Question about HP Pavilion dv4000 Notebook
How to repair the wireles switch from a hp pv 9000 notebook
The wireless switch is unable to turn on, regardles of changing the switch to on or of is stay of
  • fenomeno Feb 21, 2008
    Thank your help, I will look in to this issue.
  • 31 Answers
Check to see if the wireless adapter has been disabled in the device manager. If it has been turned off there it will stay disabled no matter what you do with the switch.
Best way to get there is by:
  1. Right-click on my computer and select Manage
  2. Select Device Manager on the left hand panel
  3. Select the Network Adapters category on the right panel
  4. Look for your wireless adapter in the list. If it is disabled the right-click and enable.
    If you don't have a wireless card listed then you have a bigger issue and will need to get that repaired.
Posted on Feb 21, 2008
WHY DOESN`T MY HP,LAPTOP.CONNECT TO WIRELES TRANSMITER.
Make sure you didn't disturb the wireless card inside the laptop. Check the connections for the wireless card antennas (usually a gray wire and black wire). Also some laptops have a little on and off switch, to turn on and off the wireless. Please make yours is on. I've had a few clients with the same problem and turned out the switch was accidentally turned off. Good luck
Nov 28, 2015 | HP Computers & Internet
How to find wireless switch on dell inspiron 6000 laptop running windows XP
There is no physical wireles switch on your laptop. You should however, be able to hold down the "fn" key at bottom left of the keyboard and then hit the F2 key at top left to turn your wireless on or off. If that does not provide the desired effect, then your wireles adapter may be disabled, in which case you should right click on the wireless icon in the bottom right system tray and choose "Repair" or "Enable".
Best of luck to you.
Aug 27, 2010 | Dell Inspiron 6000 Notebook
Hello. I am Ali. I am from Iran. I have a HP pavilion dv9000 laptop.It had work very well till 2 weeks ago But my wifi doesn't work any more.I changed my OS and I re-installed my drivers and after that I...
I would first try to get into HP wireless assitant which you can do through Control Panel (Start >> Control Panel or Start >> Settings >> Control Panel). In there you can turn your wireless on and off. Be sure to make sure the wireless switch at the front is turned on also. If the light near the wireless switch still remains orange, then you will need to get the motherboard repaired or replaced as this is a known issue. If you still have warranty, HP will repair this free of charge. Otherwise contact a repair company such as www.revivemylaptop.com
Jun 09, 2010 | HP Pavilion dv9000t 17" Notebook Laptop PC...
My brother-in-law has a hp g60 laptop the wireless swich will not stay on. when power up the wireless switch shows orange if you press the switch it will come on blue for two or three seconds and then go...
Before sending the notebook to repair, I would suggest you to reinstall the wireless drivers on the notebook. Also update the BIOS and then check for the issue. You can download the wireless drivers from the HP Software and Drivers website for your notebook model. I am not sure of your exact notebook and hence I am unable to provide you the web links to download the drivers.
However, if the issue persists even after updating the drivers, then the issue is clearly due to wireless card and the notebook needs an onsite diagnosis by a service technician which is not feasible through online. If your notebook is under HP warranty, then I would suggest you to contact HP support and send the notebook to them to get it repaired under warranty for free of cost. Incase, if you wish to take the notebook to any authorized service center then they may charge you for the service as they do not honor the warranty provided by HP.
May 15, 2010 | HP G60-120US Laptop
Can't access internet wireles router says connected hp is a vista
If Nothing else changed in the last 2 weeks, such as a new router, or other hardware changes, AND it just started happening, I suggest you do a "system restore" to a date BEFORE the problem started.
This should correct the problem, and if you did any updates or other software installations, you will need to re install them.
Finally, one option prior to system restoring is to turn off the wireless router (unplug it) and then wait a minute. Plug back in. Then turn on your computer. You can try this first if you haven't already..
Good luck..
Apr 23, 2010 | HP Pavilion dv6000z Notebook
I dont find wireles in laptop
for first time switch the wireless on. There must be wireless led on board. there must be switch or button in keyboard to switch wireles on.
Apr 12, 2010 | Gateway 7330GZ Notebook
Where do i switch on the wireless on my laptop, COMPAQ NV9000
I was unable to find your model notebook, but most are turned via 3 ways:
1: Wireless Switch on the side or front of your pc.
2. You can do so from the control panel under wireless settings. (XP/Vista)
3. HP/Compaq Assistance software installed on your pc. This can be found by clicking on the start menu, and scrolling until you see something like "Compaq Utilities". Use this to configure and start your wireless network.
Goodluck,
C2Solutions
Aug 17, 2009 | Compaq Presario 2100 and 2500 ,NX 9000...
How to turn on the wireles function capabilty
Should be a switch at the front left hand side of the touch pad that you switch. if it's off it should be orange when it's on it will be blue light
Aug 06, 2009 | HP Pavilion dv7-1132nr Notebook PC
I have a hp compaq nx 9000 notebook and am unable to connect to a WPA encrypted network. I'm using the wireless adapter that came with the notebook and it's listed in the device manager as LAN-Express IEEE...
it sounds like somehow the WPA was turned off . Can you reenter your internal router and re-initailize the WPA setting for your laptop, if there a setting for WPA And WEP together ,check that box. Hopefully that does the job.. good luck
Apr 03, 2009 | HP Compaq Business Notebook nx9000
Wireless LAN PCI card
for the tecra 9000 it does have a wireless switch on the side of the laptop or infront.
the only way to test this is by dismantling it and using a tester. (hope you have them).
Apr 11, 2008 | Toshiba Tecra 9000 Notebook
HP Pavilion dv4000 Notebook Logo
307 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
