Question about JVC TH-M505 System
Philips theater system dvd/radio/surround sound
Just bought a system trying to install theres no color upset in ohio using blue green and red jacks. do get blackand white
  • 8,596 Answers
I need your exact model number of HTS, and the manufacturer and model number of your television to be of maximum assistance.
There are a couple possibilities:
1) you could have red, yellow, and whites plugged into the red, green and blue slots
2) If you have more than one output (S-video and red/yellow/white, for instance), the signal could be splitting - try unhooking one of the outputs (preferably the S-Video)
For a more detailed solution, send me your model/manufacturer of TV, and the model of Philips HTS.
Posted on Feb 21, 2008
No blue green yellow like in football peach color flags thrown peach color grass is blue green purple color is black etc etc
Are you using a component video connection (3 wires for the video, colored red, green, and blue)? It sounds as though you are, but correct me if you are using a different connection as the steps will be different. If so, ensure that they are all connected. You can also unplug one at a time while watching the picture. If the colors DON'T change when unplugging any individual wire, then check that wire from end to end looking for cuts/corrosion/etc... If necessary, replace the cable. Also make sure that they're plugged in to the right jacks, they should be color coded. NOTE: there is a red jack for the video AND for the audio. Check carefully that these aren't mixed up.
Nov 08, 2013 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Why? no sound from the speskers at all.
There are a few things that could cause no sound and although some are obvious I'll got through them all..
1) Sound is on Minimum
2) Sound is Muted
3) No Power to Subwoofer
4) Speakers connected Incorrectly or Faulty
5) No AUDIO IN connections to TV-IN or AUX-IN
6) Incorrect Input Source is Selected (See Below)
Connecting audio from TV
When connecting the audio output from your TV to this Home Theater Audio System, you will have the sound of the
TV output on all the speakers. It will enable you to enjoy the multi-channel surround sound capabilities.
Use an audio cable (red/white - not supplied) to connect the TV IN jacks on this DVD system to the AUDIO OUT
jacks on the TV. To listen to the sound, press TV on the remote control as the sound source that you want to play.
Connecting audio from an audio/video device
This DVD system provides analog and digital audio connection. You can connect the audio output from an
audio/video device (e.g. VCR, Cable/Satellite Box) to this Home Theater Audio System in order to enjoy the
Use an audio cable (red/white - not supplied) to connect the AUX IN jacks on this DVD system to the AUDIO OUT
jacks on the connected device. To listen to the sound, press AUX/DI to select "AUX" as the sound source that
you want to play.
Or
Use a coaxial cable (not supplied) to connect the DIGITAL IN jack on this DVD system to the DIGITAL OUT jack on
the connected device. To listen to the sound, press AUX/DI to select "DI" as the sound source that you want to play.
Please leave feedback
Cheers
Andy
Apr 27, 2011 | Philips HTS3450 System
I have a vizio HDMI DTV telvision, and a sony surround sound system, I am trying to hook my wii to this to watch movies, the problem is I have hooked the yellow cable from the wii to the surround sound, I...
If you're using the HDMI cable with 5 wires, the red, blue and green wires are for video and the red and white wires are for audio. If your TV has a component IN RCA jacks, they connect there. If you're using the 3 wire cable, yellow is for video, and the red and white is for audio. You will NOT get HDMI pictures with this setup so you will have to go into the input selections and choose composite video input on the TV menu. Get a connection diagram from Visio's website or look in your owners manual if you have one.
.Connect them to the corresponding inputs
Jul 28, 2017 | Philips HTS-3565 Theater System
Panasonic SC-HT730 Green picture when showing DVD's
The DVD player of this system will output to a TV on either composite (Yellow jack), component (RGB jacks) and S-Video (a small round jack that looks like a mouse or keyboard connector) jack. Since the tint is off, I would guess that you're using the more desirable component or even the S-video jack. Try removing & re-seating the plugs into the jacks at the DVD and at the TV; then check the picture color. If it still is wrong, try using a different cable type - use a standard video cable between the yellow jacks on both the TV and DVD. You may need to set the TV input to reflect the use of the new jack - and possibly set the DVD to 480i or Interlaced if you used the Progressive Scan or 480P output when using component RGB video cables (Red, Green & Blue). Check for correct color.
Chances are the connection got dirty and caused the color issue - or less likely, the cable or even less likely - the DVD output has failed.
Mar 26, 2010 | Panasonic SC-HT730 System
Hi, I just bought a samsung blue-ray. I want hook
i can help with that have you looked on the back of the tv at all the jacks you have look at the color of the jacks some are red and white those are for audio and the yellow is video you need a pair of cables that will conect from you dvd to your samsung that same color on both ends their RCA cables or analog cables
Oct 29, 2009 | Onkyo HT-S780 System
CD/DVD PROBLEM ON A PANASONIC SA-HT680
Check your "Setup Menu" with NO DVD in the player. Could be the wrong format, should be 720p or 1080i or 1080p. Are you using Component cables to your TV or HDMI? if Component, check your connections, it is color coded but may be hard to see with most installations. Use a flashlight to make sure colors are correct Red to Red, Blue to Blue and Green to Green. Sounds like you've got cables mixed up. It happens to the best of us! and I do it for a living! Hope this helps
May 21, 2009 | Panasonic SC-HT680 System
Can't get surround sound for tv shows
The coby dvd 988 has 2 rca audio input jacks, you need to have these connected to your TV AUDIO OUT jacks, these are usually colored red and white like right and left stereo jacks, be sure to set up the TV for AUDIO output through these connections, some tv`s require that the internal built in speakers are cancelled and the audio output jacks are enabled. Set the coby input signal to receive the port you pluged the tv signal into.
Feb 06, 2009 | Coby DVD-988 Theater System
No color and no audio
yes , this is why , on your dvd there is a "yellow for video" output on it ,and then there is a "red output jack for right audio"
and then there is a "white output jack for left audio" does your tv have these inputs?
the blue , green and red "RCA JACKS" are called " composite video" which seperates the colors of given video
the red and white RCA jacks are for right and left audio and are required when using composite or the yellow video jack
there is also a "s-video" connection that is one cable but seperates the colors for better picture quality ( dvd player only)( vcr and tuner do not work with this)
then there is a optical or coax digital connection for a reciever that decodes the connections audio digital signals for dolby digital surround sound
Jan 08, 2009 | GoVideo Go Video DVD/VCR Combo
I want to connect the Audio from tv to Surrounding audio system
For connections of audio, so that you can hear all tv audio through the
surround system, connect either an optical audio cable or red & white
analog audio cables from the tv to the home theater. If you are using
optical audio, there is a plug on back of tv labeled for digital audio
output and an input on the surround sound system. If you plan on using
analog red and white, use the PROG OUT red and white output jacks on the
back of the tv to the AUX input on the home theater.
For video connections, to get HD you will need to be using either HDMI or
Component cables. HDMI is the cable that will provided 1080p signal (the
best HD signal), but if the source does not output 1080p, then your tv
will not display 1080p. Most cable boxes output at 1080i or 720p when on
HD stations. This signal still provides great picture quality, but HDMI is
not needed to get these HD signals. You can use component cables for your
cable box and the DVD player output to the tv for video. HDMI might give
you a slightly better picture quality but the signal will be the same.
To make the connection, you will want to connect from the cable box to the
tv (component or hdmi). Also from the home theater system to the tv using
hdmi or the video cables from component (red, blue, & green cables).
We hope this information is helpful to you.
Thank You,
Panasonic Consumer
Dec 16, 2008 | Panasonic Home Theater System System
The color on my dvd is red. The TV color is fine.
Bad chroma processor. Part of the video CPU. Service time...accordianman
Nov 24, 2007 | Philips HTS3400/37B System
JVC TH-M505 System Logo
74 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
