Question about Canon MultiPASS F60 All-In-One InkJet Printer
Canon F60 Check Printing
Hi, I seem to be having the same problem as the others who have the "Check Printer" issue, however, when I try to reset the ink count, it keeps flashing between that and the "purge flag" option. Once, through some unknow action of mine, I got it to set on the ink count option, I hit clear, and then nothing happened. My printer has never told me what's wrong. I'm just guessing that it is the ink well issue. Should it actually say that? Is there a code I should be looking for? This all started because it wouldn't recognize the full ink cartridges I put in. Help!
The waste ink tank near full
Posted on Mar 08, 2008
Canon F60 Multiprinter printing random light lines.
I had a case just like yours where the printer wasn't in use for some months because there was a second, better printer to use instead. So when the abandoned one was to be used again, it was no longer salvageable. And I tried cleaning it and maintaining it doing everything in the book to make it work again but no matter what I did, it ended up in the garbage bin after all my wasted time and effort. I'm sorry. I wish I had better news for you but I'm speaking from experience. Yours might be a write-off too in which case you are better off to just buy a better one.
Feb 05, 2010 | Canon MultiPASS F60 All-In-One InkJet...
How do you get rid of waste ink in a Canon MultiPASS F60?
Hi
This works on the F30, F60, and F80.
Resetting the Waste Ink Volume Counter
1) Enter SERVICE MODE.---
By pressing Menu-Copy-#
2) Select TEST MODE.
3) Select [8] PRINTER TEST in TEST MODE.
4) Select 3. [EEPROM CLEAR].
5) Select 0. [INK COUNT].
6) Press the [OK] key.
7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
Skip step (6) since there is no [OK] key on F30 printers.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Oct 26, 2009 | Canon MultiPASS F60 All-In-One InkJet...
Cannon multipass F60 scanner/printer striped color printing
What you have is a dried up color cartridge. You can try to use the <clean print heads> in the diagnostic tools section of you priner software. (usually, just try to print something & the window will appear) Sometimes you have to clean heads, then print test page like 2 or 3 times before it clears up. If that doesn't correct it, don't worry. Have your color cartridge filled (staples, office depot, & other stores do it cheap) - or - replace it with a new cartridge. You may have to run the clean print heads program after installing a new cartridge, but this will definitely fix your problem.
Jul 26, 2009 | Canon PIXMA MX850 multifunction InkJet...
Canon multipass F60 blinking alarm - press resume- check printer
Hi. if your multipass is connected to a computer you can check in the printer monitor status the exact error . Or you can count how many time the error display blinks
May 18, 2017 | Canon MultiPASS F60 All-In-One InkJet...
5100 error with canon i255 printer
5100 is a carriage error, check the timing strip for contamination(plastic strip about 1/4" in width)
The unit is not homing, check for obstructions.
Dec 24, 2008 | Canon MultiPASS F60 All-In-One InkJet...
Driver?
ok my friend
here u can download the drivers from this website
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=238&modelid=7174#DownloadDetailAct
just click on the (Drivers & Downloads) button (to the middle right side).
select the operating system that u have (windows vista ,XP).
and start the download
install the drivers
enjoy printing
cheers
Sep 04, 2008 | Canon MultiPASS F60 All-In-One InkJet...
Canon F60 Waste Ink reset
I had the same message "check printer. press resume key". I cleaned the encoder strip and reset the waste ink volume counter like 6 times and it helped. To reset the waste ink volume counter, follow the steps below. (These steps were originally posted by NerdRUs.):
6) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
May 11, 2008 | Canon MultiPASS F60 All-In-One InkJet...
Canon F60 waste ink near full message
Hi. I actually had to reset the waste ink volume counter on my F60 and found a solution posted by NerdRUs that helped me. So I copied and pasted it below:
Apr 22, 2008 | Canon MultiPASS F60 All-In-One InkJet...
Alarm light on. F80
This worked for me on an F60 and someone else on an F30. Re: Check Printer error message on Canon MultiPass by watsonk (6/7/05 11:16 PM) reply + / - It could be due to "waste tank full" alarm; you may need to reset the waste tank counter. I found a reset sequence for a MP730 printer in this website that works for F30 as well. Try: Resetting the Waste Ink Volume Counter 1) Enter SERVICE MODE.--- By pressing Menu-Copy-# 2) Select TEST MODE. 3) Select [8] PRINTER TEST in TEST MODE. 4) Select 3. [EEPROM CLEAR]. 5) Select 0. [INK COUNT]. 6) Press the [OK] key. 7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key. Skip step (6) since there is no [OK] key on F30 printers.
Sep 29, 2007 | Canon MultiPASS F80 All-In-One InkJet...
Canon f60
before you clean your printer head, try identify if there're other problems, for example maybe your ink is running low, this will cause bad quality printing. To clean your printer go to control panel, click printers and other hardware, click printers, right click on your printer icon and select properties, click on the tab maintenance and you will see what options are availible. In your case my look for something said cleaning. (NB: this is winXP)
Feb 28, 2007 | Canon MultiPASS F60 All-In-One InkJet...
Canon MultiPASS F60 All-In-One InkJet Printer Logo
old marine
old marine
