Question about HP LaserJet 3055 All-In-One Printer
CAN NOT GET THE FEEDER ON TOP BACK IN - HP LaserJet 3055 All-In-One Printer
  • 163 Answers
See your instructions manual.
Hope this helps!
Posted on Feb 05, 2010
How do i get the feeder to stay up in the feed position. After it comes up it beeps and goes back down to the load position
The motor control board handle few sensor within the feeder. Check the cable telephone for proper connection. And at the very top of the feeder there is a sensor and one on the feeder itself at the bottom. If those sensor are good the problem could be the motor control board.
Jun 20, 2014 | Xante Ilumina Digital Color Press Printer
How to set document feeder on top to work?
Sir/Mam,
Recommend that you have the technician come back out and reseat all the connectors he removed when in stalling the new circuit board. One connector mite not be seated properly or a connector pin was bent!!!
Feb 07, 2014 | Konica Minolta Bizhub C253 With Document...
What does close the feeder tray mean
The Canon PIXMA iP4000 InkJet Printer has two paper sources for printing. Likely the top feeder tray is not completely closed (it is possible you do not have the printer set up to feed from both which may cause the error).
See the Quick Start Guide and the Picture Below:
Mar 06, 2013 | Canon PIXMA iP4000 InkJet Photo Printer
Giving error place doc.feeder in the down position
problem with the feeder sensor >>top at the arrow
May 07, 2011 | Toshiba estudio 305 Copier
Canon MP730 Paper feed is not working correctly.....keeps jamming and feeds the paper incorrectly
There are two feeders on this MP730. There is the sheet feeder on top and there is the paper feeder on the back. You can have problems with both.
The sheet feeder on top.
If the problem is things go through somewhat sideways, and if this is the problem, stuff some postit notes between the back grey thing and the feeder tray to eliminate this problem. Add or subtract to the wad to make it right.
If the problem is it does not grip the sheet, what I used to do is to help it through by one sheet at a time, painful. I got frustrated with this so for scanning, I have a Snap Scan 1500, which is faster and better.
The paper feeder.
A small piece of paper left in the paper infeed path can cause a major problem. You cannot have anything in the paper path that will skew the paper, so you must get any little bit of restriction out of there.
As the printer gets older, you will have to produce your own guides to prevent this skewing, as the guides on the printer do not do this well. I use clamps and wooden guides to keep things in line.
May 25, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
I'm getting drum error message, it says move blue tab back and forth, I don't what the drum is and I don't see blue tabs
Open your document feeder cover (it pivots away from you), then open the forward top cover (it pivots towards you). Inside the machine is the drum / toner unit, remove it. On top of this assembly is the blue tab (plastic handle) either on the left or right side. Slide that tab back and forth ~ 4 or 5 times. Reinstall the drum / toner unit. Close the top cover, then the document feeder cover. Done...
Dec 18, 2009 | Brother IntelliFax-2820 Laser Fax
The automatic-feeder does not work. Everytime I
There is a small power cable that connects the main printer to the sheetfeeder. It is loose or unplugged.
Look on the back side of the Automatic Feeder, near the top.
Plug it in ... it will work.
Nov 13, 2009 | HP Officejet 7210 All-In-One InkJet...
Documnet feeder jam
Check input paper feeder at top too - easy to miss. Top flips open with a firm (but not excessive) pull, so you can look there.
If you are sure you've opened and looked under every available panel on the printer (there are many!), turn it off and unplug for half a minute. Make sure all panels are back properly in place, but leave out the paper tray (and no paper either in the rear input paper feeder).
Plug in and turn on. Wait for it to finish its start-up sequence - it should complain about no paper.
Check the paper is flat and straight in the paper tray, and no excess room between paper and guides, and put it in again.
Print test page.
How is it now?
Sep 15, 2009 | HP LaserJet 3055 All-In-One Printer
Spring from printer
it goes behind the paper feeder at the bottom you have to take out the piece of plastic that has the light grey slider on it which is fixed in place at the top you'll have to be quite firm when trying to prize the round lugs out of there holes located at either end at the top of the dark grey plastic paper feeder guide the one with lots of thin vertical lines on it top left. once out look at the back and you will see a circle with the same diameter as the spring then look inside near the bottom of the rear of the paper feeder and you will see something similar. its very tricky trying to locate the spring back into position i placed the spring into the hole on the piece i removed and then squashed it down using a metal ruler and then slid it back into position. you will know if it went back properly by putting your hand inside and pushing back against the feeder with your finger nails it should spring back and forth.
Aug 31, 2009 | Epson Stylus Photo RX620 All-In-One InkJet...
Paper Jam in Bowels Of Canon ImageClass D760. Also need to replace Rollers where paper exits Copier. I have the parts-how do I get to it
It needs a new fixing unit. If you are careful and have a long skinney screw driver you could do this. Open the right side door. Remove the small screw in front this secures the control panel.
Shift panel to the left and remove the ribbon cable. Put right top door down. Shift top feeder back to the right. remove all the screws on the left side and remove the plastic. There is a top piece held by one screw in the middle. One on the left and two hold the bottom plate on. Remove this plastic. Now the dangerous part. Remove the two screw on top of the the machine that hold the two white guide pins. Now you are going to rock the top feeder up and to the back. Before you do this you need to know there is a plastic finger that comes up out of the copier and is part of the main drive gear pack. IF YOU BREAK THIS you can just throw your machine away in the trash. SLOWly look under the top *** you rock it back. You want to shift the feeder unit left or right to get clearnace of the white 90 degree angle finger that is in a grove of the feeder. Clear it and rock the feeder back resting on the rear of the copier. DO THIS CLOSE TO A WALL. SO WHEN YOU ROCK BACK THE SIDE CAN SIT ON THE BACK OF THE COPIER. There are hole in the top that allow a screwdriver to remove the three screw for the fixing unit. and you will unplug two wires. GOOD LUCK !!
Jan 05, 2009 | Office Equipment & Supplies
HP LaserJet 3055 All-In-One Printer Logo
20 people viewed this question
Seeker5211
Seeker5211
