Question about Miele Optima G2470SCVi Built-in Dishwasher
My miele dishwasher MOdel G2470SCVI is not draining.
  • Anonymous Mar 30, 2014
    smells like a dead fish when i open it after a cycle is completed
I went on line and looked up the use and mcare and maintanence info.
Posted on Feb 06, 2010
Intake/drain light on
Please check the INLET water pressure, remove the inlet and check. Now if there is pressure make sure that when the power is pressed there is a pre wash cycle to start the machine. If not there is fault in the program controller , please check the door switch and the panel board.
Jan 02, 2013 | Miele Optima G2470SCVi Built-in Dishwasher
For Miele Dishwasher G2470SCVI Need help with remaining water in the bottom. Model# G2470 SCV1 SF Type-HG03. Runs through the entire cycle,long,short ect..everything is clean and dishes look great but
see this causes and fix it. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Drain Hose If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Sep 28, 2012 | Dishwashers
Not drying at end of cleaning cycle
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Apr 18, 2011 | Miele Optima G2470SCVi Built-in Dishwasher
On normal rinse aid the dishes do not dry
heatman101
Apr 16, 2011 | Miele Optima G2470SCVi Built-in Dishwasher
My dishwasher door is falling open. I have to latch it to keep it closed
The spring cables that hold the door have broken so the springs have no effect....
They are not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Jan 11, 2011 | Miele Optima G2470SCVi Built-in Dishwasher
Miele 2470 does not rinse properly. The motor seems to be stuck because it makes a buzzing noise
Hi dear.According to what you're saying,there is a problem with wash pump.Please do this before take any action, remove the filter & check for any obstacles.if there is any clean it & run the machine for test.If this did not work then there is a little capacitor on the main wash pump.That's causing the problem & needs to be chage.If you can do it,try to replace the capacitor "?uF"same as the original type.It should work perfectly.I hope that helps.Thanks.
Aug 29, 2010 | Miele Optima G2470SCVi Built-in Dishwasher
I have an Miele Optima Series HG03 dishwasher. The dishwasher stops after a minute and the intkae/drain error flashes. I tried everything in the manaual but there is nothing blocking the drain or intake...
hi,
try checking the spigot under the sink as quite often the hole has not been opened up enough and there is a shoulder for food to jam up against causing a blockage. Remove the drain hose and have a look in the hole of the u bend.
If ok remove the filter in the base of the unit and remove the non return valve and make sure the drain pump can turn and there is not anything blocking it.
Dec 28, 2009 | Miele Optima G2470SCVi Built-in Dishwasher
Miele Optima G2470SCVi Built-in Dishwasher Logo
503 people viewed this question
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
