Question about Kenmore Microwave Ovens
I have a model#564 8888620 kenmore microwave oven. What size is it?
jsrock516
  • 5911 Answers
SOURCE: replace handle on microwave oven
The part number for a new handle is 820941 and costs approx. $19. If you already have the part and are wanting to install it follow these steps:
You can either do this with the door in place, or remove it. To remove it, you open the door all the way and push up at the hinges. The door should lift off the hinge pins.
1. On the back side of the door (the side that faces the interior of the oven) is a plastic facing around the perimeter of the glass.
2. There should be a series of slots or grooves around the facing that you can place a small screwdriver in.
3. Carefully (I cannot emphasize this enough) lift around the facing until it comes loose. You may not have to remove it all the way around the door. Sometimes you can gain enough access by lifting on the side where the door handle it mounted.
4. Under the door facing are the mounting bolts (or screws). Remove broken handle and install new handle.
5. Reinstall components in the reverse order as stated before.
If you are waiting to order the part for your oven, you can get it at repairclinic.com. The part will be shipped directly do you for a nominal shipping fee.
This should be a fairly simple repair that only takes about 10-15 minutes.
Again, be careful with the door. If you break it, a replacement door costs over $200! Good luck and let me know if I can help further.
Posted on Jan 18, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: sears microwave oven model number
This is probably a shorted triac or relay.
You can find exploded views and order parts by entering your model number at the Sears parts site.
There may also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
Posted on Nov 27, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Owners manual for Kenmore Elite Microwave Model 66462
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
You can just enter your full model number at the Sears parts site.
On the resulting page, look to the right for the blue "View manuals" button. Click there.
d:%5cele%5crepair%5cmicrowave%5ckenmore_sears%5cview_manuals_button.jpgd:%5cele%5crepair%5cmicrowave%5ckenmore_sears%5cview_manuals_button.jpgd:%5cele%5crepair%5cmicrowave%5ckenmore_sears%5cview_manuals_button.jpgcaab351.jpg
That Sears-related site has many free manuals. While the manuals they list there are all free, they will ask you to register.
Many times, the owner's manual will have the installation instructions inside.
If yours is not listed there for free, you would have to order it through the
Sears parts site.
Posted on Jan 18, 2009
SOURCE: The fan on our Kenmore microwave oven is not working.
My husband took the unit off the wall looked down into the fan and found a dead mouse keeping the fan from spinning. We removed the dead mouse cleaned up the area. Turned on the oven. The fan worked perfectly. Then he rehung the microwave.
Thanks!
Posted on Aug 21, 2009
erpaalai
  • 999 Answers
SOURCE: Kenmore Microwave Oven model #401.80082700
Sounds like a bearing is tightening up when it get heated up with use. Then after a cool down period it works normally until using it heats it up again. Eric
Posted on Sep 15, 2009
What size glass glass tray will fit my kenmore microwave 565.8904490
Go to www.ebay.com type make and model of microwave oven, refine search to plate, or glass plate.
Jun 12, 2012 | Kenwood Microwave Ovens
Need new glass tray for Kenmore microwave bought in 1977. Model # 99371.
They made Microwaves in 1977? wow. I would try an appliance junkyard, or ebay. We have used a microwave safe plate of the right size and it worked well. Good luck!
Apr 29, 2012 | Kenmore Microwave Ovens
Kenmore microwave oven model 721
On the link below is the list of Kenmore microwave oven model manuals starting with 721.Click on selection to download.
www.managemylife.com/mmh/owner_manuals/search?query=Kenmore+micicrowave%2Fhood+combo+-+7218924680
Hope this helps.Thanks!
Jan 07, 2012 | Microwave Ovens
What is the cu ft, wattage, size, conventional oven yes or no, all the specs ect of the Kenmore mircorwave model #721.80833500
From the factory manual here:
SPECIFICATIONS
Rated Power Consumption ..............1700W maximum (Microwave oven+Cook top lamps+Ventilation fan)
Microwave Output ...........1100W (IEC60705)
Frequency ....2,450 MHz ±50 MHz
Power Supply .................120 VAC, 60 Hz
Rated Current ................14.5 Amp. (Microwave oven+Cook top lamps+Ventilation fan)
Magnetron Cooling .........Forced Air Cooling
Rectification .Rectification Voltage Double Half-Wave
Door Sealing ..................Choke System
Safety Devices ...............Magnetron Thermostat: Open at 145 °C ±5 °C
Close at 60 °C ±5 °C .....................Oven Thermostat: Open at 110 °C ±5 °C
Close at 0 °C ±5 °C ......................Fuse(20A)
Magnetron ......................2M282J (Toshiba)
Cook top Lamp ...............130 V, 35 W (Halogen)
Cavity Lamp ...................130 V, 35 W (Halogen)
Timer ..............................Digital,up to 99 min.(in each cooking stage)
Tray ..............Tempered Safety Glass
Overall Dimensions ........2915/16"(W)x167/16"(H)x153/8"(D)
Oven Cavity Size ...........231/2"(W)x10"(H)x141/2"(D)
Effective Capacity of Oven Cavity ....2.0 Cu.ft.
Accessories ..Owner 's Manual &Cooking Guide, Installation Manual,
Exhaust Adapter, Exhaust Damper, Mounting Kit and Filter,
Rotating Ring Assembly, Glass Tray, Metal Rack, Guide Tray.
Jul 09, 2011 | Kenmore 80809 Microwave Oven
I have a Kenmore microwave model 882252 from 1992 and I am trying to find out the size of the microwave. Any suggestions?
Download an instruction booklet from the manufacturers web site, that should have the details.
Dec 17, 2010 | Kenmore Microwave Ovens
Kenmore microwave model 665.69682992. I am attempting to replace the door on this model. I ordered the new door but find that the hinges are installed in the new door and cannot figure how to get the new...
I am looking to replace my Kenmore model 665.61612100 combination microwave with an updated model of the same size and specifications. Any suggestions???
Sep 08, 2010 | Kenmore 62622 Microwave Oven
I have a 21y/o full sized Kenmore 700w microwave that I want to keep. Worked fine until this morning. Everything works except the heat.
Sadly Kenmore only offers parts for 10 years. The truth is a new microwave for 50 dollars will be much more energy efficient than your 21 yr. old model
Jul 12, 2009 | Microwave Ovens
Need to replace light inside kenmore microwave
Unplug the unit first.
To install the halogen lamp WB08X10050 you will need to take the cover off. You can see a diagram at;
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=36363693302&productCategoryId=0123370&brandId=0583&modelName=MICROWAVE&diagramPageId=00006&componentDescription=INTERIOR%20PARTS%20(2)&documentId=S9060341&backToLink=Return%20to%20Sub%20Components%20list
then click on "view full size"
This will give a view of the parts. Only remove the parts needed to get to the bulb.
Mar 26, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
Microwave Ovens Logo
73 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
