Question about Danby DCR34 Compact Refrigerator
Pressed a button, now fridge won't work
I have a very old mini brown Danby Ignis fridge. I'm not sure where it came from or how old but as I was putting groceries in, I accidentally pressed this button in the center of the low, medium, high knob. (assuming it's the temperature knob??) As soon as I pressed it, the fridge stopped running. The button stuck and won't pop back out. The light still works. Please help!!! This is my only fridge. Thanks!
  • Ajudge Dec 14, 2008
    I have the same problem with my refrigerator. I hit that stupid red button by accident that is in the middle of the temperature knob and now my refrigerator is not working...(the light is on but it isn't cooling). Wondering if defrosting is the only way to get the darn thing to work?
  • 958 Answers
You have pressed the defrost button that is why the compressor stops and would not come back on. there could be a temperature sensor on the thermostat or a timer where in it would only reset back after the temperature of the fridge warms up. try to remove all the food and let is sit for a while, plugged and watch if the compressor would kick in after about two hours or untill the fridge warms up. if the button is stuck, you may have to spray lubricant in the thermostat or replace the thermostat .
Posted on Feb 21, 2008
    New Friend:
I pressed the red defrost button as well and while I was Unloading all of my food I turned the dial all the way left (counter clockwise) to the "0" on my dial (the one with JUST the dark and light blue gradient, no numbers) and then turned it back on and it started up again!!
Posted on Nov 12, 2014
Please help my fridge isnt working but the freezer is what has happened all my food is going to waste
Posted on Jun 24, 2012
I can't get a regular temperature in my old brown Danby Inglis frig . It is freezing every item in the frig even at the lowest ajustement. Can you help me?
Most likely temperature control thermostat needs replacing. Also check damper between fridge and freezer. If mechanical, adjust where less air is going in fridge section. If not mechanical, but electric, damper door may not be closing.
Sep 23, 2017 | Danby Refrigerators
What is the red push button for in the middle of the temperature control on danby mini fridge
If you go here
https://www.danby.com/support/#product-manuals
select compact fridges, and then your model, you can read the user manual for it.
Oct 01, 2016 | Danby Refrigerators
Fridgidaire Mini Fridge not cooling
pulled off back panel on inside of freezer, to find it was a solid block of ice. thawed, and plugged back in... working properly
Feb 08, 2010 | Electrolux Refrigerators
I had my Danby premier mini fridge stored in sthe garage for a while and just plugged it in. Nothing....., no sound, nothing...anything special I should look for?? Appreciate your help.
turn the temperature nob all the way to full then all the way to minimum. (the red button you press to defrost the fridge probably needs to be reset...)
Aug 20, 2009 | Danby Refrigerators
Fridge Wont Turn On
the button is a defrost button
Nov 29, 2008 | Danby DCR34 Compact Refrigerator
Danby Ignis Refrigerator light isn't working
See this link and scroll down to see information about parts for a Danby refrigerator:
http://www.rekitchen.com/refrigerator/brands/danby.html
Nov 19, 2008 | Danby DCR34 Compact Refrigerator
Countertop kenmore microwave, large, brown, old...whar is model number...I need to manual
Sorry, but you can't get a manual without the model number. You can find help locating your model number here.
If the manual doesn't address how to change the bulb, or you don't see an obvious bulb cover, then you'll have to remove the outer cover.
Be sure to unplug the oven first.
The screws you need to remove should be pretty obvious, and a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 03, 2008 | Microwave Ovens
Danby DCR34 Compact Refrigerator Logo
6,690 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
jason
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
