Question about Jenn-Air JCB2059G Bottom Freezer Refrigerator
Came home to find my Jenn Air JCB2059G freezer completely thawed out but light and fan appear to be working. any thoughts?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 162 Answers
Compressor relay. take it off and shake it. 99 percent of the time when there bad they will ratlle like broken bits inside. just replace.
Posted on Feb 05, 2010
There is a ticking nose in the freezer , like it wants to start,, feel air but not cold
How often does it click? It may be the compressor clicking, trying to start. If so, you may have a faulty starter or compressor.
Jan 29, 2011 | Jenn-Air JCB2059G Bottom Freezer...
It's dead. no cold. fridge and freezer. fan is blowing. Made weird noises for the last 2 months. Compressor?
Good day,
If the fan in the freezer as well as the condenser fan underneath by the compressor are running, and there is no frost building up on the rear panel in the freezer compartment, then yes, it sounds as if the compressor failed.
If the compressor won't run, it is possible the compressor relay or overload protector failed, but if it was making noise, it is likely the compressor is the faulty component.
If the machine is under 5 years of age, hen the factory will service it. If not, then you will need the services of a professional to check it out.
Sep 13, 2010 | Jenn-Air JCB2059G Bottom Freezer...
Freezer building up lots of frost, but on lowest setting.
FREEZERS SHOULD BE TEMP AT O /REFRIGERATOR SHOULD BE 40/FOR PERFECT OPERATION.1ST IS THE FAN RUNNING IN THE FREEZER/IF YES UNPLUG FOR 6-8 HOURS AND RETRY/IF NO UNPLUG THE FRIDGE AND REMOVE THE BACK PANEL OF THE FREEZER MAKE SURE THE FAN IS PLUGGED IN.IF SO PLUG IN THE FRIDGE AND SEE IF THE FAN IS TURNING.IF NOT YOU NEED A NEW FAN IF THE FRIDGE IS NEW MAKE THEM BRING YOU A REPLACEMENT FOR FREE.
Jan 16, 2009 | Jenn-Air JCB2059G Bottom Freezer...
JENN-AIR BLOWS WARM AIR
hi thanks for the question the freezer is more than likely frosted up now with the door left open the drain hose from freezer is clogged shut down let thaw remove panel at the back of fridge allow 24 hrs to thaw clean out the drain tube re level the fridge so that if the door is left open the door will close by its self raise the front legs to achieve this thanks the appliance doc
Aug 12, 2008 | Jenn-Air JCD2389G Side by Side...
Refridgerator
There is fan in the freezer behind the metal cover. Try to stop the fan, and see if the the noise stops... If the noise stops then its possible that the fan is out of balance. If this is not the case then i would suspect that this is problem with the mainboard.
Jul 09, 2008 | Jenn-Air JCB2059G Bottom Freezer...
Jenn-Air Refrigerator JCB2059GES freezes
your thermostat is bad,get the model number from inside and call your local appliance store and get a new one,let me know,thanks-mike
Jun 23, 2008 | Jenn-Air JCB2059G Bottom Freezer...
Freezer drawer handle loose...how do I tighten screws?
With a screwdriver?
Screws in plastic will wear with constant use , take the screw right out and wrap it with aluminium foil, then replace
Jan 24, 2008 | Jenn-Air JCB2059G Bottom Freezer...
Jenn-Air JCB2059G Bottom Freezer Refrigerator Logo
113 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
