Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
What does UE mean in the window of my washer - LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
  • 1,543 Answers
UE = Unbalance Error. If you are doing a large item and cannot add, reduce, or adjust the load, try adjusting the spin speed to a low spin speed setting. If the load is still too wet, you can run just a pump and spin by turning on power and then selecting the spin speed, one setting higher than the last one which ran the full cycle through without resulting in the UE code,(without selecting a cycle) and push start.
Posted on Feb 05, 2010
Display come ue and timer not working
Posted on Mar 13, 2010
Keeps Stopping and saying UE
uE error code 79631512210 Kenmore Elite Washer - Sears ...
www.searspartsdirect.com > Ask an Expert
Jan 10, 2014 - uE error code 79631512210 Kenmore Elite Washer ' SearsPartsDirect. ... After unloading the washer completely, the machine attempts to rebalance the .... to ensure proper fit and to keep appliances running for years to come.
UE Error code on my front loading Kenmore washing machine
www.shopyourway.com > Manage My Life > Questions
Jun 13, 2011 - I have a Kenmore 3.5 cu. ft. front loading washing machine (model #4027) and it is 1 year old. ... what does the F35 error code on my kenmore elite front loading washing machine mean? F13 code on Kenmore Elite HE3 front loadingwashing machine.
Jan 21, 2016 | Kenmore Washing Machines
What does code UE mean on my LG washer machine mean
The "UE" Means that your load is unbalanced, try adding something to the load or dispersing the load more evenly.
Jun 04, 2014 | Dryers
What does"ue " mean?
UNBALANCE ERROR - Display shows UE.Laundry load is unbalanced, manually loosen any tangled laundry.
If only one item of clothing needs washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an UE error message will be shown in the display. Unbalance error is cleared by POWER switch OFF and back ON.
Jun 29, 2011 | Samsung WF337AA Front Load Washer
Our LG227HW washer is showing an error code UE, what does this mean and how do we correct it
UE means an unbalance load. Either you have too small a load, too much of a load or you're washing a large bedsheet all by itself. If you are washing a large bed sheet or bed spread, you need to add about 4 bath towels in the load to help offset the balance problem. As for loads, you can only put in 15 lbs of dry weight laundry in the wash. Preferably, fill the tub with clothes half way up the window and no more.
Jun 29, 2011 | Washing Machines
What does UE fault mean? & what do I have to do?
UE means the washer has experienced a severe out of balance condition during the spin cycle, do not overload the washer and if necessary reduce the wash load size, distribute the items in the washer more evenly, this is especially true with heavy items like towels and jeans,.
Feb 05, 2011 | LG WM-1290FHB Front Load Washer
My Lg washer is showing a code UE and then PF what can I do to fix this problem.
UE means that the load is unbalanced in my LG. The code PE means that the water sensor is malfunctioning and needs replacing.
Feb 13, 2010 | LG WM-2277HW Front Load Washer
LG front load washer coded UE. what does that mean?
UE means unbalanced error. when you see this, it means the clothes are unevenly distributed in washer, it's basically unbalanced.
Dec 03, 2009 | LG WM-2077C Front Load Washer
Comes up with the sign UE ??
Hi
Thanks for using FixYa. The error code UE means there are some heavy clothing is loaded. Rearrange items to help balance the load. If the imbalance is heavy, the washer will make several attempts to restart the spin cycle. If an imbalance is still detected, the washer will stop and will display the error code UE. In case, if the load is small then you need to add 2-5 clothes to balance the load. If the load is out of balance then you need to rearrange the clothes to balance it. Although the Washer has an imbalance detection and correction system but if still the problem persists then it means that it is due to control error and needs to replaced preferably by a qualified service technician.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 09, 2009 | LG WM-2277HW Front Load Washer
After a wash cycle, the letters UE appeared in the timer window..
UE = Unbalance error.
try to use a low spin speed with loads like rugs, and try to get as even a load as possible. (ie: not just one rug) Don't wash rubber backed rugs, as the backing can break up and clog your machine.
Now, if you are successful washing with the lowest spin speed, you can hold the " Spin Speed " button in while pressing on the power button. Release power button. Now release the spin speed button. Now, press the spin speed button until the next higher spin speed from your last successful spin. Press start. Your washer should now pump out and attempt to reach the new spin speed, without adding any water. (usually about a 14 minute pump and spin cycle) Don't expect to be able to spin out rugs at a high spin speed.
Jul 05, 2009 | LG WM2487H Front Load Washer
Washer
the error code, UE means that there is an imbalance error. Either the load is too small, the appliance is tilted, laundrey is gathered to one side, or non distributable things have been put into the machine.
Jul 26, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
2,318 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
