I have a Savin 8020d that just popped up with a SC 500 error that is a functional problem. Any idea how to fix this error? J-Dubb
Bubbabear64
  • 2794 Answers
SOURCE: sc 322 error
Troubleshooting a laser is a lot of work. You're better off getting a tech that can do it safely and correctly. That error code has to do with the motor.
Posted on Aug 21, 2008
Bubbabear64
  • 2794 Answers
SOURCE: RICOH 2015 error code sc 500
Main motor/ transport motor lock/ fusting motor error.
The only thing you can do is check for any obstructions in the machine.
That needs to be looked at by a service because the problem could be a motor, a pcb, or a power supply.
It can be a lot of troubleshooting to do.
Posted on Oct 19, 2008
SOURCE: Error code sc 500
check the developer gear...txt me at 09275514418
Posted on Oct 27, 2008
  • 990 Answers
SOURCE: Functional problem with the copier (Savin 2545) Service Code SC 546
Hello sir; Your machine need to reset, the procedure as follow;
1, press "clear mode", "107", then hold down "clear/stop" key, until screen change message to sp mode.
2, turn power off and back on ,machine will in working condition.
Posted on May 29, 2009
brett207
  • 231 Answers
SOURCE: Functional error SC542
This is a fuser temperature heating error.
the fuser has not heated up within 5 minutes after switching the copier on.
Most likely cause:
Heater lamp blown
Thermal fuse blown
Faulty power supply
Bad connection to fuser unit
You will need a service technician to fix this.
Posted on Dec 08, 2009
Testimonial: "Very quick and helpful reponse. Thanks!"
Error 120 code
To reset the SC code follow these directions:
Resetting Ricoh Savin Lanier Gestetner SC Error Code
Error code 120 is scanner home position sensor problem. If it's a recurring problem, here are some troubleshooting tips:
SOLUTION:
Turn the main switch off and on.
Check the wires between Home Position sensor and the SBU.
Fix scanner board or the SBU .
Check the wires between scanner motor and the scanner I/O board
Fix the scanner motor.
Fix the Home Position sensor.
Fix pulley, timing belt, the scanner wire,
Fix the carriage.
Jun 17, 2014 | Gestetner Office Equipment & Supplies
My SAVIN 2575 is giving error code sc820, any idea what the problem is ?
Unfortunately, I've never seen this error, so I can't give you much help beyond what the code means and the possible solutions that the service manual provides...
SC820:
Self diagnostic error: CPU - Unexpected external error or interrupt occurred.
• Controller board defective
• Software defective
The manual indicates this is a "C" type code, so this should not be displayed on the OP panel, only logged in the SC history in the machine.
Jun 23, 2011 | Savin 2575 Black and White Copier
We have a Savin 2545 copier. We received an error message SC 726. Can you give me some idea what we need to check?
That error is for the shift tray motor in your finisher where the copies come out. The tray should move from side to side when you switch the machine off and on. It sounds as if it is binding for some reason.
Mar 14, 2011 | Savin 2545DP Black and White Copier
Savin 8025 SC-546 error message
you have an over heat error. you need to test your thermistors, s and lamps for continuity.replace bad parts. then you need to go to service mode and reset the code
Jan 28, 2010 | Savin Office Equipment & Supplies
Savin Copier 2020, IP 192.168.2.100 functional error SC672
yes a 672 is an address book error. do you have scanner feature on this machine?. it may be bad. you may need a tech to come remove the option. turn the machine on and use it as a copier. then reinstall the option and see if the error returns. it could be a static build up or the option is bad.
Dec 26, 2009 | Savin Office Equipment & Supplies
Most likely cause:
Heater lamp blown
Thermal fuse blown
Faulty power supply
Dec 07, 2009 | Savin Office Equipment & Supplies
110 people viewed this question
jasbo
jasbo
