Question about Acoustic Research 900MHz Wireless Stereo Speakers with Auto Tuning
TRANSMITTER FOR A AW811 NO LONGER WORKS.. DID WORK TOO LONG AFTER I GOT IT...HELP
    Problem Solver:
  • 8 Answers
Did you change the distance between the two ? assuming they are plugged in, does a power light come, maybe a fuse.
Posted on Mar 21, 2010
Why doesn't it connect to sensors?
From your description, it seems that the transmitter section of SC-001 is working properly. What you have done to reinstall the system may not be thorough. And it is unclear whether the control panel is not responding to keychain transmitter or sensor or both.
I assume that you have followed the instructions in the manual to clear the zones. Simply unplugging the AC power and removing battery will not clear the zones. Note that sensors can be programmed into zones 1 to 4. Keychain transmitter can be programmed into zone 5 only. There is no LED indication for zone 5.
Secondly, follow the instructions to program the sensor or keychain transmitter to the control panel. The corresponding zone LED will be flashing during programming. There is sound indication as well for successful programming of the device.
If you do not program the sensor or keychain transmitter to the control panel after clearing the zones, the control panel will no longer respond to the device.
The dialer and siren is not cleared on the control panel. They can be cleared only from the dialer or siren itself.
Dec 11, 2015 | Skylink Group Skylink Sc-100 Security...
Fireplace remote control no longer works correctly
To re-sync your Honeywell 8220 transmitter to the valve: Turn the Local/Remote switch on your valve to Local. Then switch it back to Remote. Within 10 seconds of switching it to Remote, you need to press the Flame button on your transmitter. This will re-sync your transmitter to the receiver in the valve. Replacement transmitters and valves are no longer available for this system, they were discontinued by Honeywell and they are completely out of stock. Monessen Hearth Systems (now owns Majestic, Vermont, etc) has a retrofit kit with a new valve, pilot assy, and remote for these old RF units. (expensive, but cheaper than a new fireplace). FYI, aftermarket remotes are NOT compatible with this Honeywell system.
Nov 24, 2012 | Televison & Video
Suzuki aerio lights on alarm
replace the weak batteries b) see if there stronger radio transmitter near( such radio station, airport transmitter)
2) you must shure the system is o.k and proceed to unlock
3) if the system NOT work, detailed diagnosis is required from the manufacturer recommendations see the diagram.
God bless you
Sep 19, 2012 | 2003 Suzuki Aerio
Ok my alarm is not working because a little piece of wire is off and my brother got it from circuit city but it is no longer in business I just need to know where to go to get it fixed or if you can help...
Since you have a Viper system, you can go to any dealer to have it repaired.
You can find an authorized dealer via this link.
http://www.viper.com/Stores/
Depending on the problem, a local alarm shop may be able to repair it.
Nov 14, 2010 | 7701V Responder 2way Transmitter LCD...
The light on the transmitter is no longer on, but if I put it close to my keyboard and mouse, they work fine..Is there a battery in the transmitter that controls the signal strength??
The light doesn't need to be on to work. the lights on the transmitter indecate if the number or cap lock is on or if the mouse or keyboard batteries are low.
Mar 02, 2010 | Dell Wireless Keyboard Optical Mouse w0147
Philips LX3950W - no signal to rear speakers
check to se if your reciever channel number is set to the same as your transmitter channel number. press and hold down sound butten on remote to set transmitter number .set reciever number button on reciever unit. try setting both to number 4.
Dec 29, 2009 | Philips LX3950W System
Wireless speakers AW872 transmitter won't power on anymore
Idhager,
I have the same set of speaker and had a similar problem. what I did was disconnent and reconnect the transceiver (sort of a reboot) and then powered everthing back up and that solved my problem.
Hope this helps
Dec 23, 2008 | Acoustic Research 900MHz Wireless Stereo...
Regarding Acoustic Research Speaker model AW811-----------I was using the speaker and for some reason it stopped playing. I don't know what happened. Can you help. I know have 3 of them. Do you have...
Check the speakers resistance if not open , use a multitester for checking and there connection if not loose.post a message whatever the result...
HOPE THIS MAY HELP;
REGARDS,
VOTIT
DON'T FORGET TO RATE
Jul 24, 2008 | Audio Players & Recorders
Hands free calling and FM transmitter
Old post, but here we go.
1: Update to latest firmware from tomtom, for Gox20/x30 that is 8.351
2: Make an silent mp3 file and put that onto device
3: Play silent mp3 in loop
4: Send nav instructions over fm to radio... et voila!
Jul 20, 2008 | Tomtom GO 720 GPS Receiver
No longer works
First check the fuses,the switches, sometime corrosion can cover the contact and check also the thermal fuse.......
Feb 09, 2008 | Hampton Bay 52 In. Brushed Nickel Romano...
Acoustic Research 900MHz Wireless Stereo Speakers with Auto Tuning Logo
198 people viewed this question
Top Acoustic Research Audio Players & Recorders Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you an Acoustic Research Audio Player and Recorder Expert? Answer questions, earn points and help others
