Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
Banging noise when motor turns off
I've had the system for a year and a half, and until recently, it worked fine. Now I sometimes hear a banging noise when the unit stops running. Otherwise, it's fine.
  • 308 Answers
Have you replaced your air filter recently? Often this is a symptom of a restricted return. The blower almost causes a vacuum in the duct work, and when the system shuts down the duct "pop" back out, causing this banging noise. Hope this helps
Posted on Feb 05, 2010
Testimonial: "We changed the filter, and the banging is gone. Thank you!"
Why is my tumble dryer making a loud banging noise when on its a white knight model CL3A
Most of the time a tumble dryer will work like a dream but, as with all appliances, occasionally there will be technical problems.
If your tumble dryer is making a banging, whining (or other strange noise) it's best to diagnose and sort out the problem. It could be the result of a number of things, but what you certainly don't want to do is ignore it.
Here are the most common reasons for your tumble dryer making odd noises.
Coins and keys
One of the most common reasons for a banging, rattling or clanking is keys or coins left in pockets - so always check them before you put any clothes in the tumble dryer. More often than not you won't hear anything until the dryer cycle is in full spin.
Uneven surfaces
If the dryer is vibrating or shaking during spinning, check to make sure the dryer's sitting on a level surface. If it's fitted with height adjusters on the front legs, adjust them accordingly to ensure the machine is level as this will often reduce or eliminate the banging sound.
Drum bearings
If the tumble dryer is noisy when its turning and the whole appliance is shaking and rumbling, it could be indicative of a problem with the drum bearings, which help the wheels turn freely and easily.
The drum
If the banging noise is continuous when the drum is turning then it might be problem with the drum itself. If the noise is a metallic one, it could be the result of the drum scraping on something inside the machine. You could always check the drum visually for any marks or dents.
Motor bearings
If the tumble dryer is emitting a high-pitched screaming or whining noise it could be a sign that the motor bearings are wearing out.
Tension pulley wheels
If there's a squeaking noise coming from the dryer it could be the result of wear on the tension pulley wheels. This occurs more frequently on older models...or try this link..
Common Tumble Dryer Problems
Dec 09, 2016 | Dryers
Loud banging during kneading
you are right.for further help check this link.
www.repairclinic.com
Aug 29, 2008 | Breadman TR875 Bread Maker
Lincoln Navigator 2004(?) starting problems
well the wav file don't work, always use youtube.
as to your car, from the description, it's either battery or starter motor related.
Apr 25, 2017 | 2004 Lincoln Navigator
Hot water: Pipes make a banging noise when turned on full force.
Hi, That banging is sometimes called a water hammer. It is made when the water hits an elbow in the piping with a force and bangs into the pipe itself. It is more likely to occur in a long run of pipe. This can be reduced or eliminated by installing an empty tube verticle in the piping near where the hammer is occuring. This tube can be found at most building supply stores. The tube is a pocket of air that acts to absorbe the extra pressure from the piping and stops it from hammering.
May 05, 2010 | Delta 2 Handle Lavatory With Metal Pop Up...
1998,GMC,1500,5.7. Turns over will not start, gaskets from the heads on up have recently been replaced. was running fine untill last week when it stalled out on the highway, now it just turns over, but...
sounds like failed fuel pump.
try taking a hammer and bang on the fuel tank while someone is cranking the engine over. sometimes the banging is enough to allow the fuel pump to start working. (doesn't always work)
Oct 12, 2009 | GMC Sierra 1500 Cars & Trucks
Whirlpool gold makes banging noise
If the refrigerator is working fine the banging noise you hear is the isulation inside the refrigeratior walls that exand and cotract with the change of temperatures. you don t have to worried about it.
Apr 10, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Banging noise on spin cycle
most front loaders are balanced by a large: ready for this: cement block inside at the top of your machine and because spin is so fast it can sometimes hit inside your machine or it has brokin a peice off ,sorry but yours going to have to get the repair person out.adrian
Feb 15, 2009 | Bosch Classixx WFL 2066 Front Load Washer
206 Lincoln Aviator driver window will not work, other three work
when you push the switch if you hear a grinding noise you will need a new window regulator if you hear nothing the motor is stuck and by pushing on the switch while banging on the center of the door panel with fist or rubber hammer will sometimes unstick the motor
Jan 18, 2009 | 2005 Lincoln Aviator
Loud Banging Noise
if its a loud banging noise when the unit kicks off then broken spring in compressor will have to replace compressor check your 2-5th year warrenty in your owners manuel
May 14, 2008 | Hotpoint HTS18GBR
Banging noise
You may have had a foreign object slip under a loose drum baffle. Manually rotate the drum to locate wwhich baffle it is in.
Apr 06, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Heating & Cooling Logo
287 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
