Question about Sonic RecordNow! Deluxe 7.3
Following a computer crash a while ago I now find my Sonic Record now is not functioning is there any way I can get help My system is Microsoft XP
  • 163 Answers
I would say the best thing to do is re-install the software for this program.
Hope this helps!
Posted on Feb 05, 2010
I have a net n my computer but i dont have a microsoft.. can i dowdload it free ???? help me pleas??
Call microsoft 1800 102 1100 for Customer Service and ask for a recovery disc for XP. If you take the CPU to your computer store they might run it for you. I assume you mean your system has crashed?
Jan 15, 2011 | Microsoft Windows XP Professional
Tip
How to fix "Operating System Not Found" error when you start your Windows...
When you try to start a Windows XP-Based computer, you may receive an error message that the operating system is not found.
APPLIES TO
Microsoft Windows XP Home Edition
Symptoms
When you start a Windows XP-Based computer, you may receive one of the following error messages.
Error message 1
Operating system not found.
Error message 2
Missing Operating System
When you start your computer to the Recovery Console to recover functionality, you may receive an error message that resembles the following error message:
Setup did not find any hard drives installed on your computer.
CausesThis issue may occur if one or more of the following conditions are true:
The basic input/output system (BIOS) does not detect the hard disk.
The hard disk is damaged.
Sector 0 of the physical hard disk drive has an incorrect or malformed master boot record (MBR).
Note Some third-party programs or disk corruption can damage an MBR.
An incompatible partition is marked as Active.
A partition that contains the MBR is no longer active.
Resolution To resolve this issue, use one of the following methods, depending on your situation.
Contact your hardware manufacturer
Your best bet may be to contact the manufacturer of your computer or your hard disk. The manufacturer may have a utility that you can use to perform a more detailed scan for damaged areas of the disk and help verify the correct BIOS settings. However, be aware that the damage to your hard disk may be serious. Sometimes this means that your only solution is to replace your hard disk.
If a fix or workaround is not available, you can use the "Advanced Troubleshooting" section to try to resolve this issue.
Advanced troubleshooting
This section is intended for advanced computer users. If you are not comfortable with advanced troubleshooting, you might want to ask someone for help or contact support. For information about how to contact Microsoft support, visit the following Microsoft Web site:
http://support.microsoft.com/contactus/
Method 1: Verify the BIOS settings
Verify the computer's BIOS settings to make sure that BIOS lists and recognizes the hard disk. See the computer documentation or contact the hardware manufacturer for information about how to verify the BIOS settings.
After you verify that the computer's BIOS detects the hard disk, restart the computer, and then test to determine whether the issue is resolved. If the issue is not resolved, or if the computer's BIOS cannot detect the hard disk, you may have issues with your hardware. Contact the hardware manufacturer to inquire about how to resolve this issue. You may have to replace the hard disk.
For information about how to contact hardware manufacturers, click the appropriate article number in the following list to view the article in the Microsoft Knowledge Base:
65416 Hardware and software vendor contact information, A-K
60781 Hardware and software vendor contact information, L-P
60782
Hardware and software vendor contact information, Q-Z
Method 2: Use Recovery Console
Use the fixmbr command in the Windows XP Recovery Console to repair the MBR of the startup partition.
Warning This command can damage your partition table if a virus is present or if a hardware problem exists. If you use this command, you may create inaccessible partitions. We recommend that you run antivirus software before you use this command. We also recommend that you backup your data before you use this command. If the fixmbr command detects an invalid or non-standard partition table signature, the fixmbr command prompts you for permission before rewriting the MBR. The fixmbr command is supported only on x86-based computers.
For more information about Recovery Console, click the following article numbers to view the articles in the Microsoft Knowledge Base:
314058 Description of the Windows XP Recovery Console 307654 How to install and use the Recovery Console in Windows XP
on Jul 15, 2010 | Computers & Internet
Multiboot computer, Second OS unavailable after reinstall of XP
The problem can be solved easily if the second operating system was a windows based operating system.If it was a windows operating ,the following steps will give you a solution
In order to regain the boot path for old operating system
follow the following steps
1.Insert the Microsoft windows xp installation cd into a cd drive and boot the computer from the cd
2.In the microsoft setup page select the option of R ie recovery console
3.Select the operating system in the recovery console by selecting the operating system NO eg 1 and type the administrator password
4.Type the following command in command prompt
bootcfg /rebuild it will search for existing operating system in the hard disk and prompt you to add select yes .
5.once you completed type exit
May 06, 2010 | Microsoft Windows XP Professional
Having problem with running and saving downloads on desktop. I am using xp and it crashed couple days ago. now i cannot access control panel because i have no file rundll.exe. how do i fix these problems
Click Start, click Run and type in regedit. Now, find the following key:
HKey_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explor er
Look in the right hand side pane and you would see dword value "NoControlPanel".
Right click and modify change the value data to "0" or you can delete that dword value.
However, if you are not able to fix, please install combo fix and scan your computer.
http://www.bleepingcomputer.com/combofix/how-to-use-combofix
Apr 17, 2010 | Microsoft Windows XP Home Edition Service...
Lost activation key
Hi there, well you will need to call Microsoft custumer support to get help with this. As long as you have your cd-key and original cds you should be fine. good luck!
Jun 03, 2009 | Microsoft Windows XP Professional
I may need a phone number to hp for record now of sonic which comes with!
you need to reinstall every software that don't run now after the reinstallation.
Oct 20, 2008 | Sonic RecordNow! Deluxe 7.3
Troule burning DVD
try these:
Resolution:
1. Delete upper and lower filters. (HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E967-E325-11CE-BFC1-08002BE10318})
2. Uninstall Driver in device manager, restart.
If device is still no shown try the following:
1. Download the pxengine patch (http://patches.sonic.com/PX/pxengine1_08_34a.exe)
2. Install and then restart system.
*The pxengine patch adds to the list of drives supported by the Px Engine (Sonic Record Engine).
Jun 23, 2008 | Sonic Computers & Internet
Unexpected error during install
Is XP Media Center what you had installed previously when the cam was working? If so, are you using the correct and latest driver from the manufacturer for said operating system?, That being also said, are your video and audio drivers up to date for the operating system?? Those will be the primary concerns, however remember that a corrupt download or one that became corrupted as a result of the hard drive crash could be the real issue. So in other words, start from scratch and check everything you do.
May 21, 2008 | Microsoft LifeCam VX-3000 Web Camera
Windows XP Media Center, systems freezes; suspect Radeon x600 xt
Make sure all of the fans inside your computer are still functioning. One of them could have stopped working and it is causing the card to over heat.
Jun 05, 2007 | ASUS RADEON X600 XT, (128 MB) Graphic Card
Sonic RecordNow! Deluxe 7.3 Logo
91 people viewed this question
Top Sonic Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Are you a Sonic Computer and Internet Expert? Answer questions, earn points and help others
