Question about Car Audio & Video
My dual xdvd710 has the emergency brake screen how do i bypass it? what wire coming off the deck would i use.
  • 24 Answers
Usualy its red dont mistake it for the ilumination but if you get it ground it.
Posted on Feb 06, 2010
Try to bypass a emergeny brake pedal switch for a touch sceen dvd player radio. Its a dual model xdvd710
TRY GROUNDING THE WIRE THAT HAS TO BE HOOK TO THE E BRAKE YOU MAY EVEN HAVE TO GET A SWITCH AN ON AND SWITCH THAT MIGHT WORK EVERY DECK IS NOT THE SAME
Feb 19, 2011 | Dual Electronics XDVD710 Car DVD Player
The emergency brake warning will not go away even when the emergency brake is on...do I need the remote in order to operate the dvd player?
The warning is there because the signal that the brake has been engaged doesn't reach the player - either the unit was badly installed or there's a fault in the wiring. To find which you will have to remove the unit and test the wiring.
BTW you don't need the remote, almost all functions can be easily accessed from the buttons on the unit. The remote is there so that the passengers from the rear seats don't have to lean towards the central console to operate the unit.
Jul 01, 2010 | Dual Electronics XDVD710 Car DVD Player
Emergency brake warning will not go away even when the emergency brake is on.
what emergency brake are you referring to? Is it a car emergency brake and which car model are you talking about?
Please rephrase your question, because I don't really understand it.
I look forward to your reply.
Bye for now.
How would one bypass the emergency brake to view a dual 7 inch touch screeen while driveing
On the radio wiring harness grond the wire that is marked emergency brake sensor/light wire. Be advised that it is illegal to have a dash mounted video player active while a vehicle is in motion, reason emergency brake has to be applied in order to watch.
Dec 26, 2009 | Panasonic CQ-VD7001U 7 Inch (Diagonal)...
How to bypass a dual xdvd710 without the remote
ground the brake wire from the radio to a switch that cut off and on, to the chassis ground you will have to hit the switch every time you want to watch the tv the switch acts like its hook up to the parking brake so when u hit it twice it thinks that the brake is engage
Oct 09, 2009 | Dual XDVD8170 Car DVD Player
Dual xdvd 8625 double din emergency brake bypass
you can ground it,then enter the code 26604 after u insert a dvd real dvd then press stop twice then enter the code it should work
Jun 06, 2009 | Dual XDVD8170 Car DVD Player
Dual XDVD710 Car Video Player
There isn't a code but there is a way when you wire it. DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On mine, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
The e-brake indicator light is what is called a "ground complete" circuit. That means that the bulb always has power applied, but when you pull the brake, that puts a ground to the wire and completes the circuit, allowing it to illuminate. The head unit sees this ground, and activates the DVD player.
In my Jensen unit, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in whatever manner is required by the manufacturer of your head unit. If there is no off/on sequence with yours, as there is with mine, simply ground the wire to a screw inside the dashboard and you're done.
Jul 31, 2008 | Dual XDVD8181 Car Video Player
How do i bypass the emergency brake wire on a dual xdvd700
Its illegal to do but i have done it! You have to connect the brake wire to either the pos or neg wire! You need to find out which one it is thou, so attatch it to the negative first so you dont cause any damage if it doesnt work then connect it to the pos wire and it should work a treat for ya! I stress connect to neg first!!!!!!!!!!
Jun 13, 2008 | Jensen's VM9312 Car DVD Player
Help
just add a valet swich to the ground and the oher to the other end of the brake wire cable
Dec 20, 2007 | Dual XDVD8181 Car Video Player
Car Audio & Video Logo
256 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
