Question about Kenmore Refrigerators
I have a Kenmore refrigerator 596.71864101 that develops a thin sheet of ice on the bottom of the freezer (which is on the bottom) even after I shut of the water to the ice maker. It seems to be dripping down from the back by the evaporator or something like that. Any clues?
  • gfoster1958 Feb 06, 2010
    This did not help me. There is no drain from the evaporator. The drip tray (part # 12226502) has no drain from it! Apparantly it is overflowing from the tray indicating it might be something else wrong. Maybe the defrost system itself isnt working or what? Too much water must be accumulating in the drip tray and overflowing down into the bottom of the freezer!
    Thank You. Kenmore refig. 596.71864101
  • 454 Answers
You are right about the source of the water. It is coming from the evaporator coils. When the freezer goes into defrost mode, it melts the ice on the coils. The water is supposed to run out of a drain below the bottom of the floor of the freezer. It is common for these drains to freeze shut. If you clear this drain and remove all of the ice from the pan under the floor of your freezer, your problem should go away.
Posted on Feb 06, 2010
I have a maytag bottom freezer refrigerator model# MFF2558VB3 that is forming a sheet of ice on the bottom.
Type in the search engine on your computer Refrigerator Repair-Ice in the freezer- Whirlpool, Maytag, Kenmore
Do that and it should give you your answer.
Jun 19, 2017 | Maytag Refrigerators
My Kenmore Model No 596.69282012 bottom freezer fridge develops a thin sheet of ice on the bottom of the freezer compartment. I have checked the freezer seal and it is intact. Any suggestions?
Is it supposed to be a frost free freezer?
I had one to act like that, but it was on warranty and they repaired it for me.
I wish I could have been able to help.
May 15, 2017 | Kenmore Refrigerators
Why would our Kenmore refrigerator have an ice sheet at the bottom of the freezer and frequently leak water onto the floor?
sounds like a condensation problem due to plugged freezer drain line hole, need to remove bottom plate and have a closer look. if not that then check ur defrost terminator
Sep 06, 2014 | Kenmore Refrigerators
Ice in refrigerator
Usually a blocked drain at the rear just above the bottom shelf. Use a plastic drinking straw to clear the hole. Could just be condensation if you are in and out of the fridge a lot.
Aug 07, 2012 | Frigidaire FRT17B3A Top Freezer...
Water accumilates in the bottom of the freezer in the morning there is a thin sheet of ice on the bottom of the freezer
Here is a tip that will tell you where the water is coming from and how to fix it. The drain hole has froze shut and the water from the defrost will not drain out.
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Aug 20, 2010 | Maytag MFI2266AES Stainless Steel Bottom...
Kenmore bottom freezer refrigerate leaks
Hello, this sounds like you have a blockage in the drain tube, remove panel back of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...If you need any further assistance please feel free to comment again. good luck! P.s Please don't forget to rate my solution thanks! Mike.
Aug 13, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Water weeping out vents in lower back of freezer compartment
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
heatman101
Jun 29, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Freezer compartment ice build-up
too defrost just open the doors for a day with the unit unplugged. as far as why it is frosting up check door seals make sure they are all good and seal it up well and that should take care of it.
Jun 26, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Sheet of ice forms on bottom of freezer
Your defrost heater assembly has probably failed. Look at the ends of the heater for darkness like that of a bad neon bulb. Replace the heater assembly as a unit after removing the ice with a hair dryer. Becareful not to drop the glass heaters when replacing.
Jan 19, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
138 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
