Question about Hampton Bay 52 In.Carriage House II in Polished and Satin Brass Finish Fan
Got a new Hampton Bay model 599/779 fan 3-way switch for my Cameron 2 Plus fan. 4 wires...which one goes where? Colors are: orange, black, purple, and yellow.
I have a Hampton ceiling fan, its got a four wire fan switch, home depot gave me a Westinghouse 77286 with L, 1, 2, 3 wire points the fan has a black, purple,brown and gray wire. What goes were?
Just because the switch looks the same on the outside doesn't mean it's the same on the inside. You should have written the info down before removing the old switch. Anyway, try this;
Black - L Brown - 1 Purple - 2 gray - 3
If this doesn't work you probably have the wrong switch.
Feb 10, 2015 | Hampton Bay Dryers
Westinghouse 3speed fan switch 77288
It's the westinghouse switch. Many results on search. I just wasted 2 hours playing switching wires all combos. Others suggested the switch from Lowe's. Harbor breeze #0033905 . Plug wires back in as you listed Black L, Grey 1, Brown 2, Purple 3. Works perfectly for $3.98 plus tax.
Others said you can call Hampton Bay and get the replacement also.
Sep 24, 2013 | Hampton Bay Dryers
Fan switch are LJY-280A and E198635
I have a Hampton Bay indoor/outdoor ceiling fan with 3 speed fan switch WU Pin LJY280A, E198635. It is a L-3-1-2 (ccw) switch with purple, grey, black and brown wires. The wiring is different than most on web. The L is not black, 2 is black. My wiring for the switch is L-Purple, 3-Grey, 1-Brown, 2-Black.
Found schematic on web that I think is correct:
Off-none,
Hi-L,1 4uF,
Med.-L,2,3 10uF & 4uF,
Low-L,3 5uF & 4uF.
I hope this helps someone.
Feb 21, 2012 | Hampton Bay Dryers
Wiriring a 4-way switch
Sorry to be so late in answering. Mine broke in October and I just got around to fixing it.
The Black goes to L
The Grey goes to 1
The Purple goes to 2
The Brown goes to 3
Oct 16, 2008 | Hampton Bay 24750 Huntington III Ceiling...
Hampton bay ceiling fan
we have a hampton bay fan burning smell coming in didnot run
May 14, 2008 | Hampton Bay 24002 Ceiling Fan
This should do the trick. Good luck and make sure the power is off.
L - Orange, 1 - Black, 2 - Yellow, 3 - Purple
Jan 28, 2008 | Hampton Bay 24002 Ceiling Fan
Installing Fan Pull Chain
Hampton Bay fans are a Home depot entity. You can contact Home Depot online and ask but im sure you never will recive an answer as I have asked several questions about replacement parts to them till I was blure in the face. You can look up a company called the fan doctor online and see if they can assist you Good Luck
Oct 07, 2006 | Hampton Bay 52 In. Cameron II Plus Ceiling...
Hampton Bay 52 In.Carriage House II in Polished and Satin Brass Finish Fan Logo
81 people viewed this question
Top Hampton Bay Dryers Experts
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
