Question about PfaFF Sewing Machines
1475 C.D. How do I adjust machine to do free arm
I have a pfaff 1475 C.D. machine and have recently taken up quilting. How do I adjust machine to do free arm quilting?
  • 323 Answers
SOURCE: free motion
If the machine works on regular stitching and only messes up on free motion ,the most likely problem is the presser foot has not been lowered. Get everything ready to sew, lower the presser foot lever and pull on the upper thread near the take up lever. It should have tension on it. Raise the foot and try again, it should not have tension on it . If this is what you get, lower the presser foot lever and try it again.
sewman7
Posted on Jun 11, 2008
SOURCE: Free motion quilting Viking Designer 1
I had the same dissatisfaction when I switched from the 1+ to the Designer 1. After some trials I am now happy. You need the springy free motion foot. Part #413 03 76-45. You take off the white shank and screw it on with the metal bar over the needle hook. In the set menu turn the SensorQ on, the free motion on, select stitch 1 from menu V and drop the feed dogs. It also makes a big difference to use the straight stitch throat plate which just has a small hole for the needle to go through. One other hint is that I often have to reduce my needle tension 3 or 4 steps. Hope it works for you.
Posted on Jul 02, 2008
bargainbox
  • 1388 Answers
SOURCE: I have purchased a Pfaff 18.8 Grand Quilter
Speak to the Pfaff dealer where you bought it and tell them....they will probably arrange a replacement with little fuss.
Posted on Aug 27, 2009
Testimonial: "Thanks for your prompt response: Both I and my dealers have been working together No luck but thanks for trying"
  • 35 Answers
SOURCE: I need a new mother board for Pfaff creative 1475
If you want to learn how to repair sewing machine by yourself, I suggest you to order the following product:
Sewing Machine Repair Guide
It's a professional step-by-step repair guide written by an expert. Besides PfaFF sewing machine, you can learn how to repair other brands of sewing machine as well. The author claims that you can earn money after you had learned the repair skills!
Good luck.
Posted on Sep 08, 2010
SOURCE: My Pfaff 1475 CD stated batterie pile battery when
turn the machine to "on". Tip the machine on its back and you will see a little door on the left-hand side. Open the door from left to right and inside are two AA batteries. Change the batteries (both batteries go in with the at the top). Close the door, upright the machine, turn it off and turn it on again. The display will be 0 0 2.5. It's now ready to go.
Posted on Oct 25, 2010
Pfaff 113 want to free motion quilt the foot will not allow me to se. I even took the screw for adjusting preasure all the way out and it still has too much preassure
Sounds like perhaps you have the incorrect foot. Did you perhaps purchase a quilting foot (used for piecing)? A free motion foot is actually shorter in height so it will not contact the feed dogs or needle plate. It is this added space that allows the fabric to be moved freely under the foot. Also, be sure to drop the feed dogs.
Open Toe Free Motion Spring Foot
Open Toe Free Motion Foot
Pfaff 113 free motion foot Google Search
If the presser foot is still too long, perhaps the shank is not correct for your machine. Sorry, am unable to locate information re your particular model.
Sewing Machine Feet
Apr 05, 2017 | PfaFF Sewing Machines
Can the presser foot be raised slightly on pfaff tiptronic 2030 to facilitate free motion quilting? There is not enough clearance with feed dogs down to freely move material to quilt. Thank you.
You need a special foot for free motion quilting--it is slightly shorter in height than a regular presser foot, which essentially provides space between the presser foot and the needle plate to manually move the fabric. Sometimes machines came with a standard darning foot accessory. Your Pfaff dealer probably has at least one style in stock. But there are other specialty feet you can probably use, ie Big Foot, clear free motion foot, C-shaped, oval, etc. You can also purchase a shank adapter (verify it is the correct shank for your machine) and use it with a kit of snap-on presser feet so you can have a variety of presser feet for different functions.
Pfaff Presser Feet
Pfaff Big Foot Free Motion Quilting Foot
Pfaff Free Motion Guide Presser Foot
Pfaff Free Motion Open Toe Quilting Foot
http://www.sewingpartsonline.com/snap-on-sewing-machine-presser-feet.aspx
May 07, 2016 | PfaFF Sewing Machines
Pfaff 1475 manual
Not sure if your model is the creative 1475. The closest I can find at a service website of Pfaff is 1473. Check if this is similar to your model and it shows where the balance wheel goes.
http://new.pfaff.com/SiteMedia/PFAFF/Products/Machines/Support-manuals/Creative_1473-manual-EN.pdf
Also see this Youtube video showing how to insert the bobbin after threading.
Pfaff Creative 1473 CD sewing machine in action
otherwise you will have to buy service manual for eBay
PFAFF CREATIVE 1475CD Sewing Machine Service Manual
Aug 12, 2014 | PfaFF Sewing Machines
1475 running slowly
Visit my favorite site: www.fixsewingmachine.com for FREE videos, fix tips and tricks, pictures, fix timing, oiling, and more--more info then a manual and all FREE. Jimmy
Apr 03, 2012 | PfaFF Sewing Machines
Looking for repair manual for pfaff 1475 sewing machine
There are a number of sites that offer the Instruction Manual for a fee. See the following:
https://www.paypal.com/uk/cgi-bin/webscr?cmd=_flow&SESSION=-ie7IespXbGhzxSgz7VOcenyV4QpRpdnv3SQLygeVdu2EeF4PBuUnr4Vxd0&dispatch=50a222a57771920b6a3d7b606239e4d529b525e0b7e69bf0224adecfb0124e9b61f737ba21b081988562bf19d61623c6f33db8e87506be10
http://gotoes.org/sales/PfaffSewingMachineManuals/ViewInfo.pl?Pfaff=1&Sewing_Machine_Model=CREATIVE-1475-CD
http://www.sewingpartsonline.com/instruction-manual-pfaff-1475.aspx
I was able to find a free download of the Instruction Manual for the 1473 if that would be of any assistance:
http://s2.vsmgroup.com/VSM/Pfaff/pfaffmanual.nsf
Not sure if these will have enough information to help with repair but perhaps the 1473 manual will give you an idea whether the information you require is likely to be in the Instruction Manual before you purchase.
Jan 14, 2012 | Sewing Machines
Sewing Machines Logo
110 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
