Question about Nokia N70 Cellular Phone
N70 phone: still keeps saying memory full when i emptied everything already. tried to do resetting but was asked for lock code which i don't have any idea anymore--my daughter changed it and can't remember what. My phone's IMEI: 356294014776917. Pls. help me reset my phone by providing me the lock code. Pls. Help. ASAP!
  • lotlot811 Feb 05, 2010
    hey! hey! hey! I solved it myself. so, for anyone who has the same problem and want to reset their n70 phones, try hard-resetting : turn phone power off and then power on while holding green dial button, *, and 3 all-together at the same time until it asked for your country.
Posted on Feb 07, 2010
Hey the solution for this is simple. Go to my office. In that select File manager. Then right click on c: drive. Then go to data in c: drive. Scroll down you"ll find a file called music.db. Just delete the file. Then you're phone memory will be fine. This is because that file contains alot of memoy.
Posted on Jun 05, 2010
Whenever I try to make a call from my Nokia N70, it shows me 'Connection Error'. Others are not able to call me.I am unable to send and receive text messages also.Please let me know what kind of...
try a hard reset..dial *#7370# then input 12345 as a password..if it doesn't work turn off your n70, hold power button * 3 and receive call button at the same times, make sure your battery is full.
notes: it will erase all your data in phone memory
May 09, 2011 | Nokia N70 Cellular Phone
My cp is nokia N70... my problem is its says "memory full delete some data first" ive already format my memory card so then my free mb is big but its the same problem nothing changes i have a...
YOU NEED TO FORMAT YOUR PHONE NOT MEMORY CARD.FORMATTING THE PHONE WILL SOLVE YOUR PROBLEM.AND TO AVOID PROBLEM IN FUTURE INSTALL APPLICATION MANAGER ON YOUR PHONE AND WHENEVER YOUR PHONE SAY MEMORY FULL JUST USE THIS SOFTWARE TO COMPRESS MEMORY.
THERE ARE TWO METHOD TO DO FORMAT NOKIA HANDSET.
  1. MANUALLY.
  1. OPEN MENU>SETTING>PHONE SETTING>FACTORY SETTING.
  2. PRESS O.K. A MENU WILL POP UP LIKE YOU LAST ALL YOUR DATA PRESS O.K.
  3. IT WILL ASK FOR CODE ENTER CODE( DEFAULT CODE IS 12345).
  4. PRESS OK IT WILL DO FORMAT YOUR PHONE.
2. USING CODE.
  1. DIAL *#7370# ON MAIN SCREEN.
  2. A MENU WILL POP UP LIKE FORMATTING PHONE.
  3. PRESS OK IT WILL ASK FOR CODE ENTER 12345 AND PRESS OK
  4. IT WILL DO FORMAT FOR YOU.
3.METHOD NO.3(FOR S60 SERIES MOBILE)
  1. SWITCH OFF YOUR PHONE.
  2. WHILE SWITCHING ON PRESS THREE BUTTON AT THE SAME TIME.(1.GREEN DIALING KEY 2.*KEY,3 KEYPAD NO. 3 KEY) WITH POWER ON BUTTON.
  3. A MESSAGE WILL POP UP LIKE FORMATTING. HOLD BUTTON FOR 3 SECONDS AND RELEASE THEM AFTER THAT.
  4. YOUR PHONE WILL RESTART AND ALL YOUR DATA WILL BE GONE
Mar 11, 2011 | Nokia Unlock N70 N71 N72 N90 6630 6680...
It says that the memory is full but i have memory.. and i can`t open the menu..
The warning pertains to the phone memory. try restarting the phone. if it still doesn't work, you need to hard reset your device by typing *#7370# . it will ask for the security code. after that, it will fomat the phone and you'll be able to use it again.
Jan 21, 2011 | Nokia N70 Cellular Phone
I keep having an error come up saying Messaging: Memory full close some applications. I have also had an error saying General: Memory full close some applications. I have no applications open can you...
clear your browser cache as well
set your messages in messaging - options- settings - other to 999 and e memory.
restore factory settings *#7780# default code is 12345 that might just might help you a bit and turn off and on your phone when you do all these things see if it helps any.
“Memory Full…Close some applications and try again” is a normal
message that usually comes on Nokia N70. It showed the memory used in the phone doesn’t have space anymore. But if the message still appears although the user already closed some applications it can be theproblem.
Someone who experience in this memory full problem said, an error message of memory full like above is appears each time he’s opened the
Camera. It also happens for a few times when he’s trying to open
messages, Gallery, or other applications. And then it will force to restart the phone.
Seems like it’s a RAM problem and might there are some applications unable to close completely. If your Nokia N70 phone has gone a start
menu button you can try to hold it down. This way will show you
everything that you have open and they can be closed easily so that
you can continue to take your photos.
So if it can resolve the problem you can reset/format by pressing *#7370#
Oct 30, 2009 | Nokia N97 Cell Phone
My Nokia N73 phone keeps saying 'memory full delete data' when i try to send txt - but there is no data to delete, txts , images etc are empty. And memory details say there's plenty of memory. What's...
you just have to reset your phone press*#7370# this will reset your cell phone and then it will ask for the code then enter your code thats all
Jun 08, 2009 | Nokia N73 Cellular Phone
My nokia n72 keeps on saying memory full delete some files...I have nothing on my memory card yet. What am I supposed to do to fix this...Please HELP!!!!!!!!!!!!
hie!
if ur cell is displaying the memory full warning, it means ur phone memory is full, try to reduce some software frm the phone memory, and always install the softwares on ur memory card whenever it ask to install the path, while installing a software.
if the problem is still there, of memory full after emptying ur phone memory, then soft format ur cell, by pressing *#7370# and then the security code(12345 by default)
bt before that backup all ur important datasuch as contacts and mesages of the phone memory, as then soft format reset all the settings and flash all the phone memory.
bunty
May 02, 2009 | Nokia N72 Cellular Phone
Forgot my N70 code
Me personally: i would enter it INCORRECTLY mutliple times till it asks you for a PUK Code and you can get this from your carrier online.
Just be careful entering the Puk Code because after so many incorrect trys it will lock out your sim card and you will have to purchase a new one.
I hope this helps, Let me know if you need any more assitance
Feb 19, 2009 | Nokia N70 Cellular Phone
N70
You can perform a master reset of the phone to get rid of the virus. Make sure you back up everything since this wipes out everything. Here is the code for the reset:
*#7370#
Mar 22, 2008 | Nokia N70 Cellular Phone
Format
How to get N70 password by using IMIE number?
Feb 16, 2008 | Nokia N70 Cellular Phone
N70 lock code forgot
you cant do it with yourself,but your problem is very easy to solve,just go to the cellphone repair shop nearest in you & tell them what happen.dont worry mura lang yan.50-100peso lng...kpg sobra p dyn yung siningil sayo try ka sa iba..,gudluck
Nov 15, 2007 | Nokia N70 Cellular Phone
Nokia N70 Cellular Phone Logo
195 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
