Question about Maytag MDE3706 Electric Dryer
I clean the front filter out after every use but the compartment it sits in is hard to clean. The dirt seems to go to the bottom and it is impossible to reach.
    Problem Solver:
  • 5 Answers
A home-made remedy that I have used in the past is to take a paint stir-stick and wrap it with duct tape, the reverse side or sticky side out. Tie a string onto the end of the stick in case you accidentally lose it. Place the sticky stir-stick into the trap and move it about as to collect the dirt on the bottom of the trap. Have fun!
Posted on Feb 05, 2010
Vacuum is spewing dust out of the front vent! We have the Dirt Devil 12 amp bagless upright. Hoses are clear, brushes turn, everything fine except dirt blows OUT instead of going into canister. How
Hi! We actually don't recommend opening the motor compartment. It sounds like there may be a clog somewhere in the vacuum that you are unaware of. Please try following the steps below.
  • Remove the hose from the vacuum from both ends and check it for clogs.
  • Lay your vacuum face down, remove the bottom guard and brush-roll
  • Use a wooden spoon or something similar to help break up and remove any clogs from the lower hose.
  • Check and clean all the filters on the vacuum. If they are really dirty they may need to be replaced.
Hope this helps, if not we can be reached here on Fixya, Facebook.com/dirtdevil or Twitter @DirtDevil
Oct 06, 2014 | Dirt Devil Vacuums
How to open to clean
Hello! The dirt cup, filter and brushes need to be cleaned to ensure continued cleaning effectiveness. Below are steps for cleaning your Hoover Slider.
Turn switch to OFF position.
1. Press button and slide latch towards outside of cleaner. Rotate dirt cup toward back of cleaner.
2. While holding dirt cup, grasp filter frame and lift out filter. Empty dirt cup after every use. Dirt cup can be cleaned with a damp cloth. Allow to dry thoroughly.
3. Pull middle section of filter out of filter frame. To remove debris from filter, tap it on a hard surface or brush it with a soft brush.
4. Remove lint, strings, etc. from the brush roll located on the underneath side of the nozzle.
5. Replace the brush roll when the brushes do not touch the edge of a card as it is moved across the opening on the bottom of the nozzle.
Further disassembly of the cleaner is not recommended. Hope this helps!
F
Aug 13, 2014 | Hoover S2105 Slider Bagless Stick Vacuum
N2000 clean filter
The red guard goes on top of the foam after it is installed. The purpose of the red guard is to keep the bag from sucking down against the filter when you get a few inches of dirt in the bottom of the bag. If it sucks down against the filter the dirt in the bag will cause an airlfow restriction even though the bag is not full.
Jan 25, 2014 | Riccar Vacuums
Carb problems
Needle valve in carb is probably staying open. This overfills carb with fuel so it dumps in into intake. Carb probably has dirt in seat of valve where needle sits. This is common when dirt gets in fuel, such as when you run tank of fuel till its empty and all the dirt living at bottom of tank gets sucked into carbs. Clean all of carb internals, spotless, clean or replace fuel filter.
Dec 12, 2013 | Motorcycles
Hi i have a 2006 dodge diesel that we figure got bad fuel and stopped running.wouldnt start took it in go a new lift pump, fuel filter, lines cleaned and tank cleaned out and its still not running great....
Diesels need to be clean and typically after 10,000 miles removing the fuel filter produces very little in the way of dirt and grit.
You had the tank and lines cleaned out and a new pump and presumably a new filter and still you find dirt and grit in the filter after a short time. ..
Either the tank, etc. wasn't cleaned out or more dirt has entered the tank since, either from more dirty fuel, from dirt ingress into the tank while the car is in use or the third possibility is something is wearing rapidly and the dirt is appearing in the tank to be recirculated after being sent along the fuel return line. If this is what is happening it throws suspicion onto the high pressure pump...
If the high pressure pump is failing it is surprising one or more of the injectors hasn't failed.
If you got dirty fuel the filter should have trapped everything that was likely to damage the injection system until performance reduced and eventually the engine stopped due to fuel starvation. Replacing the fuel filter with a suitable amount of care should then restore performance to the previous level.
Fuel filters are great for trapping dirt but not so good for other liquid contaminants. Water fortunately tends to remain at the bottom of the tank and the bottom of the filter cavity but other things might pass through the filter - acids, salt solution, solvents.
A couple of years ago there was a case of a few petrol filling stations selling fuel contaminated with seawater and shortly afterwards a lot of injectors needed replacing...
I think if my car had the problem your car has I would temporarily fit an inline filter to the fuel return line and drive it for a time. Two things should happen if the dirt is self-generated. The new inline fiter when cut open should show the dirt and grit you usually discover in the main filter and secondly, there should be a reduction in the amount of dirt and grit you find in the main filter, however any dirt at all in the inline fiter means my best advice is to take the car to a good diesel specialist for proper diagnosis and a guaranteed repair.
If dirt is found in the fuel return line there can be no half measures - the business end of the injection system needs surgical-level cleanliness.
May 12, 2017 | Dodge Ram 1500 Cars & Trucks
My washing machine does not spin fully
the problem can sometimes just be a bit of fluff or dirt in the filter it is usally at the front at the bottom of the panel of your machine just give it a clean I know it seems to simple but it will make a difference
Nov 10, 2012 | Washing Machines
My Riccar Upright leave lines of debris when I use it. Can you help?
Inspect the filter.Open the secondary filter on the base of the vacuum to ensure that dirt and debris have not collected on the filter, as this will limit motor performance. Remove the filter from the dust compartment and rinse with water to clean. Allow it to dry completely and return to the dust compartment.--------
Also check if dust bag is got over full and that is causing the problem.Open the dust compartment, take the old dust bag out of the bag holder and discard. Open the end of a new dust bag and attach to the dust bag holder. Close the dust compartment and tighten the dust cover.Also check properly that dust compartment is not got loose. Open cleaning attachment and check the hoses and nozzles on the frequently to ensure that they are free of dirt, obstruction or hair.Also inspect the brushes, if there is already dirt got stuck in the brushes and that is causing the problem.Clean the brushed.---------- This will help, to confirm where the problem is and to resolve the dirt /debris issue.----- Thanks.Helpmech.
Sep 06, 2011 | Vacuums
There is hardly any water flow from the faucet in the refrigerator door. A re light at the top of the refrigerator side sys the water filter is plugged. Where is the filter and how do I clean it? ...
Without knowing the manufacturer and model of your fridge, it will be impossible to tell you exactly.
Some manufacturers have the filter installed on the back side of the fridge, some will have it behind an access panel. Others will have the filter located at the bottom kick panel on the front of the fridge. Others will have it located in the refrigerator compartment, behind an access panel.
If you post the make and model, perhaps I can find the user manual for you, maybe a source for filters as well. Filters are typically replaced, and not cleaned.
Sep 11, 2010 | Kitchen Ranges
Fantom Twister
On my fantom cylone I use a 2 foot wire with small hook. Open bottom and push wire up the vacuum channels. There is also a channel that goes to the brush. Check for suction at hose. If none then your one of your channels going up are blocked. If you have suction at hose but none at floor brush then channel to floor brush is plugged.
Dec 09, 2007 | Fantom Vacums FM741 Twister Bagless...
Maytag MDE3706 Electric Dryer Logo
63 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
