Question about Le Chef Electric Shabbos Hot Water Pot-Free Electric Kettle
I need a replacement pump gasket for le chef AG-490c
I need a replacement pump gasket for AG-490c
The green lights fuse has blown on my Le Chef kettle (keeps want to hot for 24 hours). How can I repair it or where can I take it for repair? Thanks? Dennis
If its a leaking gasket if the heating element is having short circuit or have a measure with the metal exterior is very rare must be only a melting wire, or a bad switch there is also a temp fuse between the element and the power cord.
Aug 08, 2016 | Le Chef Kitchen Appliances - Others
I purchased a PRO Chef electric hot pot a few months ago. I am very happy with the product but unfortunately the pump no longer works. Do you have any idea where I can get a new top piece?
pro chef electric water pot is defective. I bought 2 & both had pumps that stopped working. A friend has the same problem. Best way to fix the problem is not to buy this piece of junk!
Aug 28, 2011 | Le Chef Electric Shabbos Hot Water...
I have a LeChef AG5300 urn. The pump isn't working and is actually jammed inside the lid. I would like to buy a replacement part as the rest of the urn works nicely and is in great condition. I'd...
The replacement parts of Le Chef AG5300 urn not available anywhere right now.
But you can contact with manufacturer web-site and inquire for the parts that you want to replace as per your product's model number. In this web-site, under the Customer Service option you will find their contact number and e-mail address as well. Here is the link " http://www.legourmetchef.com/about-le-gourmet-chef/customer-service-online-order-information/".
Hope this will help you.
Jun 22, 2011 | Le Chef Electric Shabbos Hot Water...
The pump on the top cover does not come up. I have the Le Chef Ag5300 hot water pot. How do I fix this? Thank you!
May 03, 2011 | Le Chef Electric Shabbos Hot Water...
Proform 490C showing error code ssytem cehck
The checksum failure is an indication of a bad console on this model. If the machine is brand new then it still has a warranty. Contact the number on the front of your manual they will replace it for free. Good luck, Tim
Nov 09, 2009 | Polar Exercise & Fitness
Magimix Ice cream maker - Le Glacier - lost instruction book
Magimix 2200 Gelato Chef 1.03 Quart Ice Cream Maker Support Magimix 2200 Gelato Chef 1.03 Quart Ice Cream Maker Support. Manual for ice cream maker ... Need Instructions/User Manual. Magic chef ice maker model MCIM30TW ... fixya.com/support/p519941-magimix_2200_gelato_chef_1_03_quart_ice/rss
best regards mike
Aug 17, 2009 | Magimix 2200 Gelato Chef 1.03 Quart Ice...
Magic chef gas stove has flames coming from the bottom
Replace the burner. Quickly. Do not use that burner until it is replaced.
Apr 23, 2009 | Magic Chef 31000 Gas Kitchen Range
Sunbeam Food Processor/Le Chef 14-11, 14-1A
My mom gave me her Le Chef that had several cracks in the handel and also the place where the handel attaches to the bowel with a screw was broken. I Used Loctite super glue for the crackes in the handel and a loctite epoxy putty that can be molded into the shape needed to fix the place where the screw attaches the handel to the bowel. After the putty set I sanded it to refine its shape and matched the screw hole in the bowel with the handel then drilled a small polit hole in the handel. I slipped the handel into the slot in the bowl and attached it with the screw and now I have a good as new Le Chef.
Jun 23, 2008 | Food Processors
Gasket old
try contacting magic mill in nj
Dec 19, 2007 | Le Chef Electric Shabbos Hot Water...
Kitchen Appliances - Others Logo
71 people viewed this question
Top Le Chef Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Le Chef Kitchen Appliances - Other Expert? Answer questions, earn points and help others
