Question about Neff 24 in. S5443X2 Built-in Dishwasher
Neff dishwasher - water left in bottom and does not drain away after programme. CHecked filters and they are ok. Makes a slightly funny noise when initially switched on. Please help! Thanks
  • 4 Answers
SOURCE: Neff Dishwasher won't drain
I've had this problem a couple of times with my dishwasher. In both cases, the cause was a shard of broken glass that had managed to get past the filters and jam itself underneath the impellor. Hard to see, but easy to fix. First ladle out the water.
Pull off the lower rotor arm, unscrew the filter and take out the filter bowl, tray and cylindrical filter. Get as much water as you can out of the filter cavity.
Then, using a Torx-20 driver, remove the screw holding the impellor cover and lift the cover off. (this is the small bit of plastic at the left end of the filter cavity.) Check whether the impellor can rotate freely by spinning it with your finger several times - if it jams or grinds, then there's probably something jammed under it. (It may seem to be fine at first, so do check thoroughly, as any debris can move around with the water flow and only jam occasionally) You may have to use a cocktail stick or similar to poke out anything that's stuck underneath.
Glass is a particular problem, since it's almost impossible to see when there's any water around (it's easy to cut yourself too!)
Anyway, that's worked twice for me now - and I didn't have to even move the machine out of its cupboard to fix it.
Hope that helps.
Posted on Mar 14, 2008
  • 1462 Answers
SOURCE: Dishwasher stuck on "drain"
not easy to fix - it has a leak. the tray at the base is full of water which ooperates a float which switches drain pump on. remove front panel at bottom front and mop out water or tilt backwards 45deg and water will run out. leak is usually main pump
Posted on Mar 20, 2007
SOURCE: BEKO D 2731 FW Dishwasher Problem
yes man,it worked 1st time,cheers for that info.
Posted on Sep 28, 2008
wbwill
  • 68 Answers
SOURCE: NEFF DISHWASHER S5443 STUCK IN TEST MODE
First try disconnecting the unit, completely from any power, for an hour or more, look in any control doors or access points for a small battery mounted to a board or in a holder, if you find one, take it out also, noting the positive and negative orientation.
If that doesn't do it, there are reset buttons under the tops or lids of some NEFF models, if there is an obvious lid after trying the no power trick, take off the top and look for a stand alone reset button.
If all that fails, write me back
Will
Posted on Nov 05, 2008
This is a on going problem with asko and they keep jerking everyone around with this defect. I had a repair person come over and used a turkey baster with a 7" rubber hose attached to the end of the baster. He took off the kick plate and inserted the hose end in the overflow tray and pull about of 12 onces of water from the tray. He is a asko repair facility and says it is a comon problem and has made the repair solution on his own as it is easier then taking the hole dishwaser out and tip it on the side just to drain the water. This has been on going for 3 years and each time i called asko it was like i was the only person having such a problem. I now do this every 3 months and the problem is on going. What a piece of junk. Purchased at Marcellas appliances in Schenectady,NY. They also know how to avoid the problem in fact there repair person left out most of the screws so the next time it would take less time to drain the water. DDDDDont buy ASKO. Michael Foote
Posted on May 19, 2009
Neff s5443x1GB/29 dishwasher starts and stops
The pressure chamber or hose (pressure chamber to sump) may be blocked and the microswitch is being activated because the water is not entering the tank quick enough. Isolate from electric, remove lid and left panel (looking from the front). There is a plastic chamber bottom right of left side with two microswitches, either this is blocked or the hose that runs from it to the right and along the back of the kick panel and into the sump. Clear either or both (make sure all hoses are pushed true when repositioning).
Apr 16, 2013 | Neff Dishwashers
I have a Neff Dishwasher S5446x0/29 FD 8109 460056. It started making a whirring noise and when I looked it was not emptying the soapy wash water. I stopped the machine and manually drained the water out....
if the pump is not emptying properly it will think its still full, they have a sensor in the bottom that tell the machine that the system is empty and to begin next cycle.
Jun 27, 2017 | Neff 24 in. S5456 Built-in Dishwasher
Dishwasher blockage...not washing
It sounds like the pump is bad. Unplug your dishwasher, pull it out and check to make drain hose is clear.
Dec 17, 2017 | Neff 24 in. S5443X2 Built-in Dishwasher
The programme is stopping with about 40mins left and the tap symbol appears . I have read a few blog articles and ... removed the front plinth , cleared any filters, checked hoses for blockages (none) but...
using a tx20 driver remove the pump cover (remove filter and looking down into sump you will see screw at approx 10 o'clock), check for obstruction, may be a piece of glass etc so go careful, remove any debris and check the impellor turns ok. The unit will not drain without this cover refitted but you can check impellor is rotating whilst it is off. Check all outlet hoses, particularly the spigot connection under the sink if this is how it is fitted, Good luck
Jun 21, 2010 | Neff 24 in. S5555X0GB Built-in Dishwasher
We have a neff dishwasher and the pump is draining all the time (even when the door is open) but there is no water in the dishwasher. Is there a way to stop the pump and reset the setting for the flood...
The water which has activated the antiflood device is actually underneath the appliance it is held in the sump tray and this has to be drained before the A.F.D.will cancel.You will have to remove the dishwasher to get at the underneath but when you have got rid of the water you will still have to trace what caused it.The seal on the circulation pump could be a suspect or a pin hole in the drain hose.
Hope this helps.
May 09, 2010 | Neff 24 in. S5409X0 Built-in Dishwasher
Neff dishwasher continually draining
Update to my problems. It is now working. I removed the T20 tork screw housing the pump cover which is situated underneath the filter. I used a sponge and siringe to remove all water. And started the dishwasher a few times to spin the pump and flickout any excess water. I noticed some small bits of food which were removed and I cleaned all filters and put it back together. It didnt work staright away but the pump was not comong on as soon as the door was shut anymore. I did a reset and then selected a rinse programme and voila it worked! Tried a full wash cycle last night and it all seemed to be working fine......
Feb 25, 2009 | Neff 24 in. S5456 Built-in Dishwasher
NEFF Dishwasher Model 5623.25 keeps sticking during running
At what point in the programme does it stick, i.e. is it washing or rinsing or draining, does the water get hot?
Oct 09, 2008 | Neff 24 in. S5456 Built-in Dishwasher
Hope that helps.
Nov 10, 2007 | Dishwashers
Mar 18, 2007 | Neff 24 in. S5543X2 Built-in Dishwasher
Neff 24 in. S5443X2 Built-in Dishwasher Logo
269 people viewed this question
Top Neff Dishwashers Experts
Cesar Quant
Cesar Quant
Michael Galve
Michael Galve
Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
