Question about GigaFast Ethernet GigaFast EE400-R Router
Gfe router im trying to run this gfe ee400r rout from m cable modem to my comp and my x-box.....comp or xbox does not workwiththe router......xboxsays unable to detect dns.....comp says little or no internet connection
  • bhoffmanjr Feb 21, 2008
    wha?
  • Anonymous Apr 03, 2008
    Did you ever get that gigafast ethernet ee400-r router to work? I can't even get my computer to access the internet with it hooked up. Says little or no connectivity. If you did please tell me how you did it.
  • 83 Answers
YOU HAVE TO CONNECT TO THE INTERNET THROUGHT A PROGRAM SUCH AS ENTERNET.
Posted on Feb 21, 2008
I have cable modem can i hook up my belkin wireless router model #f5d8236-4 v3 to it ...my son wants to play his x-box 360 while im on the computer...please help
theres a number of solutions
you son my have a wireless reciever on his xbox(this is either built in or can be purchased) this will allow him to access the router around the house wirelessly allowing you to keep your cable plugged in to your desktop
protip:,make sure that the router channel number is set to 11 or the xbox wont read the wifi signal
you can get an extra long cable to reach between the router and the xbox (standard cat6 cable) id buy that online as its cheaper than in the stores.this will plug into one of the ports at the back allowing him to play while you surf the net
Mar 07, 2011 | Belkin Computers & Internet
Can i connect my xbox to my laptop /w pc usb
Xbox Network Connection using Hub
This is the most common network configuration and is also the easiest to setup.
Step #1: Plug your network cable(RJ-45 cable) that comes from your cable/DSL modem into the uplink port of your hub. (Make sure that your uplink is switched to "on").
Step #2: Take an RJ-45 cable and run it from one of the ports of the hub, directly to the Network Interface Card (NIC) installed in your computer.
Step #3: Take another RJ-45 cable and run it from a different port of your hub directly to your xbox.
**NOTE** A switch may be used in place of a hub with the same basic setup.**
That's it! No other network changes should be needed for this configuration. Your Xbox is now on the same network as your PC.
Xbox Network Connection using Router
This is another common network configuration.
Step #1: Plug your network cable(RJ-45 cable) that comes from your modem into the WAN port of your router.
Step #2: Take an RJ-45 cable and run it from one of the ports of the router, directly to the Network Interface Card (NIC) installed in your computer.
Step #3: Take another RJ-45 cable and run it from a different port of your router directly to your xbox.
**NOTE** In steps #2 and #3, you should not use a port that is directly beside the "uplink" port on your router, if your uplink port is being used to connect to another routing device.** If your router has a built in firewall, you will need to forward ports 8602 both incoming and outgoing to the internal ip address of your pc. Consult your device manaul for port forwarding.
That's it! Your Xbox is now on the same network as your PC
Xbox Network Connection using Crossover Cable
This is the last network configuration. For this setup you need at least one NIC card.
Step #1: Plug your USB cable that comes from your modem into your PC's USB port. This should already be done, if you have a usb modem for your current internet connection.
Step #2: Take an RJ-45 cable and run it from an installed NIC card on your PC, directly to the Xbox.
**NOTE** A crossover cable is only needed if you are connecting the Xbox directly to the second NIC card. If you have a device such as a switch, hub or router in between you should use a standard RJ-45 cable. This type of network setup also requires "Winroute©", a program downloadable from the world wide web. Consult the manual for specific instructions on how to set this up. Also if you have a USB ethernet adapter, you may use any of the setups described herein. USB ethernet adapter basically converts a USB cable into an RJ-45 cable.
That's it! Your Xbox is now on the same network as your PC.
Aug 14, 2009 | Video Game Consoles & Games
Have the n+ wireless router/modem trying to connect via a cable to xbox live but keep gettin insufficient MTU even though the actual MTU of the router is higher than required
You may have to use trial and error to find the best MTU fit:
MTU Default of 1500 to 1492
Tart the setting the MTU @ 1400
MTU setting. Xbox LIVE requires a minimum MTU setting of 1364.
The information your console sends and receives is broken up into "packets" for transmission over your network. MTU is a setting that controls the size of these packets. If it's too small, you won't be able to connect to Xbox LIVE.
Top Solutions Try these solutions in order. If you give each one a shot and you still can't connect, contact Xbox Customer Support. Note that they will ask you try the suggestions on this page first.
Solution 1: Check your router MTU settings Xbox LIVE requires a minimum MTU setting of 1364. Usually, you can change your MTU setting from your router configuration web page, which is supplied by your router manufacturer.
Learn how to find and use your router configuration page
Look for the MTU setting on the router configuration page. When you find it, set it to Auto or 1364 (or higher), save your settings, and then try to connect to Xbox LIVE again on your console.
Solution 2: Connect directly to the modem If your router's MTU is set correctly, try bypassing it by connecting your console directly to the modem. This will help determine whether there's a problem with your router or something else on your network.
Note
This may require you to move your console to a location close to your modem. This is a temporary arrangement, meant only to troubleshoot your connection. If your console is connected wirelessly, you'll need an Ethernet cable for this step.
To connect your console directly to your modem (wired connection):
  1. Find the Ethernet cable that runs between your console and the router.
  2. Unplug the cable from the router, leaving it connected to the console.
  3. Find the Ethernet cable that runs between the router and the modem.
  4. Unplug the cable from the modem, and plug the cable from your console in its place.
To connect your console directly to your modem (wireless connection):
  1. Unplug the USB connector for your adapter from the console. The adapter can remain attached to the console.
  2. Plug an Ethernet cable into the Ethernet port on the back of the console.
  3. Find the Ethernet cable that runs between your router and the modem.
Try to connect to Xbox LIVE again. If it works, there may be an issue with your router. Double-check the MTU setting in solution 1 above. Also confirm that you're using a compatible router, and make sure it has the latest updates from the manufacturer. If the problem persists, you may want to try a different router.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 06, 2009 | Belkin N1 Vision Router
Router problems when using xbox live
This sounds like a problem i ran into a few years back with a ps2.
This is not a machine related problem this is a signal strength problem. Most likely you have too much cord in between the router and the X box try shortening that cord as much as possible.
If this doesnt work try calling 1-800-4MY-XBOX
they will run a few tests with you and confirm my diagnosis.
you might be forced to run Xbox lve directly off your modem in an extremem situation or consider upgrading your internet signal or router
GL
Comment for further help
Please rate advice as it will help me out
Apr 08, 2009 | Microsoft Video Game Consoles & Games
Xbox Live On Westell C90-610030-06 Isn't Working
if this is the original xbox you have to use a crossover cable especially if your router is the same as your modem (both the same box) (try google for the crossover cable instructions.) if this is the 360 it should just work, also how is your router plugged into your modem or are they the same thing. If that is the case go get a linksys router and set it up so that your modem-router combo plugs into the linksys router which plugs into your xbox (note that this is a fix for the original to.)
Jan 10, 2009 | Microsoft Xbox 360 Console
Trying to play x box live by running an ethernet cable from my dsl modem to my x box, but it doesn't work why?
Easiest way to fix that problem is to run your eithernet cable through a router/gateway/switch... it will go modem>gateway>xbox after cable has been ran set everything to auto and run a test. may need to do a few configuration changes to gateway but othere then that you will be online and good to go.
Dec 05, 2008 | Video Game Consoles & Games
Ip address
try resetting your router & modem.unplug modem,unplug router....plug up your modem wait 4 all the little lights 2 light up & then plug up your router.if that doesn't work i don't know ;)
Feb 16, 2008 | Microsoft Xbox 360 Console
Ip address failed
If you are behind a router.. try hooking it up directly to your cable modem or DSL modem. If that fixes the problem then you need to open ports on the router to allow the connect to get routed to your xbox.
http://support.microsoft.com/kb/908874
Jan 18, 2008 | Microsoft Xbox 360 Console
GigaFast Ethernet GigaFast EE400-R Router Logo
144 people viewed this question
Top GigaFast Ethernet Computers & Internet Experts
Michael Galve
Michael Galve
Prashant M
Prashant M
WelderArc
Are you a GigaFast Ethernet Computer and Internet Expert? Answer questions, earn points and help others
