific model. If system software does not resolve the error, replace the DIMM Assembly. When replacing the DIMM, you may be required to flash the system software to it's latest version.
iR 2010F FG6-9454-000, Dimm assembly.
As a temporary work around, power on the iR while holding down the STOP key. This may boot the iR to a ready state and copies can be made.
Mar 12, 2008 | Canon USA - COPIERS - ImageRUNNER 2010F...
Lexmark Optra T610 Laser Printer Logo
96 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
