Question about Truly MP313X 1 GB MP3 Player
Truly MP3 13X only showing blue backlight
Had this TRULY MP3 13X player about 18 months - working fine till 3 days ago. Played okay in the morning, but 2 hours later when I turned it back on it just showed dark blue backlight, did nothing else.
MP3 was showing almost full charge that morning. Has been dropped from hand MAYBE 3 times - early 2007. Last connected to my PC probably after Tgiving 2007 - worked fine till this week.
Please advise soonest? Thank you
  • harleyd_2004 Dec 10, 2008
    I have the same problem.  I've only had mine for about two weeks though before the blue back light problem.  I've tried resetting it and turning it on and off, and the only thing that displays is a mostly blue screen with some blackened edges.
Same here, you just have to keep messin' with (pluging it into computer, etc.). I know it sounds strange but that's how I deal w/mine. It eventually comes back to life.
Posted on Apr 30, 2010
Truly fc606 video converter download
Truly can advise whether a video converter program is available.
May 24, 2014 | Truly FC-606 1GB MP3 Player - Blue Intenal...
I have a whirlpool built in oven. Model RBD275PDQ8. The display (control panel) went blank 2 months ago. I reset the breaker, nothing. Pushed buttons, it just beeps. 3 days later I pushed the upper oven...
it's the control panel behind that touchpad item. and it's not too difficult, just time consuming. My recommend is to grab a service manual online(usually around 20.00) which will provide good step by step,and also parts list.
spares? well, that's a good question. Until you have that part number, and the best way is to eyeball the one that's in side your unit(no offense to the printers, but mistakes can happen with manuals).
then you'll find out what it's like to be truly handy, eh?
May 31, 2008 | Whirlpool Kitchen Ranges
Tip
Truly/Accuread DB61M Blood Pressure Monitor - how to set date and time
I found how to set the date and time on my Truly DB61M blood pressure monitor by trial and error. I suspect other Truly BP monitors do it a similar way. These monitors also seem to go under the name Accuread. It's a pity they don't make manuals readily available online.
Here's how you do it:
1. Put the monitor into the date/time setting mode by holding down the MEMO and AVG buttons together for several seconds, then release.
2. The YEAR will be displayed flashing at the top right of the display. Press the PAGE button to move through the years to the one you want.
3. Press the AVG key to move to the next field, which is the month, flashing on the left. As with the year, used the PAGE button to move through the months to the one you want.
4. Following the same procedure, set the day of the month, the hours and minutes. The monitor knows how many days are in each month, so you can't set eg 31 February.
5. To finish, press the START button (the one on the right with the red marking).
There seem to be some other settings as well as the date/time that come up if you keep pressing the AVG button, but I don't know what they are.
on Feb 13, 2014 | Truly Health & Beauty
All of a sudden it will not turn on....nothing...when plugged into the usb...it say fully charged....but if you disconnect..and try to turn it on.....nothing happens..
If you can turn your player on while being plugged to your PC/Laptop or USB charger, then your internal Lion battery is most likely gone past its useful life (some 500 charges or 18 months usage) and may need replacing. Most MP3 player may show 'fully charged' when plugged in either when the battery is truly fully charge or defective battery is no longer taking a charge: e.g. minimum or no current flow situation.
Dec 20, 2009 | RCA M4204 MP3 Player
Pioneer DBP-51FD Blu-Ray
I bought mine four days ago and it would not pay the new James Bond Blue-Ray. The screen said your player needs an update. I downloaded the firmware, and it still did not work. I took the disc down to Best Buy and it played fine on an identical DBP 51-FD. Their tech came out with a replacement player and it played fine. Now, however, it will not play the DVD Happily Ever After 2, eve after the firmware update. Strangely enough, the other player played that DVD fine.
In other words, take it back and get another one.
Apr 10, 2009 | Pioneer BDP-51FD Blu-Ray Player
Cd player showing error 43
Still under warranty?... check that.
Mar 24, 2009 | 2008 Hyundai Elantra
Getting hot when connected to charger and wont work
well if you just got it cause i am not good with i pods but if you did just get it not to long ago you could go to the store and they will type in the serial number in and see if your warranty is still good or what ever it is and they might just give you a new one
Feb 21, 2009 | Apple iPod MA446LL/A MP3 Player
My stiletto records for about 18 minutes then stops
Daylight savings time change a few months ago messed up the timer recording schedule - you must now fix it. Daylight savings time changes will always mess up this recorder. You must reset your recording schedule.
For more info on fixing, go to:
http://shop.sirius.com/edealinv/servlet/ExecMacro?nurl=control/StoreItem.vm&ctl_nbr=2640&siId=1745656&catParentID=7874&scId=7874&oldParentID=&cid=SL100PK1
2 other remote possibilities:
If no signal is present at the time the recording is scheduled to start, the recording will be skipped.
Make sure you have followed all instructions on pp. 55-58
-Tha Mp3 Doctor
Jun 03, 2008 | Sirius STILETTO 100 MP3 Player
Cant connect to pc, player problem
1. unplug and clean mp3 port with fine small brush or can of compressed air. My mp3 had blue oxidation residue at both ports. Odd eh? 2. unplug and recharge for longer, battery might be low. 3. just unplug and replug 1,000 times, then never unplug till problem fixed by the repair site. 4. Call Philips and tell customer service that it was a great marketing idea but it truly is a cheap peice of shit. Your going to buy a Zune now. I wanted to send mine in for a new one and they said 150.00$$ OK, like I'm gonna do that when a decent Zune is around 200.00
Dec 05, 2007 | Philips GoGear HDD6330 MP3 Player
Truly MP313X 1 GB MP3 Player Logo
109 people viewed this question
Top Truly Audio Players & Recorders Experts
 Grubhead
Grubhead
ray gallant
 steve
steve
Are you a Truly Audio Player and Recorder Expert? Answer questions, earn points and help others
