Question about Coleman Sport 1850 Generator
I have 4000 watts coleman generator it runs all it will do is run 1 small power tool. Not enough power to run anything else. would like to know what's wrong.
  • tommy_west Feb 06, 2010
    I have a coleman gen. 4000 watts the motor runs open but still will not put out the right watts, it will run a small power tool just one at a time.
  • Coleman Master
  • 6,674 Answers
Have you read manual thoroughly, as some will explain in there what and what not as far as power tools go, that it will run. Some models of generators, aren't designed for that much load at start up etc. Maybe if you can give me exact/complete model number I can figure it out from there, once I see actual rated specs.
Posted on Feb 06, 2010
  • 10,865 Answers
Your generator is rated at 2000 watts at from each 120V line. At 240V it will supply the full 4000 watts. That said, use a volt meter to check the output from each outlet. If it is less than 1900 watts per leg you mmay need an engine tuneup [new plugs, new air filter] OR you may have a partially gummed up carburator. I recommend that you begin by getting a bottle of a fuel additive called Seafoam. Follow the directions to add the correct amount. Run a tank of treated gas through the generator and the engine will run up to it's potential. IF at that point you still don't have the wattage you should you will have to check the breaker and the wiring connections. Regards, Joe
Posted on Feb 05, 2010
Power cord does not retract immediately
Coleman Powermate Generator 5000 Watts / 6250 Watts ...
? 3:27
https://www.youtube.com/watch?v=IROa5QfPqkU
Nov 8, 2012 - Uploaded by Carlos Roman
This 5000 watt generator is great for backup power at home or forpower ... Coleman Powermate Generator 5000 Watts / 6250 Watts ... This feature is not available right now. ... folding handle, 1 quart, of oil, and 25ft generator convenience cord. ... How to convert a generator recoil starter to an electric starter!
pull cord won t retract Power Generators Questions ... - Fixya
www.fixya.com > Forum > Tags > pull cord won t retract
Power Generators pull cord won t retract questions and answers. Ask your pull cordwon t ... Question about Powermate Powermate 5000W Generator. 2 Answers · I was running my coleman powermate 6250 gen power ... cord 6250 trips out ... The pullcord does not rewind onto the pulley when pulled. At first I thought it was ...
Best Portable Generator Reviews
Feb 03, 2016 | Coleman Powermate Powermate 5000W...
We have a Valsi 5500 watt generator that isn't putting enough voltage out to run everything in out small travel trailer. It runs the lights but doesnt push out enough voltage to carry the A/C, microwave,...
How long have you had this generator?
Has the generator worked on all of these loads before?
Model 5500 is a 5500 Watt generator which could easily be 5500 watts (Peak) and not continuous.
Your AC is an inductive load.
Your lights are resistive loads
An inductive load can cause issues when starting due to an increased current demand at start up that some generators cringe under. Do the lights flicker or are they stable? I'd say your diodes on your stator are working if you have light stability but you haven't provided nearly enough information for a detailed solution.
I'm sure you have enough voltage but you aren't getting enough current to run specific loads. How many watts is your AC? How many watts for your microwave? Both of these units demand a great deal of energy to run and when you place too much demand on your generator, it will choke it out and eventually, will cause damage to the generator. You may consider getting a beefier generator with a greater amount of wattage output.
Seeing these specs online and noting what you are trying to run, you have an undersized generator and need to get one that can produce a greater amount of running wattage (as well as peak wattage).
Apr 12, 2011 | Watts Onan Portable Generator - 4000 ,...
4000 watt buffalo tools generator: Engine Starts, but after a few minutes it cuts out and stops running. No appliances plugged in, drained gas(it did sit for 6 months), oil is full, Plug is good.
Idle speed jet or passage and/or high speed jet/passage is clogged. Remove the carb and inspect and clean thoroughly, then re-install. Set idle and high spped screws approx 1 turn and tune to run smooth from there.
Feb 05, 2010 | Buffalo Tools 4,000 Watt 6.5 Hp Portable...
I have a 4000 watt coleman powermate that is fifteen years old and approx 200 hrs on it. Had it running during a blizzard and the motor pulled down and now only puts out half power.Could swirling snow have...
Yes, swirling snow could have done some damage. Any snow that may have gotten inside had enough heat to melt it but not evaporate it. It would be overly difficult to try and explain how to take it apart over the internet. I would suggest taking it to a small engine repair shop. Is it running at full rpm with half the power or running at half the rpm at half power?
Feb 02, 2010 | Coleman Powermate Premium Plus 6250W...
12000 watt powermate won't charge the battery
Some Coleman generators have rectifier /diode pack behind panel others have a diode inside generator cover however when diode fails it usually fries the winding. Your winding could be within the generator or under flywheel depending on model#. If your generator had a fuse to protect winding then test diode and replace as necessary. You may also just plug a small battery charger (1 or 2 amp ) into 115v plug to charge battery / power coil. Good luck and email if you have other questions.
Oct 27, 2009 | Coleman Electrical Supplies
RV Onan 4000 runs fine but not putting out enough voltage to run anything
Not sure how to set it up but you can take it and have the voltage turned up on your generator or the voltage regulator is out.
Sep 09, 2009 | Watts Onan Portable Generator - 4000 ,...
I have a 4000 watt Coleman generator that won't
If it has been in storage with gas in it. it is gunked up. Need to remove carburetor and take to someone to clean carb.
Aug 23, 2009 | Buffalo Tools 4,000 Watt 6.5 Hp Portable...
Coleman Sport 1850 Generator Logo
85 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Shawn DuRee
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
