Question about Kicker KX200.4 Car Audio Amplifier
Hello. My Kicker kx200.4 is acting funny. The red display light on front/top of the amp is turning on for a second and then turning off, repeatedly. The light on the side (power) is also turning on, red for a second then green for a second, then off, also repeatedly. I'm trying to push two twelves(wired regularly, not bridged) with it and I've got it wired exacly the way they said to wire it in the 2 channel mono mode in the owner's manual. Any help would be dearly appreciated.
  • michael whitman May 11, 2010
    Hi what ohm are the two 12" subs? and how many coils do they have?
  • 24 Answers
The amp is a 200 Watt by 4 im guessing and its doing that because its going into protection mode unhook the subs if it stops then 1 you have a bad sub or 2 the subs are too much for the amp if an amp is rated 200w per chanel its 200 max about 75 rms or 75 normal constant power
Posted on Feb 06, 2010
Kicker amp powers no audio all connections made properly
Is this the first time installing it or have you had it a while and it suddenly stopped playing ?
Aug 07, 2011 | Kicker Car Audio & Video
I have a kicker 500.2 red protection light is on and red light on top of amp flashes every couple seconds. Have checked all connections and other amp in truck works good. I bought two of these amps and...
Disconnect all the wires except the three main power wires, ground, 12v battery and remote. Now, turn on your radio, if the protect light is still on then there's an internal short in the amp. If the light turns green, then there's a short in either the auxiliary cables or the speaker outs. If it turns green, then troubleshoot the other wires that plug into the amp by connecting them one at a time until the protect light comes on, which will tell you that there's a problem with that speaker/aux wire.
Jul 25, 2011 | Kicker KX500.2 Car Audio Amplifier
Have issues with trailer lights. Both turn signals on trailer flash when I use left or right turn signal. Have 7 pin factory plug. Lights on trailer work fine, hooked up to 97 Silverado. Act funny on 2000...
Standard wiring colors are as follows:
4-Way
5-Way
6-Way
7-Way
Green
Yellow
Brown
White
Red
Blue
Purple
Right Turn & Brake
Left Turn & Brake
Tail Lights
Ground
Backup Lights
Electric Brakes
Auxiliary Power
Green- Right Turn and Brake
Yellow- Left Turn and Brake
Brown- Tail Lights
White- Ground
Red- Reverse (Back Up) Lights
Blue- Electric Brakes
Purple- Auxiliary Power
It sounds like your green and yello wires are shorted together somewhere along the length of the harness. I would check the wires on the trailer first. Easier yet, if you have another trailer to connec or access to another to use for testing, connect to it and see if the problem repeats; if it does the trouble is in the vehicle's wiring.
Jun 26, 2011 | 2001 GMC Jimmy
Kicker impulse 254 amp red light on top?
1st check all of your wiring, make sure the remote wire is hooked up, check to see it the RCA's are hooked up. I know this sounds stupid, but i've done it a thousand times, check to see if you hooked up the speakers. If you checked all of those and still nothing, double check your ground. Make sure where you have it grounded, you have all the paint sanded away and its a good grounding point. The red light on the top of the amp, its not a protection light is it??
Apr 03, 2010 | Car Audio & Video
Amp Power LED Display blinks red and no sound
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. Does the voltage on either the B+ or remote pulse below ~11 volts when the LED flashes?
Jan 26, 2008 | Kicker ZX650.4 Multi-Channel Amp - 480W ZX...
Kicker KX200.4 Car Audio Amplifier Logo
203 people viewed this question
Top Kicker Car Audio & Video Experts
Professor_V
Professor_V
Tygh Duval
Tygh Duval
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
