Question about Polaris New Genuine Polaris Snowmobile Accessories / X Treme Sidecut / Out of Bound
Why does 2000 polaris xc 500 blow head light bulbs as soon as i give it throttle. light works while machine is idling but once it is given gas the bulbs blow
  • 44 Answers
IF YOU HAVE A VOLTAGE METER HOOK IT UP TO THE BULB CONNECTOR IF IT GOES BEYOND 12v,YOU HAVE BAD VOLTAGE REGULATOR.
Posted on Feb 08, 2010
I have 1999 polaris 600 xc keeps blowing head lights when rev up changed voltage regulator but still does it any suggestions
Dose the headlight get quite a bit brighter when you rev machine up, if it does it probably is still a regulator issue. You could see about installing a in line resistor if there is not one already or see if you can pick up a heavier bulb.
Feb 02, 2016 | Winter Sports
I have a 02 600 XC edge the temp light come on and off when the light comes on the motor starts to run rough also when you give it acculturate the light comes on
I have a 00 700 XC and my temp light and engine use to do the same thing. I raised the hood once and noticed the temp sender wire had rubbed bare and a cylinder head bolt and was shorting out. Just an idea??? Not sure if it would cause it to run rough though, it seems as if mine did as well a few years back.
Jan 01, 2013 | Polaris New Genuine Polaris Snowmobile...
1999 polaris 500 big boss 6x6 idle good but when giving it throttle is strat to backfire change carb. change fuel pump.
It sounds like you have water in the gas, drain all the gas out in a glass container and let it sit overnight if there is water then you will see it next morning. Be sure to sit inside or at least cover so no other moisture can enter
Dec 23, 2012 | Polaris ATV
I have a sportsmen 500 2000 it runs and idles good up to about half throttle and then sputters and starts smoking any ideas where to start at
CLEAN CARB AGAIN THIS TIME SHAKE THE FLOAT TO SEE IF IT HAS GAS IN IT, IF IT DOES THE FLOAT IS BAD, TAKE YOUR TIME CLEANING THE CARB AND USE COMPRESSED AIR TO BLOW OUT THE ALL THE SMALL PASSAGES USE A TORCH CLEANER KIT TO CLEAR ALL OF THE JETS !
JAY THE POOL PUMP MOTOR REPAIR GUY LONGWOOD FLORIDA
Sep 11, 2012 | Polaris ATV
1999 500 xc head light goes out every once and a wile but comes back on for no apparent reason
THIS IS USUALLY CAUSED BY THE VOLTAGE REGULATOR OR BAD CONNECTION IN THE WIRRING SYSTEM
Dec 23, 2010 | Polaris New Genuine Polaris Snowmobile...
Predator 500 batery wont stay charged
volts dont make things work it is the amps your battery is going dead the battery need to be replaced
Jul 20, 2009 | Polaris ATV
Dieing out
have 04 polaris predator 500 doing the same thing, when giving full throttle it seems to be hitting a limiter a couple of 1000 rpm below full rpm, but will only start with air box disconnected from carby and spitting gas out, might be buggered T.P.S unit have bought new Keihin Flat CR carby with T.P.S on it so to replace one on thumb throttle as it has taken some knocks ( should be able to test T.P.S with volt meter when pushing the throttle), a cdi unit and coil will see how that goes.
Jun 01, 2009 | Polaris ATV
Brake Light Fuse & Gas Gauge
Start by replacing your brake light bulbs. If it still blows the fuse, them your brake pedal switch. If it still happens then you have a shot circuit in your wiring between your fuse panel and your brake lights.
Jul 10, 2008 | 2000 Mercedes-Benz SL-Class
Polaris New Genuine Polaris Snowmobile Accessories / X Treme Sidecut / Out of Bound Logo
923 people viewed this question
Top Polaris Winter Sports Experts
Larry Fostano
Larry Fostano
toddgilbert
toddgilbert
Are you a Polaris Winter Sport Expert? Answer questions, earn points and help others
