Question about Dishwashers
My dishwasher is not getting any power, we plugged in another appliance and it worked fine
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 162 Answers
Obviously its the power supply . check breaker.
Posted on Feb 05, 2010
My dishwasher stopped working, bought within the past few months, it seems like no power is getting to it. I've checked the breaker and all other appliances in house are fine.
Please provide make and model number of the dishwasher along with some indication of the last cycle it completed before this problem occured.
Aug 30, 2011 | Dishwashers
WON'T TURN ON. PLUGGED IN AND BREAKER IS ON.
Unplug the washer and get a short HD extension cord and plug in to another KNOWN good (has power) outlet. Or plug in a small appliance where the washer was plugged in and see if it works. Designated outlet for washer could be defective. Never work on electrical devices until you have the correct breaker switched OFF. Good luck, best regards.
Feb 01, 2011 | Miele 24 in. G892SCU Plus Built-in...
We came home from holidays a few years ago and the dishwasher (Westinghouse 905) just didn't turn on. We've tried it repeatedly since then and are unable to get it to turn on. The power point works for...
Appliances that sit without use, usually have more problems than just the original problem.
In your case I would first check the power conection on the dishwasher. located under the machine
If this is fine then I would move on to the door switch.
these are comon problems that could be inexpensive fixes.
Jan 12, 2010 | Dishwashers
The pump to get rid of water does not stop, I have tried reseting it with no success, it has been fine before this problem
Hi.
The problem is that water has entered the base of the appliance and has activated the anti flood device.
To prove this disconnect the power to the appliance and wiull a few towels handy pull the dishwasher out. Place towels behind the appliance and tip backwards about 45degrees. If you can see water coming out then this confirms the problem. The appliance will work again for a few washes then same problem wioll come back.
Unfortunately there are many reasons why this can hapen so you will need to call a local engineer.
Regards
Aardvrak Repairs
Nov 18, 2009 | Bosch Dishwashers
We have a GE profile dishwasher. It worked fine last night. Tonight we loaded it and closed the door. Its like it dosent power up.
If your dishwasher doesn't work at all, check these: Power from the house Door switch Wiring Timer or selector switch Power from the house Is there power getting to the dishwasher? This can be difficult to test, because dishwashers are usually wired directly to an electrical circuit, rather than plugged into the wall. But at least check for a blown fuse or a tripped circuit breaker. Door switch The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it. Wiring Often the main wiring connection from the house, at the dishwasher, burns and breaks the connection. If that's the problem, the wires must be repaired/replaced as necessary. If that's not the problem, check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors. Timer or selector switch Although it's uncommon, the timer or the selector switch may be defective. If so, you need to re
Oct 11, 2009 | Dishwashers
Dishwasher is not working. No power. I checked the electric box and everything is fine. Pulled dishwasher out, and it seems to be plugged in.
Door switch
Wiring
Timer or selector switch Although it's uncommon, the timer or the selector switch may be defective. If so, you need to replace the defective part, because neither of these can be repaired.
Jul 31, 2009 | Dishwashers
IS THERE AN INTERNAL BREAKER OR FUSE INSIDE A MAYTAG wc202
There is no fuse in this unit.
If unit has power but it is not cycling, then test wirings and circuit board.
Try first unplugging and plugging back the unit.
If there is no power at all , and the machine gives no sign of life, test the power cord and and the control assembly. In UK and other country there is also a fuse inside the power cord plug.
Here you find all diagrams and parts for your appliance <Click to open>.
Mar 15, 2009 | Dishwashers
Zsf6120
Dishwasher doesn't run
If you turn on the dishwasher and nothing happens:
1) Be sure the power is on, the door is latched, and the control is turned on. Also make sure the appliance cord is plugged into the electrical receptacle under the sink (some are hardwired and don't come unplugged).
2) If that doesn't solve the problem, the door switch, the timer, or the selector switch may be defective. To solve the problem, you may be able to adjust the door latch's strike slightly, using a screwdriver (turn off the power to the dishwasher at the electrical panel when working on it).
3) If that doesn't work, call an appliance repairperson.
Dec 02, 2007 | Zanussi 24 in. ZSF6120 Free-standing...
If you turn on the dishwasher and nothing happens: 1) Be sure the power is on, the door is latched, and the control is turned on. Also make sure the appliance cord is plugged into the electrical receptacle under the sink (some are hardwired and don't come unplugged). If it can be unplugged, make sure the electrical receptacle is working (plug in a working appliance or a circuit tester). 2) If that doesn't solve the problem, the door switch, the timer, or the selector switch may be defective. To solve the problem, you may be able to adjust the door latch's strike slightly, using a screwdriver (turn off the power to the dishwasher at the electrical panel when working on it). 3) If that doesn't work, call an appliance repairperson.
Jan 18, 2006 | Hoover 24 in. DT999 Free-Standing...
Dishwashers Logo
49 people viewed this question
Top Dishwashers Experts
Owen Barnes
