Question about LG KU990 Viewty
Battery life very short in my viewty which is less than 8 months old, although when battery used in another viewty battery fine, suggests it my phone. Suggestions?
    Problem Solver:
  • 17 Answers
Here are three tips:
1. turn off UMTS/3G in your network options, choose the standard 900/1800 instead of auto or UMTS. This can save a lot of battery.
2. turn off bluetooth
3. turn on the power save mode and reduce the screen brightness (you can also select the black handset theme)
Posted on Aug 20, 2010
HI my golf buddy will take a part charge but when i turn it on it tells me low battery. This buddy is less than a year old,used 3 times. I charged it on a regular basis. What can we do? Tkx, Mike
Sorry but what you are describing is a defective battery or batteries. The manufacturer's use the cheapest batteries they can get, and some have a very short life span. I suggest you buy a "Battery Tender" that maintains a full charge and monitors battery voltage, the battery is left on this whenever the cart is idle, it will greatly extend the life of the battery even a cheap one. I have provided a link to the product. Battery Tender Plus 021 0128 12V Battery Charger
Feb 08, 2017 | Computers & Internet
Tip
The Most Important Considerations of Using Laptop Battery
1, when no external power supply situation, if the working conditions at the time slot being less than PCMCIA cards, it is recommended to remove the card first to extend battery life.
2, room temperature (20-30 degrees) for optimum battery working temperature, the temperature is too high or too low, the operating environment will reduce battery time.
3, can provide stable power supply environment, using a laptop computer, remove the battery for extended battery life is not right by. On Asus notebooks, when fully charged battery, the battery charging circuit will automatically shut down, so the phenomenon of overcharging does not occur.
4, the recommended average of three months to conduct a battery power correction action.
5, to minimize the number of NIKON en-el3e battery
The battery charge and discharge is directly related to life, one charge, the battery a step forward to retirement. Suggest that you use an external power supply,
6, the use of an external power supply when the battery removed.
Some users often plug the power several times a day, and the laptop is equipped with batteries, do more damage to the battery. Because each access to the equivalent of an external power supply to charge the battery once the battery life shortened by a natural.
7, after the exhaustion of battery charge and avoid the long charging time
Regardless of your notebook to use nickel-metal hydride or lithium electricity, to power after the exhaustion of a certain charge (charge less than 1%), which is the best way to avoid the memory effect. Lithium also have memory effect, but its memory effect smaller than nickel-metal hydride Bale.
8, the usual precautions
When used in peacetime to prevent exposure to prevent damp to prevent the erosion of chemical liquids, avoid contact with the metal battery contacts, etc. happen.
When you purchase your laptop battery
Laptop battery life - as no more than 3 to 4 years, it may be users of the most likely to replace things. Two years after the laptop, you will find the battery consumption and faster. If possible, you can replace the old batteries for new batteries to ensure the stable operation of the computer.
When the need to replace the notebook computer batteries, best to choose the same type of battery replacement. However, if the old computer using a nickel-metal hydride batteries, to make a longer battery life, of course, can also be specified by the computer user manual or manufacturers recommended models use lithium batteries. Although the nickel-metal hydride batteries for cheap, but there is memory effect, and in the same capacity than the lithium batteries under the weight of large, and lithium batteries have no memory effect, light weight, power supply for a long time, etc., has become a standard notebook computer batteries . Lithium batteries used in notebook computers at this stage because the different manufacturers in the power of time there are some gaps, and friends in the purchase process should be noted that different brands of the difference in the Sony vgp-bsp13/s Battery, the best among several brands compare.
Performance battery power supply in addition to the stated time manufacturers, but also need to pay attention to their capacity. Battery capacity is usually AH (ampere-hour, ampere-hour) calculated with the current laptop is 4000AH most about, and a battery can last for 2 hours or more. In addition to the battery power supply time by the whole power of computers and the impact of factors such as heat dissipation, the screen size (bigger and more power), screen brightness, and the implementation of the work and so will affect the power of time.
Now the price of laptop battery up and down the ocean in 1000, accounting to 10% of overall price notebook - about some of the ultra-thin models or even higher. The battery warranty period, is guaranteed 3 months, and is guaranteed six months, the longest, but also for 1 year; the reason why the warranty time is short battery laptop battery is easy because of consumables, the number of charge is constant, with a little time. Moreover, the laptop battery and other hardware different, there is no room for repairs, can only be a new one. The products of such a long warranty (replacement), intangibles to increase the burden on manufacturers, so buy laptop, be sure ask the battery warranty period and conditions.
Also in the purchase of second-hand laptop computers, they also do not forget to try it inside the battery can continue to work long. Under normal circumstances, the use of one or two years after the laptop is fully charged, the nickel-metal hydride battery can support about 1 hour or so computers at work, lithium-ion battery can support nearly 3 hours, but relative to the terms of this new battery requirements are already very low, and able to meet this target from the scrap to the battery of far away.
Causes of Damage Laptop Battery
Notebook computer CANON nb-6l battery a long time, often charge less for electricity, and even shows the battery is damaged, the specific performance of a larger resistance, the voltage across the charging up faster. So easy to charge control circuit is judged to have been filled, the capacity will naturally decline. Since the battery internal resistance is relatively large, the discharge voltage drop when a large, fast, so the system is easy to mistakenly believe that the voltage is not enough, lack of electricity. Comparison of the discovery of short battery life, should take appropriate measures.
If you need replacement laptop batteries, There are two professional battery shop
UK http://www.global-battery.co.uk/laptop-batteries.htm
US http://www.sales-battery.com/laptop-batteries.htm
on Dec 09, 2010 | Computers & Internet
When I plug in the charger is shows green, but the scooter does not run. Should I replace the battery or the charger? E100 razor.
Check the voltage output of the charger. It should be about 28 volts. Most likely your batteries are dead (over 2 years old?)
Mar 28, 2010 | Razor E100 Electric Scooter
Hi , i got my LG ku990i in december 2009, the Battery life very short. Less than 4 hours. pls advise.
if your product is in warranty goto lg service centre and complaint them that problem with the battery, your phone ll get switched off within 1 hour after fully charged,
they ll replace ur battery.... surely. don't do any tweaks yourself u may lost the warranty.
if not in warranty contact prajwal_yes@yahoo.com
Feb 28, 2010 | LG KU990 Viewty
Viewty's battery loses charge very quickly
with rechargeable batteries you have to fully charge it up then completely run the battery dead for the first 3 or 4 times this is what extends the battery life. I have had an LG viewty for 16 months and only charge my phone twice a week. this is a golden rule for all rechargeable batteries
Aug 19, 2009 | LG KU990 Viewty
Battery Life Shortened
i have the exzact same problem with my laptop but its coz when u watch a movie, play games, listen to music or if ur using up a fair bit of memory it takes up battery life to store it all
Jul 24, 2009 | LG Dare VX9700 Cell Phone
LG viewty ku990 - no battery life and phone gets really hot
Hi
I dont know if this will help you, but it helped me. I had the same problem, with phone not holding charge and getting really hot both during and after complete charge.
I needed my memorycard from my LG to my other phone, so I took it out, and off course the phone needed to be charged so I charged it, and... it did not get hot at all, and when it was finished, the charge lasted a day and a half!! Now the problem is I cant use the memorycard anymore in my Viewty :S Win/Loose situation i guess....
Dec 26, 2008 | LG KU990 Viewty
Battery
This isn't something to get overly concerned with. Most likely it's just the battery, and not a problem with the machine. Batteries are funny. I own a small computer shop, and we specialize in laptops, so I've seen many batteries (with laptop attached) come through. The thing about batteries is that, although they may be the exact same make and model, they will have different characteristics, and no two batteries will be the same. I've had batteries that held a great charge, and would hold a charge for 3 to 4 hours, but only had a life of about 8 months before replacement. Then I've had batteries that will only hold a charge for approx 45 minutes, but lasted 2 or 3 years before replacement. I'm going to say that you just have a weak battery, and suggest that you purchase another to use on a regular basis, and keep this one for a back up (or vice versa). I think it's always a good idea to keep a back up battery.
Sep 05, 2008 | Dell Computers & Internet
LG KU990 Viewty Logo
226 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
