Question about BBQ Guys Grilling
Full tank but no gas to ignition ...used the tank an another bbq and it works fine...in fact i used 2 different tanks....had the problem a year ago but it went away....i dont have gas even for the side element which is cleaner than the others....i cant even hear gas or smell it so there is a blockage somehwnere but not sure i shoul dbe tinkering with it?
  • 80 Answers
The new BBQ tanks need to be opened very slowly or they trip out.check regulator
Posted on Feb 06, 2010
Iinstalled new propane tank to gas bbq grill and smell gas?
to undo the tank its a left hand thread re connect tank turn on valve on top of tank slowly make up some washing up liquied with some water and make bubbles and brush this on the gas joints this will show if you have a gas leak .
Jul 26, 2012 | Weber Grilling
I used our bbq a couple days ago and it was fine, now I am not getting a flame to any part of the bbq. Tried different tanks, still nothing. Do you have any ideas as to what it might be?
Betty, to solve this problem, do the following:
1. Turn the gas tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the tank valve is fully open, light the burner farthest from the tank first and set the burner
control knob on HIGH. Does the flame height look correct for being set on HIGH? If so, light
the remaining burners the same way. Do all the burner flames look correct? If so, you solved
the problem. Remember, to always open the tank valve Very, Very Slowly.
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. It runs about $30.00 at any home center or hardware store that sells grills & accessories. If you replace it, turn the tank valve ON Very, Very Slowly.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling.
Jul 09, 2011 | Uniflame FG2204C Grill
Hi, I have just bought a Weber 100 BBQ. I have a
You have a couple of questions. In order: 1. Flame may not be visible because it burns very clean. 2. When they say 'turn gas off', they actually mean 'turn gas tank off'. 3. It's not necessary to remove the tank after every use. Just make sure the gas valve is off and the entire grill and tank are covered. I do remove the tank, and store it in an outdoor shed during the winter.
May 18, 2010 | Grilling
New bbq won't light
try turning the gas down a little while you use a match?
Aug 07, 2017 | Grilling
Gas Grill
The "safety" inside the gas tank has tripped. Close the valve on the tank, remove the hose from the tank, reconnect the hose and SLOWLY open the valve on the tank. This should reset the safety.
SG
Apr 06, 2009 | Grilling
No gas getting to bbq
I switched to the new style 20# tank with the new turn-on knob.  I couldn't get enough gas pressure to the BBQ burners for all three burners to light or to keep a strong flame on even one burner.  The new style tanks have a safety valve on the inside of the tank that shuts the gas off if you turn the knob on too fast because the safety valve thinks there is leak.  Shut everything off and then try turning the knob on real slow, especially at first, before turning it all the way on.  If that doesn't work (it didn't for me), then replace the large plastic connection valve knob (female end) that attaches the regulator to the tank.  Mine was for the old style tank and was black (low pressure).  I went to a propane company and had them replace it with a green knob (higher pressure).  Took it home and WALA!  Everything works fine now.  But it was very frustrating trying to figure why I couldn't get any gas to the burners after buying a brand new tank.  I hope this helps solve your problems.
Sep 15, 2008 | BBQ Guys BBQ400C/G42 Grill
No gas flow
sounds like the best option you can not fix them
Aug 02, 2008 | Jenn-Air JLG7130A
Grilling Logo
140 people viewed this question
Top BBQ Guys Grilling Experts
John Rodgers
John Rodgers
Andrew Taylor
Andrew Taylor
Howie Snyder
Howie Snyder
Are you a BBQ Guys Grilling Expert? Answer questions, earn points and help others
