Question about HP Mini 1000 Notebook
Boot manager is compress
How do i fix this with being able to boot the computer
  • 733 Answers
Boot Manager is compressed???
here are two solution:
1.
"BOOTMGR is compressed. Press Ctrl+Alt+Del to restart"
Check points for fixing compressed boot-manager:
Boot into Windows Recovery Environment (WinRE) and perform a "Startup Repair".
If the above doesn't solve the problem then boot into WinRE again, but when selecting the Vista-installation, then press "Load Drivers" (Instead of "Next") and use the mini Windows Explorer to right-click the boot-drive and deselect "Compress this Drive" and choose Apply to sub-folders and files.
If that also fails then boot into WinRE again, and go to the "Command Prompt" and execute these commands:
compact /U C:\bootmgr
compact /U C:\ntldr
If you for some strange reason have lost your Vista DVD, then you can also use a Windows 2000 / XP install CD and enter the recovery console instead and execute the following commands:
attrib -c c:\bootmgr
attrib -c c:\ntldr
2.if the above solution did not work for you try this easy way:
reboot, push open the dvd drive, load OS Vista CD/DVD, before the ridiculed bootmgr compressed shows, shutdown, boot from the dvd, let the installer do it’s job.
when reach choice “install now” choose “repair the pc” instead.
In the System Recovery Options dialog box, choose the drive of your Windows installation and click Next.
click Startup Repair.
Just click “load drives”since you know the answer about “repair”….nothing wrong..)=:
see that??, you’re inside your HD!! I assuming that from here everybody knows what to do, if not, that what follow:
Browse for your “C” Drive, right click properties and fellas, reverse what you did, exit, reboot.
Posted on Feb 07, 2010
4 Suggested Answers
  • 86 Answers
SOURCE: boot manager compressed
Sorry to tell, format and reinstall everything, next time if you need space upgrade hard drive or buy an external HD
Posted on May 04, 2008
sexymax15
SOURCE: Compressed boot manager
Windows Vista includes a new Boot Manager (BootMgr) that replaces the old NT Loader (Ntldr).
If the boot partition no longer can be found, then Vista will display the following error: BOOTMGR is missing. Press Ctrl+Alt+Del to restart
The Windows Boot Configuration Data file is missing required information
More Info MS KB 919529
More Info MS KB 927391
This can usually be solved by checking the boot devices, and if no problems found then use Windows Recovery Environment (WinRE) and perform a "Startup Repair".
If by accident having compressed the entire boot partition, then Vista will display the following error: BOOTMGR is compressed. Press Ctrl+Alt+Del to restart
This can usually be solved by using Windows Recovery Environment (WinRE) and perform a "Startup Repair". If that fails then use WinRE to enter the "Command Prompt" and execute these commands:
  • compact /U C:\bootmgr
  • compact /U C:\ntldr
Posted on Sep 29, 2008
SOURCE: boot manager files compressed windows won't start cannot start up
make sure computer is off, insert xp disk, at the top left corner of your screen you will see boot from cd press any key and let windows do its thing follow instructions . use up and down arrows to highlight and delete old files . old wndows that did not work. yes you are sure to delete refomat follow and answer questions very simple. your computer will blink flash thats part of the process, it will even reboot do not touch anthing at all the computer will let you know when its done, once you start the installation i repeat let the computer o its thing sometimes its fast sometimes not wait frediemccly@yahoo.com
Posted on Jun 02, 2009
I was given an Acer Extensa 4420 shortly there afrter i turned it on and the boot manager was compressed. is there a fix i can do myself for free
Try to boot up into the Recovery Console. If you can get there, go into explorer, right click on the boot drive(it is seperate from your c: drive) and de-select "compress this drive".
If that does not work and you can somehow boot to a command prompt, go there and then type compact /U C:\bootmgr and compact /U C:\ntld
If that does not work, borrow a windows disk from someone you may know and enter the recovery console off of the disk and do the 1 step above.
Sep 25, 2012 | Computers & Internet
Boot manager compressed dell inspiron e1505
you may have trouble sorting this with out the disc.Here are the steps to replace the BOOTMGR:
  1. Boot from the Windows install disc.
  2. Click on Repair your computer after selecting proper language, time and keyboard input.
  3. Select the Windows installation drive, which is usually C:\ , and click Next.
  4. Choose "Command Prompt" when the System Recovery Options box appears.
More items...
BOOTMGR is compressed: Press Ctrl+Alt+Del to restart
https://neosmart.net/wiki/bootmgr-is-compressed/.....or try this link.. boot manager is compressed press ctrl alt del to restart Google Search
Oct 14, 2017 | Dell Inspiron E1505 Notebook
Boot manager is compressed. Press ctrl+alt+del to restart. Same happens when i restart. My cd/dvd cant read cds or dvds
I am sorry to hear that your CD/DVD can't be read but in order to resolve your issue you need to have that drive working or have an external DVD/CD Drive to be able follow the below procedure and to resolve the compressed Boot Manager.
· Insert the installation DVD(Vista or Windows 7) in your Disc Drive and then power up your computer
· Click Repair your computer.
· Then click on Load Driver.
· Go to Computer.
· Right click on the partition your installation previously compressed> Properties.
· Uncheck "Compress drive to increase space available".
· Close all windows to restart the computer.
Jul 19, 2011 | Computers & Internet
It will not reboot the message 'boot manager is compressed' is displayed and will not move past it
  • Boot into Windows Recovery Environment (usually the install DVD or Create a Windows Vista/7 Recovery disk on an USB stick) and perform a "Startup Repair".
  • If the above doesn't solve the problem then boot into WinRE again, but when selecting the Vista-installation, then press "Load Drivers" (Instead of "Next") and use the mini Windows Explorer to right-click the boot-drive and deselect "Compress this Drive" and choose Apply to sub-folders and files.
  • If that also fails then boot into WinRE again, and go to the "Command Prompt" and execute these commands:
  • If you for some strange reason have lost your Vista DVD, then you can also use a Windows 2000 / XP install CD and enter the recovery console instead and execute the following commands:
    • attrib -c c:\bootmgr
    • attrib -c c:\ntldr
May 05, 2011 | Advent 4211c Notebook
Boot manager compreessed
Sadly the startup repair option or any other repair option in windows 7 startup recovery failed to solve this problem. this can be solved by
reboot your pc
select the repair your computer option
command prompt
at the prompt type notepad (since the recovery option boots from a seperate wim image it has notepad built into it )
press ctrl + o which invokes the open file dialog
go to the open file field (ALT+N) and type c:\boot and also see for the c:\bootmgr
file. right click it and deselect the option of "compress files to save disk space"
when we apply the boot manager is again decompressed. also if someone finds this harder we can directly deselect the compression option by reversing the process used to compress the drive
thats it . we are done
Apr 16, 2011 | Computers & Internet
Compressed hrd drive now it won't boot up error mess says compressed boot manager press alt,contrl,delete(win7)but just comes back to same screen
boot from Windows 7 disc, and Repair Windows 7. When it comes up it will ask u the language, pick your language, then in the bottom left corner of that box that says Install now, you will find repair my computer :)
Apr 13, 2010 | Acer Aspire 5100 Notebook
Boot mgr is missing
Boot Manager is missing If the boot partition no longer can be found, then Vista will display the following error: BOOTMGR is missing. Press Ctrl+Alt+Del to restart
More Info MS KB 919529 More Info MS KB 927391 Check points for fixing missing boot-manager: Check that your boot device is configured properly Boot into Windows Recovery Environment (WinRE) and perform a "Startup Repair". Boot Manager is compressed If by accident having compressed the entire boot partition, then Vista will display the following error: BOOTMGR is compressed. Press Ctrl+Alt+Del to restart OR maybe try this first. Check points for fixing compressed boot-manager: Boot into Windows Recovery Environment (WinRE) and perform a "Startup Repair". If the above doesn't solve the problem then boot into WinRE again, but when selecting the Vista-installation, then press "Load Drivers" (Instead of "Next") and use the mini Windows Explorer to right-click the boot-drive and deselect "Compress this Drive" and choose Apply to sub-folders and files. If that also fails then boot into WinRE again, and go to the "Command Prompt" and execute these commands: compact /U C:\bootmgr compact /U C:\ntldr If you for some strange reason have lost your Vista DVD, then you can also use a Windows 2000 / XP install CD and enter the recovery console instead and execute the following commands: attrib -c c:\bootmgr attrib -c c:\ntldr
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
Feb 21, 2010 | Acer Aspire 8920-6048 Notebook
Aug 28, 2008 | Computers & Internet
You are stupid!!! of course there is another way!!!!
http://answers.yahoo.com/question
/index?qid=20080612115923AAgIovt
Guru my ***!!!!
May 04, 2008 | Computers & Internet
HP Mini 1000 Notebook Logo
584 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
