E machine motherboard
Y need to know were the cable or conector named pwr/sw its gona be conected in the motherboard
  • 34 Answers
Most of the time, those connections are on the bottom-right of the motherboard. Look carefully for markings or words.
Most often its like this
reset HDD POW
o o o o o o o o
o o o o o o o o
PW/SW
or somtimes its above like this
reset hdd pow
pw/sw
o o o o o o
o o o o o o
LOOK AT THE MARKINGS. HOOKING IT UP WRONG MAY CAUSE PROBLEMS
hookups are usually like this
o o o o o o
o o o o [o o]
PW/SW
hope this helps
Posted on Feb 21, 2008
Power sw, reset sw, and led conectors are disconected and i don't know how to conecte them
This diagram from the manual shows the front panel header location and pin functions.
Jul 30, 2011 | ASUS K8V-X Motherboard
Problem with the MSI 7050 v2.0 (HP dx5150) Motherboard Front panel wiring colour diagram please.... PWR LED, HDD LED, PWR SW, AND RST SW
You should read manual of the moterboard, there is wiring diagram that you need. But however, i suggest to you - take it to the expert, if you don't know how to do it.
May 20, 2011 | Intel Motherboard
I need help connecting the power on cable and led cable as well as the hard drive light cable. for my emachine w3644
These cables are attached in the lower right corner of the motherboard. There are two rows of pins there. Probably 10 pins in all. They should be marked with letters something like hdled (hard drive LED), pwr (power light) pwr sw (power switch) spk (speaker) etc. Anyway, if you can't find markings, hooking the little plugs up to sets of the pins one plug at a time will tell you which works.You can't hurt anything by trying various combinations
Feb 13, 2011 | E-Machines Computers & Internet
I have a PLE01 mother board and i need to plug in the hdd,ldd and ect plugs and i don't know how they go as i do not have the manual and cannot read the small print can u help
Today's motherboard are easy to setup because mostly are now color coded like those connection ports.All you have to do is place the cables according to their color coded ports. Connectors are easy to identified because they are also labeled with name. Like the picture below.
Connections ports on the motherboard are also labeled similar to the connector cables above or have a similar abbreviated names like PSW for Power SW.
I hope this could help you..
Please don't forget to rate. Thanks..
Mar 24, 2010 | Intel Motherboard
Problem with panel front conector in Dell Dimension 2200 motherbo
The following information is to assist you in performing the right connections. You should take precautionary measures such as grounding yourself and completely disconnecting the PC form any source of power.
This picture shows the connector for the front panel power button, reset button, and power and hard disk lights: an 8x2 pin connector with 1 pin missing:
The table below lists the pinouts for the connector. The orientation of this table is the same as the picture above, this shows the top part of the connector. All the pins below pin 8 appear to be non-connected.
Each pair of pins labeled Power and Reset goes to the 2 wires for the corresponding button. The hard disk and power LED wires connect to the corresponding LEDs, you need to ensure the proper polarity of the + and - wires for each LED or it will not illuminate.
The above information is for your information only.
Mar 01, 2010 | Dell (2M502) Motherboard
Where do i plug hdd/led pwr/sw pwr/led? on an AMD Motherboard n1996
Cklick on this picture and you will know...You have to connect all three to "Front Panel" connector the way it shows on this picture...
http://img33.imageshack.us/img33/9223/11frontpanelinstall37sc.jpg
Feb 09, 2010 | HP Compaq Motherboard
Need help bigtime
are those all seperate connectors for the button? Or are they all together on one block? Should be something near bottom right hand corner of mobo saying pwr, hdd, sw, snd, led, that kind of thing
Mar 24, 2008 | E-Machines eMachines Desktop PC
Can't connect front panel Power SW cable
On your board in the corner at bottom, you find pins for front panel Power Switch Cable, over there in small characters PWR SW is written, you can put your Power SW Wire there
Jan 02, 2008 | Intel D845HV (735858149143) Motherboard
Intel D845WN motherboard
search for markings on the motherboard. sometimes the are not near the pins at all. the pins may have a name like J22 or something.
Sep 19, 2007 | Intel D845WN (KD845WNPAK10) Motherboard
Computers & Internet Logo
164 people viewed this question
Alun Cox
David Payne
David Payne
