Question about Nintendo DS Lite Console
I have replaced the case on my Nitendo ds lite, but now the upper screen shows everything up side down but only when a game is started.
  • 644 Answers
Check the cable is securly in the the socket as far as it will go, if it is not correctly you will have this sort of problem.
Posted on Feb 17, 2010
My Nitendo DS lite does not charge, the orange light does not turne ON when I plug the charger. I measured the voltage on the contactes of the DS lite when the charger is plug in and without batterie and...
Well the charger shouldn't be showing voltage if it's not plugged into the ds as the circuits not complete. And if you only recently dropped it in water, take the battery out and make sure there's no games in it and let it dry out for a few days. Also, make sure the cover for the gameboy game slot is off. Hope that helped!
May 08, 2011 | Nintendo DS Lite Console
I replaced the top lcd screen on my son's Nitendo DS lite and now when I turn it on the bottom screen flashes and shuts off. What is wrong with it?
Hello!
The bottom screen flashes because something is still wrong with the upper lcd
Make sure you didnt put a rip in the upper lcd. The smallest rip will mess it up.
Also, make sure the cable is in completely.. If its off the slightest cm , it'll cause the lower lcd to blink which causes the DSlite to not work
Dec 29, 2009 | Nintendo DS Lite Console
My nitendo ds has water damage and i am not able to see the top screen but the battery works fine what should i do
try replacing the top screen, if that does not work, part of the mother board is damaged, not much more you could do, but replacement.
Nov 29, 2009 | Nintendo DS Lite Console
When i turn on my DS the top screen is blank then it turns white and stays like that, i don;t know what's wrong
If your booting to a GBA game, there us a setting in the machine BIOS to tells it to use the top or bottom screen. You can access it by taking out the games and booting the unit.
If your booting a DS game, it should display on both. If not, it is possible a wire has come loose on the display (or the screen went bad).
You can try and check for the wire yourself or take it to a repair shop. If you bought it recently call Nintendo.
Nov 01, 2009 | Nintendo DS Lite Console
Broken bottom screen
Some of the screws are hidden.
-2 under rubber feet (bottom of console) - just prise the feet off - they just stick back on when refitting.
-1 screw (when the console is upside down) is in the middle of the cartride entry point - small black tri-wing screw.
Failing that check out YouTube - there are lots of videos showing how to take the case apart and put it back together again.
Sep 03, 2008 | Nintendo DS Lite Console
Purchasing Games for Nitendo DS - Machine purchased from NZ
name
address
credit card information
shipping address
possibly email address
Jul 26, 2008 | Video Game Consoles & Games
Nintendo DS lite
Baakie,
You turn de DS Lite on, the green light flashes and the unit turned of. Is that correct?
The DS Lite checks some things before he starts-up. One of these things are the screens. the DS sends a signal to it and expect an answer back. When this answer is not received, it shuts down.
The most common problem in these cases is the flatcable of the upper screen.
Question is, did you replaced the housing? If so, you might dammaged the flatcable of the upper screen. If not, the flatcable might be defective because of using the DS Lite a lot (open /close the unit).
So first check the flatcable of the upper screen (google and you will find manuals how to open the DS Lite but be carefull!!!!)
Second, on the mainboard are two fuses (F1 and F2) . Check these! One of them might be defective
Success
Jul 19, 2008 | Nintendo DS Lite Console
Nintendo DS Lite Game
try to not play the game for a WHILE. then the system will calm down if you had a nitendo for more that one month
Jun 19, 2008 | Nintendo DS Lite Console
Nintendo ds to screen broken
Hi, replacing the original nds upper screen is a fairly straight forward procedure, you need to remove the 4 x small plastic plugs located in the corners of upper screen, then remove the 4 x phillips screws, the top outer back part of the case will seperate and you can gain access to the screen. Firstly remove the small screw holding down the right hand pcboard to gain access to the ribbon connectors, release the larger flat connector by hinging the clip up, slide the ribbon out, underneath you will see a tiny connector, gently ease the small clip back towards the ribbon, prising a little each side at a time, remove the ribbon and then you can prise the screen from the case.
These guys sell the replacement screens www.ps2laser.co.uk prices are very competitive and offer next day delivery!
Nov 08, 2007 | Nintendo DS Console
Nintendo DS Lite Console Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
