Question about Siemens Washing Machines
SIEMENS XLM1400 WASHING MACHINE DOES NOT SPIN AFTER WASHING A CTTON MAT WHICH LEFT LOTS OF FLUFF IN DRUM. DID NOT DRAIN PROPERLY EITHER. DRUM CEASED AND CANNOT BE ROTATED BY HAND
Siemens xlm 1400 washing machine fills with water but wont wash
Posted on Jun 04, 2010
My washer will not drain or spin we just had a
hi it will not spin with water in it.have you tried opening the fluff filter ,usually located at the bottom left or right of the machine.once that is clear put the machine on spin or drain to see if the pump is running.if all this is fine check your plumbing is not blocked where the machine empties its water
Jun 25, 2013 | Frigidaire Washing Machines
Won't drain but the filter is not blocked
can you tell me the make and model then i can help
Dec 02, 2012 | Washing Machines
Siemens s.16.38 washing machine doesn't always spin so clothes come out soggy
The washing machine picks up on wait and will only spin if there is enough weight. Make sure that the washing machine drum has enough weight in it so that it can spin properly.- This what a Siemens washing machine engineer told me as I had the same problem.
May 04, 2011 | Washing Machines
Wasing machine fills with water during washing and wont pump out filling the drum...
1. Empty the drum via the filter / trap at the front (there is sometimes a drain pipe near the filter - otherwise be prepared to use lots of towels to soak up the water).
2. Check / clean the filter.
3. Ensure that the drainage pipe is not blocked.
4. Check that the pipe from the pump to the waste water pipe is not kinked / blocked.
5. Check that the pipe from the drum to the pump is not blocked.
6. Does the pump sound like it's trying to work? If not, it could be that the pump is dead. Pumps can often become blocked with fluff / slime from the machine.
Jan 13, 2011 | Bosch Washing Machines
THE PUMP HAS GONE
You may find the fluff filter is just blocked which protects the drain pump or something is jamming the drain pump from turning. On front loader machines the fluff filter service panel is found on the front panel at the bottom on the left or right hand side.Hope this helps.
Jan 19, 2010 | Samsung Washing Machines
Bosch wfd2473 washing machine wont drain or spin
I have a bosch wfd 2473 washing machine...wont drain,I have had this problem before and resolved it by removing drain/filter plug...normally a button or hair clip....but this time there are no objects blocking.I am guessing the drain pump is faulty and needs replacing...?????
Apr 05, 2009 | Bosch WFL 2063 Front Load Washer
Got lots of fluff under the drum
You will find the filter at the rear of washer..
Remove rear lower panel, on right you will see a large black hose that goes to the bottom of drum,
Undo clip that secures hose, and remove hose, be careful as there will be some water run out.
Remove plastic filter and ball inside hose, and clean filter, replace and fit hose back onto tub, making sure it is on properly.
Test for leaks before you refit rear panel back on.
You may have to repeat the process more than once if there is a lot of fluff present.
Plz rate my solution.
Thanks
Jan 08, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Washing not being spun properly or machine emptying fully
If it has a filter, remove and clean, check for blockage and or obstuction in drain hose
Dec 12, 2008 | Tricity Bendix AW1400W Front Load Washer
Can't get washer to finish spin cycle
I'm not familiar with this washer, but if there is water in the drum when it comes to the spin cycle chances are that it won't spin. The likely cause of water left in the drum would be that it is not emptying fast enough, so you might check the pump for a blockage, or if there is a filter check that for some obstruction like fluff, coins, or small items of clothing which can sometimes get drawn through from the drum. Tom.
Mar 09, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
2,072 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
