Question about Sharp AR-810 Black and White Copier
What is the Abnormal Fuser During Warm-Up Error Code C-44 Sub 05 for the AR-810
  • 1,476 Answers
The fuser is a heating element which "fuses" or sets the toner to the paper using heat. A fuser error has occurred. Here are some items to check and perhaps solve your problem. 1. Turn the printer off, wait 10 minutes, and then turn the printer on. 2. If the message persists, reseat the fuser. If that does not work, replace the fuser. To check the fuser, turn the printer off and remove the fuser. Measure the resistance between the fuser connectors. If it is not within the proper range, replace the fuser. If there is not continuity between the fuser connectors neutral and hot with the fuser removed, replace the fuser. If the problem is not related to the fuser, replace the engine controller board.
Hopefully this will solve your problem. If you are not capable of performing the testing you should hire an experienced tech to do it.
hardrocko
Thank you for using FixYa
Posted on Feb 13, 2010
HOW DO I RESOLVE H - 4 ERROR ON MY AR-5320E SHARP PHOTOCOPYING MACHINE?
1. Entering the simulation mode
Perform the following procedure to enter the simulation mode.
"#" key "*" key "C" key "*" key
Main code 14 Start key Sub code 0 Start key
OR
"#" key "INTERRUPT" key "C" key "INTERRUPT"
2. Canceling the simulation mode
When the clear all key is pressed, the simulation mode is cancelled.
When the interruption key is pressed, the process is interrupted and the
screen returns to the sub code entering display.
* After canceling the simulation mode, be sure to turn OFF/ON the
power and check the operation.
Note: If the machine is terminated by a jam error or paper empty during copying in the adjustment by the simulation, recopying is required.
DO NOT CONTINUE RESET AS THIS CAN CAUSE A FIRE AND RUIN A PERFECTLY GOOD DAY. REPLACE THE FUSER UNIT
Apr 30, 2015 | Sharp Office Equipment & Supplies
How can i clear H 4 error code on my sharp AR-153E coppier. your help please.
OR
Mar 20, 2015 | Sharp Office Equipment & Supplies
How do i fix a h4-01 error code on my sharp ar m277 copier
OR
Feb 26, 2015 | Sharp Office Equipment & Supplies
SHARP AR 5320 PHPTO COPIER ERROR H-4
fuser error which could be a number of issues , press green copy button for sub-code
Aug 19, 2014 | Sharp AR-5320 Black and White Copier
Error code h4-20
check fuser pressure roller shaft may worn out and also check how is upper roller and bushing together if they r not ok then replace them all then u may need to reset byt your key steps #*c* choose 14 press start button will reset this error and your machine will be ok this error is for fuser motor rotation abnormal because your fusing unit is tight try it and let me know
Feb 24, 2014 | Sharp AR-M257 Black and White Copier
Earorr E 7
E7 it is main code sub code 03 problem on LSU Check printing with SIM 64-1check the LSU unit.Check the MCU PWB
Sub code 04CCD white level trouble# Details CCD white reference level which is read during the copy lamp lighting is abnormal.
Aug 28, 2010 | Sharp AR-5316 Advanced Digital Imager...
SHARP AR-287
Is the code a H5 ? Is it a AR-163 or a AR-287? Is the copier making a load noise when making a copy? Basicly, the code means you are have more then 5 paper jams in the fuser & there is a problem there & the copier is locked up.... It's self saving it self
May 05, 2010 | Sharp AR 163 Copier
Machine come up with a F-10 code and will not warm up. The fuser comes on and shuts off after 30 sec. and the machine runs and runs then comes up with a E-41 code.
F10 00 Printer board problems 01 Printer board problems 02 Printer board problems 03 Network card error 04 Firmware error 05 Not enough memory 10 Printer board problems 90 Printer board problems
Jan 16, 2010 | Sharp -COPIERS - AR-800 Copier
H5-01
Hello sir;That code means, fuser jam, fuser not installed or pcu main board/sub board, seem like fuser unit not installed.
Mar 22, 2009 | Sharp Office Equipment & Supplies
Error Code SC542
Fuser temperature warm up error. Hot roller warm up error. It could need a new thermistor or a heat lamp. That will make the error go away.
Oct 10, 2008 | Ricoh A1515F Copier
Sharp AR-810 Black and White Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
